# The Concept of Control
Electra can be described as a MIDI device that:
  1. Generates MIDI messages according to user actions, such as turning the knobs or using the touch
  2. Forwards MIDI messages between different ports, (<MIDI IO>, <USB HOST>, and <USB DEVICE>)
  3. Merges messages (1) to the flow of messages (2)
A Control is an instance of a synth parameter. It visualizes the value of the parameter and it generates and sends corresponding MIDI messages when the parameter value is changed. Control also reflects any change of the value according to the incoming stream of MIDI messages. Some control may have more synth parameter assigned, for example envelopes.
The picture below shows a Fader Control representing Filter cutoff with the value currently set to 8.
Fader cutoff
Each Control has several attributes that define its function and appearance. The most obvious attributes are:
  • type of the Control (fader, list, ...)
  • visual variant of the Control (regular, thin, ...)
  • the associated MIDI message type (CC, NRPN, SysEx, ...)
  • parameter number
  • minimum and maximum value.
Electra One users create Presets by organizing various Controls to layouts that suit their needs. These layouts are called Presets. Presets are created, edited, and managed in Electra One App (opens new window) and uploaded to Electra One controller over the USB device port. The picture below is an example of one Page of a Preset:
Preset screen
In this example, the Preset consists of a number of Controls used to edit patch parameters of one specific synthesizer. Presets may, however, consist of Controls that are linked to many synthesizers. This allows Electra not to be only a synth programmer but gives you possibility to be in control of the whole rig of gear.
# Control types
There are four types of controls currently:
  • faders
  • lists
  • pads
  • envelopes
The type of control tells Electra how the Control will look like. Also, it defines if the Control will work with continuous data ranges of values or with discrete values.
# Fader
Faders are ideal for showing and sending continuous ranges of parameter values. A good example of a fader is a cutoff frequency of a filter or an oscillator detune. Turning the knob smoothly changes the current value of the assigned parameter. As you turn the knob corresponding MIDI messages are sent and the fader value is updated on the display.
The value may change within a given minimum and maximum.
Fader control
If the value range minimum is negative, the zero value is placed proportionally within the length of the fader. Positive values are then represented by a fader bar extending to the right, while negative values extend to the left.
Control positive Control negative
Optionally, faders may have Overlay assigned. Overlay replaces specified values with a text label. More on info on overlays is provided below.
# Lists
The lists are one of the key features of Electra. They help to overcome the problem when discrete MIDI values have a specific meaning. Imagine a MIDI parameter VCF Envelope Mode that has the following four values:
MIDI value Text label
0 Normal
16 Inverted
32 Normal with Dynamics
48 Inverted with Dynamics
The fader would not be very helpful here. When the list is used for this Control, the behavior of the knob changes to act pretty much as an encoder. Turning the knob switches the values of the parameter.
List control
Each list value is represented as a dot. The currently selected one is highlighted and the label is shown. The lists may have up to 255 values. If the number of list items exceeds 16, the visual representation of the list slightly changes to a more fader like style. The text labels are still, however, shown instead of numeric values.
The lists do not have minimum and maximum values defined, they work only with values defined in the overlay.
Should the list receive a MIDI value that is not defined in the overlay, the numeric value will be displayed and the list will be highlighted with a red background.
# Pads
The pads are controls that can be used to switch between two states / values of given parameter or to trigger transmission of MIDI messages.
Pad control
The pad will transmit MIDI messages when its state is changed. It is up to the user to specify if a message will be sent on a change from Off to On state, or from On to Off state, or both. When going from Off to On state, On Value will be sent. When going from On to Off state, Off Value will be sent.
Program pad Sysex pad
The pads can act either as toggles or as momentary switches. A toggle stays switched in the new state, while a momentary switch always returns to the off state.
Pads are operated with display touch or by turning corresponding knob. Turning the knob clockwise, switches the pad on. Turning the knob counter-clockwise swicthes the pad off.
# Envelopes
The envelopes are multi-value Controls that greatly improve the visual representation of ADSR and ADR envelopes. They allow users to map their MIDI parameters to individual segments of envelopes. Electra One can then visualize the shape of the envelope whenever the incoming MIDI data modifies it or when the user changes the values with knobs.
ADSR control
The following types of envelopes are supported:
  • ADSR
  • ADR
  • ADDSR
It is possible to specify which value will be assigned to the knob by default. For example, you may choose Attack being controlled by the knob. It is possible, however, to change this assignment on the fly when working with the preset. It means one knob can be used to change all values of the envelope.
The detail window of an envelope control provides access to all parameters with knobs. The knobs are remapped so that all parameters can be changed with knobs.
ADSR detail
