# External MIDI control
There are often situations during your gig when you need both hands to perform and switching presets of pages could be cumbersome. The external MIDI control provides a neat solution.
The external MIDI control allows you to map a number of Electra actions to MIDI messages sent over to Electra's <USB HOST>
port. The currently supported actions are:
- switch to a specific page, identified by the page number
- switch to the previous page
- switch to the next page
- load a specific preset, identified by the preset slot number
- load previous preset
- load next preset
- recal saved snapshots
# Configuring a USB Host device
In order to use a MIDI Controller to send commands to Electra, it must be connected to Electra's <USB HOST>
and assigned to CTRL port. This assignment can be done manually at the USB Host configuration on the controller. Pre-defined mappings of USB devices to USB Host ports can be added on the Controller configuration page of the Electra One Account application, for more details visit Electra One configuration.
A permanent assignment can be done by uploading a custom configuration file to your Electra One.
# MIDI message assignments
Electra uses default mapping of MIDI messages as shown below. The default settings can be overridden by changing the External MIDI control configuration in the Electra One Account application. When overriding default assignments, the following MIDI message types can be used:
- control change (CC)
- note on
- program change
# Default setup
# Switching presets
Remote switching of presets is enabled when Electra has Bank Select set to 0. This can be done by sending Control Change #0 with value 0 to controller's <USB DEVICE>
CTRL port.
Once in the Bank select 0 mode, presets can be switched by sending Program Change MIDI message to controller's <USB DEVICE>
CTRL port. Programs 0 .. 71 are supported. This covers the 6 preset banks of 12 presets. For example, program 13 is the second preset in Bank 2.
This can be tested in the MIDI console by selecting the Electra One CTRL port and entering Midi Console commands.
Switch to preset loaded in the preset Bank 1 slot 3:
cc 0 0
pc 2
Switch to preset loaded in the preset Bank 2 slot 2:
cc 0 0
pc 13
# Re-calling snapshots
When the controller has Bank Select set anywhere between 1 and 12, the Program Change messages recall the saved snapshots. For each bank, up to 36 saved snapshots can be recalled by sending a Program Change number 1 to 36.
Load Snapshot 3-04, ie. bank 3 slot 4:
cc 0 3
pc 4
