#Running Status
What Is Running Status?
Running Status is a feature of MIDI that allows repeated messages of the same type and channel to be sent without repeating the status byte every time.
In short:
If multiple MIDI messages in a row have the same status byte, the status byte can be sent once and then omitted until it changes.
This reduces the amount of data that needs to be transmitted.
Why Running Status Exists
MIDI was designed in the early 1980s, when:
- bandwidth was very limited
- messages had to be sent in real time
- efficiency mattered
By removing repeated status bytes, MIDI can:
- send data faster
- reduce congestion
- improve timing accuracy
This is especially important for streams of notes or controller movements.
Normal MIDI Message Transmission
Without running status, each Note On message looks like this:
Status Data Data
0x90 60 100
0x90 62 100
0x90 64 100Each note repeats the same status byte (0x90).
MIDI with Running Status
With running status, the status byte is sent once, then omitted:
0x90 60 100
62 100
64 100The receiver remembers the last status byte and applies it to subsequent data bytes.
What “Status” Means Here
The “status” includes:
- message type (e.g. Note On)
- channel number
- 0x90 = Note On, Channel 1
- 0x91 = Note On, Channel 2
Running status only works as long as both stay the same.
When Running Status Ends
Running status is cancelled immediately when:
- a new status byte is received
- a System Common or System Real-Time message appears
- a SysEx message starts (0xF0)
After that, the next message must send a new status byte.
Running Status with Different Message Types
Running status works with channel voice messages, such as:
- Note On
- Note Off
- Control Change
- Program Change
- Aftertouch
- Pitch Bend
It does not apply to:
- System Exclusive
- System Common messages
Example with Control Change
Without running status:
0xB0 7 100
0xB0 7 90
0xB0 7 80With running status:
0xB0 7 100
7 90
7 80This is common when moving a knob or slider.
System Real-Time Messages and Running Status
System Real-Time messages (like MIDI Clock 0xF8) are special. They:
- can appear between data bytes
- do not cancel running status
0x90 60 100
0xF8
62 100Summary
Running status is a MIDI optimization that allows repeated messages of the same type and channel to omit the status byte. The receiver remembers the last status and applies it to subsequent data bytes. This reduces bandwidth usage and improves timing. While most APIs hide this detail, understanding running status is essential for working with raw MIDI data and interpreting MIDI streams correctly.
