RPN and NRPN (Registered and Non-Registered Parameter Numbers)
Why RPN and NRPN Exist
Standard Control Change messages are limited:
- only 128 controller numbers
- many already have fixed meanings
- not enough for complex instruments
RPN and NRPN provide a way to control many more parameters, including:
- pitch bend range
- tuning
- vibrato depth
- manufacturer-specific parameters
They do this by turning CC messages into a parameter selection + value system.
Key Idea: “Select a Parameter, Then Set Its Value”
RPN and NRPN work in two steps:
- Select which parameter you want to control
- Send the value for that parameter
This is very similar to:
“Choose a knob, then turn it”
What RPN and NRPN Mean
- RPN — Registered Parameter Number Standardized parameters defined by the MIDI specification
- NRPN — Non-Registered Parameter Number Manufacturer-defined parameters (device-specific)
Both use the same mechanism, only the parameter meaning differs.
How Parameters Are Selected
RPN:
| Purpose | CC | Role |
| RPN MSB | 101 | Parameter MSB |
| RPN LSB | 100 | Parameter LSB |
NRPN:
| NRPN MSB | 99 | Parameter MSB |
| NRPN LSB | 98 | Parameter LSB |
These CCs select which parameter will receive the value.
How Values Are Sent
Once a parameter is selected, its value is sent using Data Entry CCs:
| CC | Purpose |
| 6 | Data Entry MSB |
| 38 | Data Entry LSB (optional) |
This gives you 7-bit or 14-bit resolution, just like high-resolution CC.
Complete RPN Message Flow (Example)
Example: Pitch Bend Range
Pitch Bend Range is a standard RPN.
Parameter number:
- MSB = 0
- LSB = 0
Step 1: Select the RPN
CC 101 = 0
CC 100 = 0Step 2: Send the Value
CC 6 = 2This sets pitch bend range to ±2 semitones.
Complete NRPN Message Flow (Example)
NRPN works exactly the same, but with different CCs.
Step 1: Select the NRPN
CC 99 = <MSB>
CC 98 = <LSB>Step 2: Send the Value
CC 6 = <MSB>
CC 38 = <LSB> (optional)14-bit Values with RPN / NRPN
Just like 14-bit CC:
- CC 6 → coarse value
- CC 38 → fine value Combined as:
value = MSB * 128 + LSBWhy This Is Powerful
RPN and NRPN allow:
- thousands of parameters
- high-resolution values
- backward compatibility
- standardized control where possible
All using existing CC infrastructure.
Important: RPN and NRPN Are “Sticky”
Once selected:
- the parameter remains active
- future Data Entry messages continue to affect it
This can cause problems if not handled carefully.
RPN Reset (Very Important)
###What Is RPN Reset? RPN Reset clears the currently selected RPN parameter so that further Data Entry messages do nothing accidentally. How to Reset RPN Selection
Send:
CC 101 = 127
CC 100 = 127This means: “No RPN selected”
Why RPN Reset Is Critical
If you don’t reset:
- later CC 6 messages may change the wrong parameter
- bugs can appear far from their cause
- behavior becomes unpredictable
Best practice:
- Always reset RPN after setting a value.
NRPN Reset
NRPN has a similar reset:
CC 99 = 127
CC 98 = 127Summary
RPN and NRPN extend MIDI Control Change by introducing a parameter-selection mechanism followed by Data Entry messages. RPN parameters are standardized, while NRPN parameters are device-specific. Both support high-resolution values and require careful handling, including resetting the selected parameter after use. Mastering RPN and NRPN is essential for advanced MIDI control.
