System Exclusive (SysEx) Messages
System Exclusive (SysEx) messages are a special type of MIDI message that allow manufacturer-specific communication. Unlike standard MIDI messages, SysEx can carry arbitrary data, making it possible to configure devices, exchange presets and access features that standard MIDI cannot represent.
Why SysEx Exists
Standard MIDI messages are limited:
  • fixed message types
  • small number of parameters
  • predefined meanings
Manufacturers needed a way to:
  • expose advanced features
  • transfer large data blocks
  • support device-specific protocols
SysEx provides this flexibility.
Basic Structure of a SysEx Message
Every SysEx message has the same outer structure:
F0 <manufacturer ID> <data bytes...> F7
Where:
  • F0 — SysEx start
  • F7 — SysEx end
  • everything in between is manufacturer-defined
Manufacturer ID
The Manufacturer ID identifies which company the message is intended for. Examples:
  • 41 — Roland
  • 43 — Yamaha
  • 7D — Educational / non-commercial
  • 3-byte IDs for newer manufacturers
This ensures that devices ignore SysEx messages not meant for them.
Why SysEx Uses Only 7-bit Data Bytes
SysEx data bytes must be in the range:
0x00 – 0x7F
This avoids:
  • accidental interpretation as status bytes
  • interference with running status
  • parsing ambiguity
Larger values are split across multiple bytes using bit masking and shifting.
SysEx and MIDI Channels
SysEx messages are not tied to MIDI channels.
Instead:
  • they target devices, not parts
  • all devices receive them
  • devices decide whether to respond
Because of this, SysEx protocols include their own addressing.
Device IDs
Since SysEx is channel-independent, many protocols include a Device ID inside the message. Example:
F0 <manufacturer> <device ID> <command> <data> F7
Purpose of Device IDs
  • distinguish multiple devices of the same type
  • replace MIDI channel addressing
  • allow broadcast or targeted messages
Common conventions:
  • 0x7F = all devices
  • 0x00–0x0F = individual device numbers
Common SysEx Message Patterns
Although SysEx content is manufacturer-defined, most protocols follow common patterns.
Command-Based SysEx
Many SysEx messages include a command byte.
F0 <mfg> <device> <command> <data> F7
Typical commands:
  • set parameter
  • request data
  • write memory
  • read memory
Request–Response Pattern
One of the most common SysEx use cases is requesting data from a device.
Step 1: Send a Request
F0 <mfg> <device> <request command> <address> F7
This tells the device: “Please send me this data.”
Step 2: Device Sends a Response
F0 <mfg> <device> <response command> <data> F7
The response may:
  • contain parameter values
  • include checksums
  • be split into multiple messages
Why Data Is Often Requested Instead of Pushed
SysEx is often pull-based:
  • controllers ask for data
  • devices respond when ready
This avoids:
  • flooding the MIDI bus
  • sending unnecessary data
  • synchronization issues
Checksums
Many SysEx protocols include a checksum. Purpose:
  • detect transmission errors
  • validate data integrity
Checksums are usually:
  • simple sums
  • masked to 7 bits
Common SysEx Use Cases
Parameter Editing
Change a specific parameter:
F0 <mfg> <device> <set param> <param ID> <value> F7
Patch and Preset Dumps
Transfer large blocks of data:
  • single patch
  • entire bank
  • global settings
These messages may contain hundreds of bytes.
Device Configuration
  • MIDI routing
  • mode selection
  • calibration
  • system settings
Device Identification
Some devices respond to an identity request.
F0 7E <device> 06 01 F7
Response identifies:
  • manufacturer
  • model
  • version
Why SysEx Protocols Are Custom
SysEx is not standardized beyond its framing. This allows:
  • innovation
  • proprietary features
  • device-specific workflows
The downside:
  • documentation is essential
  • each device must be handled individually
System Real-Time Messages Inside SysEx
Critical Rule System Real-Time messages are allowed to appear inside SysEx messages. Example stream:
F0 43 10 4C
F8
00 01 02
F8
03 04 F7
The real-time messages: interrupt the SysEx stream must be processed immediately do not break or terminate the SysEx message After processing the real-time message, SysEx parsing resumes.
SysEx messages provide a flexible, manufacturer-specific extension to MIDI. They are framed by standard start and end bytes but contain custom data defined by each device. SysEx is channel-independent and often uses device IDs for addressing. Common patterns include command-based messages and request–response exchanges for reading and writing data. SysEx enables advanced control, configuration, and data transfer that is not possible with standard MIDI messages.
Made with 🩶 in the EU · © 2019–2026 Electra One
