Firmware update Electra One mkII
This document describes how to update your Electra One mkII from firmware version 3.6.1 or older to the latest release, version 4.0.0.
The firmware update procedure
1. Download the latest firmware file
Click the button below to download firmware version 4.0.0. The downloaded file will be named firmware-v4.0.0.srec.zip. Unzip it and make sure the file firmware-v4.0.0.srec is saved and ready to use.
version 4.0.0 (May 1st 2025)
2. Connect your controller to the computer
Connect your Electra One mkII controller to your computer using a USB cable. Make sure you’re using the same computer where you downloaded the firmware file. Wait for the controller to fully start up.
3. Switch to the bootloader mode
4. Enable the USB Disk option
5. Copy the update file to the boot folder
Copy the firmware-v4.0.0.srec file you downloaded in step 1 into the boot folder on the Electra One disk. This process may take a few moments to complete. Note: You may see other files already present in the boot folder — it’s perfectly fine to leave them there.
6. Restart the controller
7. Start the bootloader again
The bootloader will start, and firmware-v4.0.0 will appear in the list of available firmware images:
Firmware uploaded
8. Apply the update
Tap the blue tile labeled firmware-v4.0.0 to begin the update process.
9. Verify you are running 4.0.0
When the controller restarts, check the startup screen — it should display a message indicating that version 4.0.0 is starting.
Notes
  1. The firmware update typically takes 30 to 40 seconds. If the process takes significantly longer, it may indicate a problem. In that case, try power cycling the controller.
