Preset Lua extension
This document describes the Preset Lua Extension for the Electra One MIDI Controller firmware. The extension introduces procedural programming capabilities to Electra One presets.
Lua is a lightweight scripting language. You can find detailed information on the Official Lua site. Alternatively, you can follow our Lua Crash Course — a short tutorial designed specifically for musicians and non-programmers.
With the Electra Preset Lua extension, you can use the Lua programming language inside Electra One MIDI controllers to easily create, manage, and customize MIDI and music-related actions.
This reference describes firmware 5.0 and later. Almost everything in it is available on every model the firmware runs on — the Electra One mk2, the Mini and the mk3. Where a model differs, the difference is usually in a number the firmware reports, not in which functions exist, and it is said where it matters.
OSC is the one place where a model differs in what it can do rather than in a number: the library is there on every model, so a preset using it loads and runs anywhere, but only the mk3 has a network behind it.
A brief overview
With the Electra One Preset Lua extension, you can extend and customize your presets by adding Lua functions. It allows you to create features and behaviors that simply wouldn't be possible without it. Here are just a few examples of what you can do:
- Send and receive MIDI messages.
- Trigger Lua functions when control values change.
- Format display values.
- Modify the visibility, location, name, and color of controls.
- Create and remove controls, groups, devices, overlays and whole presets.
- Execute custom patch dump request calls.
- Craft your own SysEx parsers.
- Calculate checksums and generating custom SysEx template bytes.
- Run Lua functions based on MIDI clock and transport control.
- Create sequences of MIDI data, clock messages, and MIDI LFOs.
- Visualize MIDI data on the controller's screen, and draw controls of your own.
- Record, edit and play back captures and snapshots.
- Drive a second screen over the Electra Satellite Link.
- Send and receive Open Sound Control over the network, on the mk3.
The core idea behind this extension is to clearly separate the static data defined in the declarative JSON preset from the dynamic processing handled at runtime through Lua scripting. The JSON preset acts as the foundation, pre-loading all pages, lists, devices, groups, and controls. Once the preset is loaded, the Preset Lua extension takes over, allowing you to manipulate these objects for specific purposes.
A script is not limited to what the preset file already holds: controls.create(), groups.create(), devices.create(), overlays.create() and presets.create() build new objects, and there are remove counterparts for them. A preset can even edit and save itself. Starting from a declarative preset is still the easier way to work — a control described in the file needs no code at all — but it is a starting point rather than a boundary.
The Lua environment
Each preset slot gets a Lua state of its own. The scripts of two presets never see each other's variables, and a preset running pinned in the background keeps its own state and its own memory.
Lua 5.4, built with 32-bit numbers (LUA_32BITS). An integer holds -2,147,483,648 to 2,147,483,647 exactly. A number with a fraction is a single-precision float, which carries about seven significant digits — so arithmetic that goes through a float stops being exact above 16,777,216, and a count of milliseconds kept as one loses whole milliseconds after about five hours.
Everything the firmware hands a script that is conceptually whole — a MIDI value, a control id, a page number, a constant, a millisecond count — arrives as an integer, so it prints without a trailing .0, can be used as a table key, and can be passed straight back to a function that insists on a whole number.
The standard libraries that are open:
| Library | |
| base | print, type, pairs, ipairs, tonumber, tostring, pcall, error, assert, select, setmetatable, dofile, loadfile, load |
package | require, and package.path - the search path it uses |
coroutine | |
table | |
string | including string.format, string.pack and patterns |
math | |
debug |
io, os and utf8 are not open. There is no io.write, no os.time and no os.clock; use print() or logger.write() for output, and controller.uptime() or controller.micros() for time.
print() does not write to a console — it sends the text to the Electra One log, prefixed with lua:. See Logger.
A script can be split over several files. require "name" looks in the preset's own slot directory first and then in the shared Lua directory on the card:
package.path = "/ctrlv2/slots/bNN/pNN/?.lua;/ctrlv2/lua/?.lua"so require "helpers" finds /ctrlv2/slots/b00/p03/helpers.lua for the preset in bank 0 slot 3, or /ctrlv2/lua/helpers.lua for a module shared by every preset. Compiled C modules cannot be loaded. Uploading several files to one preset is covered by the file transfer and management protocol.
Uploading the scripts
To enable Preset Lua extension functions within a preset, you must first upload a Lua script file(s). The uploaded script is then associated with the currently active preset. If a Lua script already exists for that preset, uploading a new one will overwrite it.
Uploading a script ends the state that was running — preset.onExit() is called — and starts the preset again with the new script.
Normally, each preset uses a single Lua script. If needed, you can upload multiple Lua script files that work together as one larger Lua project.
This document covers the single-file setup. Multi-file configurations are explained in a separate guide about Electra One’s file transfer and management protocol.
Uploading the scripts with the Preset Editor
You can create, edit, and upload Lua scripts directly from the Preset editor — the easiest and recommended way to work with Lua. If needed, you can also upload scripts to the Electra One MIDI Controller using a SysEx call.
Uploading the scripts with a SysEx call
0xF0 0x00 0x21 0x45 0x01 0x0C script-source-code 0xF7Executing a Lua command with a SysEx call
This is a call that executes arbitrary Lua commands, effectively serving as an API endpoint for controlling Electra One presets from external devices and applications.
It allows you to remotely manage Electra One presets using Lua commands, offering a powerful way to interact with the controller from external sources.
The command runs in the Lua state of the preset on the screen, on the application thread, a moment after it arrives — it is queued like every other instruction from a host, not run inside the MIDI handler. A controller with no script on the screen writes a line to the log and does nothing.
Commands of 64 bytes or fewer are executed significantly faster than longer ones: a short command is carried inside the queued instruction, and a longer one has to be copied to memory of its own first.
To optimize performance, it is better to use this SysEx call to trigger Lua functions defined in a previously uploaded Lua script, rather than sending large blocks of arbitrary Lua code.
0xF0 0x00 0x21 0x45 0x08 0x0D lua-command-text 0xF7lua-command-text is a free-form string that holds the Lua command to be executed.
An example of the lua-command-text
print ("Hello MIDI world!")The structure of the script
The Electra One Preset Lua Extension script is organized into four distinct building blocks:
- The Setup Section: This section is where you initialize and configure the settings and parameters needed for your script. It acts as the starting point for your script’s execution and often includes setup tasks like defining global variables, establishing MIDI connections, or configuring other necessary resources.
- The Standard Functions: These are predefined functions included in the Electra One Preset Lua Extension scripting environment. They provide the core functionality for interacting with the MIDI controller and its features. Standard functions can be used to send and receive MIDI messages, manipulate controls, and manage various aspects of the controller's behavior.
- The Standard Callbacks: Electra One provides a set of standard callback functions that allow your Lua script to respond to various events. These callbacks are invoked automatically by the system when specific events occur. For example, you can use callbacks to react to control value changes or button presses, adding dynamic and interactive behavior to your script.
- The User Functions: These are custom functions that you define to extend the functionality of your Lua script. User functions allow you to implement unique behaviors, process data, and create specific responses to tailor the script to your needs. They give you the flexibility to customize the Electra One experience according to your requirements.
Once you understand and use these four building blocks, you’ll be able to create powerful Lua scripts that make your Electra One MIDI controller even more capable and flexible.
Let's use the following example to demonstrate it. It shows one group of controls at a time, chosen by the value of another control. The preset it belongs to has controls 20, 21, 22, 26, 27, 28, 32 and 33, and a control whose value names displayGroup as its Lua function.
-- Display controls related to specific value of another control
-- define assignment of controls to groups
controlGroups = {
[0] = { 20, 21, 22 },
[1] = { 26, 27, 28 },
[2] = { 32, 33 }
-- a function to hide all controls within the groups
function hideAllGroups(groups)
for groupId = 0, #groups do
for _, controlId in ipairs(groups[groupId]) do
local control = controls.get(controlId)
control:setVisible(false)
-- show given control group, laid out from the second slot of the page
function showGroup(groups, groupId)
for i, controlId in ipairs(groups[groupId]) do
control:setSlot(i + 1)
-- the callback function called from the preset
function displayGroup(valueObject, value)
hideAllGroups(controlGroups)
showGroup(controlGroups, value)
-- a standard callback function to handle PATCH REQUEST event
function patch.onRequest(device)
print("Requesting patches from device " .. device.id)
midi.sendProgramChange(PORT_1, device.channel, 10)
-- set the initial state. group 0 is displayed
function preset.onReady()
showGroup(controlGroups, 0)
print("Lua ext initialized")Two things in it are worth pointing out, because they are the two mistakes that are easiest to make:
controls.get()raises an error when the preset has no control with that id. The ids above have to exist in the preset file.<control>:setSlot()moves a control and makes it visible, which is what makeshideAllGroups()followed byshowGroup()work.
The setup
The setup section includes all source code that exists outside of any specific function and runs in the global context of the script. In this section, you can perform various tasks such as calling standard functions, executing user-defined functions, initializing global variables, and setting up resources.
Below is an example of a typical setup section from a script:
controlGroups = {
[2] = { 32, 33 }
print("Lua ext initialized")The primary purpose of the setup section is to prepare your extension to handle application events later on. It is executed immediately after the preset is loaded.
The location of the setup code within the script does not affect its functionality — it does not have to be placed at the top. However, if you plan to call your own user-defined functions in the setup section, it’s recommended to either place the setup code after the function definitions or move it into the preset.onLoad() or preset.onReady() functions for better script organization. For more details, see the Preset Initialization section below.
There is one thing the setup section must do rather than may: any midi.onX callback has to be defined by the time the main chunk ends. Those callbacks are registered the moment the chunk returns, and one defined later — in onLoad(), in a timer, in another callback — is never registered and never runs.
The standard functions
Standard functions include functions from both the Lua standard libraries and the Electra One Extension libraries. They cover a wide range of tasks, such as printing messages, performing mathematical operations, sending and receiving MIDI messages, and interacting with user interface (UI) components.
You can find detailed descriptions of the Lua standard functions in the official Lua documentation, and descriptions of Electra-specific functions in the API reference at the end of this page.
As an example, the print function is a typical standard function you will use in your scripts:
print("Lua ext initialized")The standard callbacks
The Electra One Preset Lua Extension provides a set of predefined event handlers, often called callbacks. These callbacks are automatically triggered when specific events happen.
For example:
endIn this code snippet, the patch.onRequest function is a standard callback that responds to the 'PATCH REQUEST' event. When the event occurs, this callback runs the actions you have defined: printing a text message and sending out a Program Change MIDI message.
Standard callbacks like this allow you to customize how your Lua script reacts to different events, making your Electra One MIDI controller more interactive and adaptable.
Most of them are named on a library — preset.onLoad, midi.onControlChange, patch.onRequest, timer.onTick, pages.onChange, parameterMap.onChange. Each is described with the library it belongs to, in the topic pages listed at the end.
The user functions
As a user, you have the creative freedom to define your own functions. In fact, you are encouraged to do so — user functions are the building blocks for creating more advanced and structured elements in your Lua script.
User functions help you organize your code and extend your script’s capabilities. They let you group specific tasks or behaviors together, making your scripts more modular, easier to manage, and easier to reuse.
For example, the displayGroup function from the earlier source code example is a user-defined function that is linked to a callback hook inside the preset JSON.
endA function named by the preset JSON has to be a global function, because the firmware looks it up by name. The local function form is for helpers the script calls itself.
Preset initialization
Some presets may require a carefully controlled sequence of actions during startup. The Electra One Preset Lua Extension gives you ways to run your own functions at different stages of the preset loading process. It’s important to understand the order in which these stages happen.
When a preset is read into a slot — at power on, or when you switch to a preset that is not already in memory — the following steps take place:
- The preset file is read. Pages, devices, overlays, groups and controls are built, and every control value registers its parameter map entry, so the values are in place before any script runs.
- Everything in the global context of your Lua script (outside of any function) is executed.
- The
midi.*callbacks the script defined are registered. preset.onLoad()is called, if defined.- The parameter map makes its first pass: every Lua function linked to a control value is called with the value the map holds for it.
preset.onReady()is called, if defined.preset.onEnter()is called, if defined.
Switching back to a preset that is already in memory does not repeat any of that: only preset.onEnter() runs again. preset.onLeave() runs on the preset being left, and preset.onExit() when its Lua state is closed.
Which one to use
preset.onLoad() runs before any value has been dispatched, so it can neither read a value usefully nor set one: the pass that follows calls every value's function with the value the parameter map holds, so whatever onLoad set is overwritten before it can be seen. preset.onReady() runs after that pass, when every value function and formatter has run and the preset is in a known state — it is the right place for almost all start-up work.
The Presets and Events page describes the five lifecycle callbacks in full, including what happens to timers, MIDI callbacks and pinned presets at each step.
Threads and timing
Almost all of a preset's Lua runs on one thread — the application thread — and only one piece of a preset's script runs at a time. A preset's Lua state is held by a lock, so a timer tick cannot interrupt a MIDI callback half way through, and a script never has to guard its own variables.
| Runs on | |
| Application thread | the main chunk and the lifecycle callbacks; every midi.* callback; timer.onTick; scheduled functions; transport callbacks; value functions and formatters; control event callbacks; touch, knob and switch callbacks of a custom control; data pipe subscriptions; router events; the execute-command SysEx |
| Display thread | a custom control's paint callback, and nothing else |
The one consequence to keep in mind: long work blocks the screen and the preset. While a timer tick or a MIDI callback is running, the preset's paint callbacks cannot take the lock. A paint that cannot take it within 20 ms gives up the frame and the control keeps the picture it had, so a script that computes for tens of milliseconds at a time shows as a screen that will not follow the knobs.
The rules that follow from it:
- Do a little work often rather than a lot of work at once. A
timerat 50 Hz that does a millisecond of work each tick costs nothing visible; one that does 50 ms every second is seen. - Do not use
helpers.delay()to wait. It holds the lock for its whole length. Useschedule.after()ormidi.at()instead — both let the script return. - Keep paint callbacks to drawing. Compute what to draw elsewhere, store it, and let the paint function put it on the screen.
- Anything a script does while the display thread is waiting is delaying the display thread, and the display thread is what makes the instrument feel responsive.
Errors and limits
An error in a Lua script never takes the controller down. Every entry point is protected: the error is written to the log and the callback is abandoned. The rest of the preset keeps running.
The script did not load. A syntax error, or an error raised by the main chunk, leaves the preset with no script at all — a preset that looks like it works and does nothing. The controller says so in the bar at the bottom of the screen, as Lua: <the message>, and writes the whole message to the log.
A callback raised an error. The line goes to the log with the name of the function that failed. The logger is off by default for the controller's own messages, but never for a script's, so print() and logger.write() always come out; for everything else, turn the log on in the Electra One web application while writing a preset.
A callback that will not end. timer.onTick and a scheduled function are watched: one that runs for more than ten seconds is stopped where it is. The timer is disabled, or the whole schedule is cleared, the bar says Preset N timer stopped: it ran past the ten second limit, and the log says what to do — fix the function and call timer.enable() or schedule it again.
A script the controller cannot get out of. Holding all six main buttons together for two seconds stops every preset timer and clears every schedule. It is the way out of a while true do end when the host is not answering: the grip is read by a thread that keeps running even when the application thread does not.
Memory. Each preset's Lua state has its own heap, and controller.memory() reports how much of it the script is using. A preset that stops working as it grows has usually run out; the usual causes are a table that is appended to and never trimmed, and a callback that builds a new table every time it runs.
Ranges. Arguments are checked. A MIDI value outside 0 to 16383, a control id that does not exist, a port that is not 0 to 2, a face or size a font does not have: all of them raise an error naming the argument, rather than sending or drawing something arbitrary. Where a value is silently clamped instead, the function's own description says so.
Keeping data between sessions
A preset can write a Lua table to its own file on the card and read it back the next time it is loaded — persist(table) and recall(table), or persistJson() and recallJson() for the same file as text. One file per preset slot, written when the script asks and not otherwise. See System.
Preset Lua Extension API Reference
Interfaces and ports
Every MIDI message the controller sends goes to an interface and a port.
An interface is a socket, or the set of all of them:
| Constant | Value | What it is |
MIDI_IO | 0 | the DIN sockets |
USB_DEV | 1 | the USB device socket, the one a computer is plugged into |
USB_HOST | 2 | the USB host socket, the one instruments are plugged into |
ALL_INTERFACES | 3 | all three of the above |
CAPTURE | 5 | not a socket - see below |
A port is a cable within an interface:
| Constant | Value |
PORT_1 | 0 |
PORT_2 | 1 |
PORT_CTRL | 2 |
PORT_CTRL is the cable the Electra One uses for its own control traffic. It is accepted by every send function, but a preset that sends musical data there is talking over the editor.
CAPTURE is not a socket. It is the capture the script has open for writing: a send addressed to it is written into that capture's track at the write position instead of going out. It is deliberately not part of ALL_INTERFACES, so sending to every interface never writes to a file.
The interface argument is optional
Every send function takes the interface as an optional first argument. Left out, the message goes to ALL_INTERFACES:
midi.sendNoteOff(PORT_1, channel, noteNumber, velocity) -- everywhere
midi.sendNoteOff(MIDI_IO, PORT_1, channel, noteNumber, velocity) -- DIN onlyThe firmware tells the two forms apart by counting the arguments, so all the other arguments have to be there. midi.sendNoteOn(PORT_1, 1, 60) is not a note on with a default velocity; it is four arguments where five are needed and the missing one is read off the stack, which produces nonsense rather than a clean error.
The functions with optional switches at the end - midi.sendNrpn() and midi.sendControlChange14Bit() - set trailing booleans and nils aside before counting, so midi.sendNrpn(PORT_1, 1, 512, 8192, true) is understood as a port and a switch. A switch written as 0 or 1 is understood too, but only when the interface is given as well; with no interface, midi.sendNrpn(PORT_1, 1, 512, 8192, 1) reads the trailing 1 as an interface and sends nothing useful. Use true and false.
Running status
A DIN output may leave out the status byte of a message when the wire already carries it. The midi.send* functions never do this - every message goes out whole. Running status is a property of a preset device, so only what a device sends, and what the router forwards, can use it.
An interface value of 4 is accepted and sends nothing at all. There is no constant for it, and nothing in a preset should use it.
Example
-- Forwards every control change that arrives on the USB host socket out of
-- the DIN sockets, and says where it came from.
local interfaceNames = {
[MIDI_IO] = "MIDI IO",
[USB_DEV] = "USB device",
[USB_HOST] = "USB host",
[CAPTURE] = "capture"
function midi.onControlChange(midiInput, channel, controllerNumber, value)
if midiInput.playback then
return -- already went out, do not send it twice
print(string.format("%s port %d: cc %d = %d",
interfaceNames[midiInput.interface] or "?",
midiInput.port + 1,
controllerNumber,
value))
if midiInput.interface == USB_HOST then
midi.sendControlChange(MIDI_IO, PORT_1, channel, controllerNumber, value)
endMIDI callbacks
MIDI callbacks handle incoming MIDI messages. The general midi.onMessage() callback is called for any incoming MIDI message; the specific callbacks are called only for their own message type.
The first parameter of every callback is midiInput, a table that says where the message came from:
midiInput = {
interface = USB_DEV, -- an integer, one of the interface constants
port = 0, -- an integer, 0 for PORT_1
playback = true -- present only for a message a capture played
}interface and port are numbers, not names.
A capture that plays hands what it sends back to the presets, as if the socket it went to had answered with it - see What a playing capture tells the presets. Those messages reach the same callbacks as received MIDI, and their midiInput carries playback = true, with interface and port naming where the capture sent them. For received MIDI the field is absent, so the table is exactly what it always was. A script that passes on what it hears should leave playback out, because it has already gone out:
return
midi.sendControlChange(PORT_2, channel, controllerNumber, value)
endThe transport callbacks - transport.onClock(), onStart(), onStop() and onContinue() - are not called for playback: the transport follows the clock that arrives, not a capture playing one back. They are also the only callbacks the controller's own internal clock reaches; midi.onClock() is about what comes in on a wire. A transport callback that is told about the internal clock gets { internal = true } in place of the usual midiInput table, with no interface and no port.
The second key structure is midiMessage, which midi.onMessage() is given. It carries one MIDI message broken down into its parts, and is described under MIDI data structures.
When callbacks run
A message arrives on the MIDI thread, and its Lua callbacks are queued and run later on the application thread - the same thread that builds pages, paints the display and runs every other preset's script. This matters:
- A callback runs within a millisecond or two of the message arriving, but tens of milliseconds later while a page is being built. Nothing a callback sends is precisely timed.
midi.at()is the way to send on time; see Sending at a precise time. - A callback that takes a long time delays the display and every other callback. Never call anything blocking from one.
- Errors raised in a callback are written to the log and the message is dropped. They do not stop the preset.
Callbacks are registered when the preset is loaded: immediately after the script's main chunk has run and before preset.onLoad(). The firmware looks for them by name at that moment and never again, so a midi.onNoteOn assigned later - in onLoad(), in a timer, from lua exec - is never called. Define every callback at the top level of the script.
Every loaded preset gets its callbacks, not only the one on screen: a pinned preset in the background keeps receiving MIDI.
Registering a callback costs work on every matching message, so do not define empty callback functions.
The callback queue
Messages waiting for their callbacks sit in a queue 128 deep. Each pass of the application thread runs at least 16 of them, and goes on draining up to 64 for as long as a 500 microsecond budget lasts. SysEx is carried separately, in a ring of 16 messages; a block is copied before the script sees it, so a script may take as long as it likes over it.
When the queue is full the message is dropped and counted. A preset that sheds callbacks is doing too much work in them.
A script that wants to know whether it is keeping up reads it twice and compares.
Returns
Firing order
One incoming control change can run several callbacks, always in this order:
midi.onControlChange()midi.onNrpn()ormidi.onRpn(), if the run is completemidi.onControlChange14Bit(), if the pair is completemidi.onMessage()
For a SysEx message it is midi.onSysex() and then midi.onMessage(). For everything else the specific callback runs first and midi.onMessage() last.
Functions
It is not called for the controller's own internal clock. For a SysEx message the table holds only type and sysexBlock.
Parameters
A Note On with velocity 0 is reported here, not as a Note Off. Instruments that use it as a note off are common, so a script that tracks held notes must test for it.
Parameters
Parameters
Every control change is reported here, including the ones that make up an NRPN, an RPN or a 14-bit control change.
Parameters
An NRPN is not a message on the wire - it is a run of ordinary control changes (CC 99, CC 98, CC 6 and optionally CC 38), and the controller assembles it. midi.onControlChange() still reports each of those individually; this reports what they add up to.
Many instruments send only the coarse form and never a data entry LSB, so the callback runs as soon as CC 6 arrives, with is14Bit false. Where the LSB does follow, the callback runs again with the full fourteen bits and is14Bit true.
The run is assembled per source - interface, port and channel - so two instruments sending NRPNs at the same time do not confuse each other.
A repeated CC 6 reuses the last LSB
Once a data entry LSB has been seen for a parameter, a further CC 6 on its own is reported with is14Bit true and that old LSB. An instrument that sends coarse-only changes after a fine one therefore reports values that are fourteen bits wide but whose bottom seven bits are stale.
Parameters
The is14Bit note on midi.onNrpn() applies here too.
Parameters
The two halves do not have to arrive back to back: each of controllers 0 to 31 remembers the MSB it last had, so interleaved pairs are assembled correctly. An LSB on its own is a fine adjustment and is reported with the MSB its controller already has - so a controller can report a value before its MSB has ever changed again.
midi.onControlChange() still reports both halves individually.
Parameters
One control change can be two composite messages
CC 6 and CC 38 are the RPN/NRPN data entry pair, and they are also a 14-bit CC pair. A preset with both midi.onNrpn and midi.onControlChange14Bit is told about both rather than one of them silently winning.
Parameters
Parameters
Parameters
The value is signed and centred on 0, which is the same number midi.sendPitchBend() takes. midi.onMessage() reports the same message unsigned, as the raw 0 to 16383.
Parameters
Parameters
Parameters
Only clocks that arrive on a socket reach this callback. The controller's own internal clock reaches transport.onClock() instead.
At 120 BPM this runs 48 times a second, on the application thread, for every preset that defines it. Keep it very short, or follow the clock with transport instead.
Parameters
Parameters
Parameters
Parameters
An instrument that sends Active Sensing sends it about three times a second while it is idle, and it is not filtered out on the way here.
Parameters
Parameters
Parameters
The block is valid only while the callback runs. Keeping a reference to it and reading it later gives whatever has since been written over it - read what is needed, or copy it out with sysexBlock:getBytes(), before returning.
SysEx addressed to the Electra One itself - the messages whose manufacturer id is 00 21 45 - is handled by the controller and never reaches this callback or midi.onMessage().
There is no length limit a preset needs to worry about: a message of up to 128 kB reaches the script whole.
Parameters
Time Code Quarter Frame
TIME_CODE_QUARTER_FRAME (0xF1) has no callback of its own. It reaches midi.onMessage() like any other message, but midi.sendMessage() cannot send it back out.
Receiving only the SysEx you want
A script that handles one device's SysEx usually starts midi.onSysex() by checking the first few bytes and returning when they do not match. Name those bytes with midi.setSysexHeaders() instead, and the controller does the check itself. A SysEx that matches none of the headers never reaches the script, and is not even copied for it, so a busy MIDI bus costs the preset nothing.
A header is written like the bytes of a SysEx template:
- the bytes that follow the
F0, as numbers or hex strings (0x43or'43') - a leading
'F0'is allowed and ignored, so a header can be copied off a template midi.ANYmatches any byte in its position, such as a device ID or a channel nibble
A preset can set up to 8 headers of up to 16 bytes each. A byte over 127, an empty header or too many headers raises an error, and the headers set before the call stay in place.
Until a preset calls midi.setSysexHeaders(), midi.onSysex() is given every SysEx, as it always was. The headers apply to midi.onSysex() only: midi.onMessage() is still given every SysEx. They stay with the preset while it is pinned or left and returned to, and a new script starts without them.
Parameters
Returns
midi.ANY is the template element { type = "any" }. It means the same thing in a header and in a device message template, so device:setMessage(id, { 'F0', 0x43, midi.ANY, 0x00 }, 'in') works as well.
Example
-- Yamaha parameter changes on any device channel (0x10 to 0x1F), and Roland
-- DT1 data sets from any device ID. Nothing else reaches the callback.
midi.setSysexHeaders({
{ 0x43, midi.ANY },
{ 0x41, midi.ANY, 0x00, 0x00, 0x6A, 0x12 },
function midi.onSysex(midiInput, sysexBlock)
if sysexBlock:peek(2) == 0x43 then
-- a Yamaha message
else
-- a Roland DT1
endExample 1
-- Receiving MIDI messages with the generic midi.onMessage() callback
function midi.onMessage(midiInput, midiMessage)
if midiMessage.type == SYSEX then
print("sysex message received: interface=" .. midiInput.interface)
local sysexBlock = midiMessage.sysexBlock
print(sysexBlock:toHex())
else
-- the generic approach, using data1 and data2
print("midi message received: interface=" .. midiInput.interface ..
" channel=" .. midiMessage.channel ..
" type=" .. midiMessage.type ..
" data1=" .. midiMessage.data1 ..
" data2=" .. midiMessage.data2)
-- message type specific attributes
if midiMessage.type == NOTE_ON then
print("noteOn received: channel=" .. midiMessage.channel ..
" noteNumber=" .. midiMessage.noteNumber ..
" velocity=" .. midiMessage.velocity)
endExample 2
-- A complete monitor preset: every callback the firmware calls, and the
-- dropped-callback count once a second.
print("controlChange: channel=" .. channel ..
" controllerNumber=" .. controllerNumber .. " value=" .. value)
function midi.onNoteOn(midiInput, channel, noteNumber, velocity)
print("noteOn: channel=" .. channel ..
" noteNumber=" .. noteNumber .. " velocity=" .. velocity)
function midi.onNoteOff(midiInput, channel, noteNumber, velocity)
print("noteOff: channel=" .. channel ..
function midi.onAfterTouchPoly(midiInput, channel, noteNumber, pressure)
print("afterTouchPoly: channel=" .. channel ..
" noteNumber=" .. noteNumber .. " pressure=" .. pressure)
function midi.onAfterTouchChannel(midiInput, channel, pressure)
print("afterTouchChannel: channel=" .. channel .. " pressure=" .. pressure)
function midi.onProgramChange(midiInput, channel, programNumber)
print("programChange: channel=" .. channel ..
" programNumber=" .. programNumber)
function midi.onPitchBend(midiInput, channel, value)
print("pitchBend: channel=" .. channel .. " value=" .. value)
function midi.onNrpn(midiInput, channel, parameterNumber, value, is14Bit)
print("nrpn: channel=" .. channel ..
" parameterNumber=" .. parameterNumber ..
" value=" .. value .. " is14Bit=" .. tostring(is14Bit))
function midi.onRpn(midiInput, channel, parameterNumber, value, is14Bit)
print("rpn: channel=" .. channel ..
function midi.onControlChange14Bit(midiInput, channel, controllerNumber, value)
print("cc14: channel=" .. channel ..
function midi.onSongSelect(midiInput, songNumber)
print("songSelect: songNumber=" .. songNumber)
function midi.onSongPosition(midiInput, position)
print("songPosition: position=" .. position)
function midi.onStart(midiInput)
print("start")
function midi.onStop(midiInput)
print("stop")
function midi.onContinue(midiInput)
print("continue")
function midi.onSystemReset(midiInput)
print("system reset")
function midi.onTuneRequest(midiInput)
print("tune request")
print("sysex, " .. sysexBlock:getLength() .. " bytes: " ..
sysexBlock:toHex(1, 8) .. " ...")
-- midi.onClock and midi.onActiveSensing are left undefined on purpose: they
-- arrive dozens of times a second and registering them costs work on each.
local lastDropped = midi.getDroppedCallbacks()
function timer.onTick()
local dropped = midi.getDroppedCallbacks()
if dropped ~= lastDropped then
print("dropped " .. (dropped - lastDropped) .. " callbacks")
lastDropped = dropped
timer.setPeriod(1000)
timer.enable()MIDI functions
The MIDI library sends raw MIDI messages. There are two ways to send: compose a midiMessage table and pass it to midi.sendMessage(), or call the function for the message type, such as midi.sendNoteOn().
Every one of them takes an optional leading interface argument, described under Interfaces and ports. None of them returns anything.
An argument outside its range raises an error. The ranges are: channel 1 to 16, seven-bit values 0 to 127, fourteen-bit values 0 to 16383, pitch bend -8192 to 8191, port 0 to 2, interface 0 to 5.
The messages leave through the output queues as soon as the script sends them, unless midi.at() is holding them back.
Functions
The prototypes below write the optional leading interface as [interface, ]. Left out, the message goes to every interface.
It takes what midi.onMessage() gives, including SysEx, which arrives as a sysexBlock field. So forwarding everything that reaches one interface out of another is one line:
midi.sendMessage(USB_HOST, PORT_1, midiMessage)
endA hand written pitch bend carries value as the signed amount the wheel is bent by, -8192 to 8191. A received one carries the raw data1 and data2 bytes as well, and those win where they are present - which is what makes the round trip exact rather than an octave out.
Two things do not round trip. TIME_CODE_QUARTER_FRAME raises type is not supported, so a forwarder that may see one has to skip it. And NRPN, RPN and 14-bit control changes have no message type of their own; they are already reported as the plain control changes they are made of.
This function does not range-check its arguments. A value outside 0 to 127 is truncated into the MIDI packet rather than raising, so an arithmetic mistake here goes out on the wire. The dedicated functions below check everything.
Parameters
Parameters
Parameters
Parameters
Parameters
Parameters
Parameters
The channel argument is required. The value is signed and centred on 0, the same number midi.onPitchBend() reports.
Parameters
Parameters
Parameters
A clock built out of these is only as steady as the application thread, which also paints the display. To send a clock, use the controller's own clock generator - see transport - or schedule each byte with midi.at().
Parameters
Parameters
Parameters
Parameters
Parameters
Parameters
Parameters
data may be any of three things:
| a SysexBlock | sent exactly as it stands, framing included - so what midi.onSysex() or patch.onResponse() handed over can be echoed or forwarded without unpacking it |
| an array of numbers | the body; the leading 0xF0 and trailing 0xF7 are added |
| a string | the same, and what the SysexBlock run readers answer - so block:getBytes(2, 6) can go straight back out |
For the array and the string, a byte over 0x7F cannot travel inside a SysEx message and is skipped, with a line in the log. A SysexBlock is not checked; it is sent byte for byte as it was built.
Array items are read with an integer conversion, so 0x41 and 65.0 are both accepted and 65.5 raises. A value above 255 is truncated into a byte rather than raising.
A long array and a capture do not mix
An array body longer than 59 bytes is sent in chunks. The chunks go out correctly on every real interface, but only the last one is written into a CAPTURE. Build the message in a SysexBlock - or hand over a string - when it is going into a capture.
Parameters
Pass true and false for the switches, not 0 and 1 - see The interface argument is optional.
Parameters
The reset - CC 101 and CC 100 as 127 - is always sent afterwards. There is no switch for it here, and no lsbFirst.
Parameters
The name is sendControlChange14Bit, with the Bit.
controllerNumber is checked as a fourteen-bit number rather than against the 0 to 31 that a 14-bit pair needs, so a larger number is accepted and produces controller numbers that are not what was meant. Keep it within 0 to 31.
Parameters
Outbound MIDI is handed to the output queues as each message is sent, and the output threads drain them; there is nothing for a script to flush.
Example
-- Sending MIDI messages with midi.sendMessage()
-- Control Change
midi.sendMessage(PORT_1, {
channel = 1,
type = CONTROL_CHANGE,
controllerNumber = 1,
value = 127
-- Note On
channel = 1,
type = NOTE_ON,
noteNumber = 60,
velocity = 100
-- Note Off
channel = 1,
type = NOTE_OFF,
noteNumber = 60,
velocity = 0
-- Program Change
channel = 1,
type = PROGRAM_CHANGE,
programNumber = 10
-- Pitch Bend, signed and centred on 0
channel = 1,
type = PITCH_BEND,
value = 513
-- Poly Pressure
channel = 1,
type = POLY_PRESSURE,
noteNumber = 60,
pressure = 100
-- Channel Pressure
channel = 1,
type = CHANNEL_PRESSURE,
pressure = 64
-- Song Select
midi.sendMessage(PORT_1, { type = SONG_SELECT, songNumber = 20 })
-- Song Position, in MIDI beats
midi.sendMessage(PORT_1, { type = SONG_POSITION, position = 10 })
-- Messages that are only a status byte
midi.sendMessage(PORT_1, { type = CLOCK })
midi.sendMessage(PORT_1, { type = START })
midi.sendMessage(PORT_1, { type = STOP })
midi.sendMessage(PORT_1, { type = CONTINUE })
midi.sendMessage(PORT_1, { type = ACTIVE_SENSING })
midi.sendMessage(PORT_1, { type = RESET })
midi.sendMessage(PORT_1, { type = TUNE_REQUEST })Example
-- Sending MIDI messages out with the dedicated functions
print("Sending MIDI out demo loaded")
-- Control change, to every interface
midi.sendControlChange(PORT_1, 1, 10, 64)
-- Control change, to the DIN sockets only
midi.sendControlChange(MIDI_IO, PORT_1, 1, 10, 64)
-- Notes
midi.sendNoteOn(PORT_1, 1, 60, 100)
midi.sendNoteOff(PORT_1, 1, 60, 0)
-- Program change
midi.sendProgramChange(PORT_1, 1, 10)
-- Pitch bend: port, channel, value
midi.sendPitchBend(PORT_1, 1, 513)
-- Polyphonic aftertouch
midi.sendAfterTouchPoly(PORT_1, 1, 60, 100)
-- Channel aftertouch
midi.sendAfterTouchChannel(PORT_1, 1, 100)
-- NRPN, with the parameter deselected afterwards
midi.sendNrpn(PORT_1, 1, 512, 8192)
-- NRPN, LSB first and the parameter left selected
midi.sendNrpn(PORT_1, 1, 512, 8192, true, false)
-- RPN 0, pitch bend range
midi.sendRpn(PORT_1, 1, 0, 4096)
-- 14-bit control change: MSB on CC 1, LSB on CC 33
midi.sendControlChange14Bit(PORT_1, 1, 1, 2048)
-- Transport
midi.sendStart(PORT_1)
midi.sendStop(PORT_1)
midi.sendContinue(PORT_1)
midi.sendSongSelect(PORT_1, 1)
midi.sendSongPosition(PORT_1, 200)
midi.sendClock(PORT_1)
-- System
midi.sendActiveSensing(PORT_1)
midi.sendSystemReset(PORT_1)
midi.sendTuneRequest(PORT_1)
-- SysEx, from an array of body bytes: F0 43 20 00 F7 goes out
midi.sendSysex(PORT_1, { 0x43, 0x20, 0x00 })
-- SysEx, from a string
midi.sendSysex(PORT_1, string.char(0x43, 0x20, 0x00))Sending at a precise time
A script runs on the controller's application thread, which also builds pages, paints and runs every other preset's script. A note sent from a timer or a callback therefore leaves when the script gets to it - usually within a millisecond or two, but tens of milliseconds late while a page is being built. For anything that has to land on a beat, work out when it is due and hand it to midi.at(): the message is then sent by the controller's MIDI schedule thread, the highest priority thread there is, on the millisecond it names - whatever the application thread is busy with.
It applies to everything the script sends from here on - the midi.send*() functions, a device's device:send*() functions and the messages parameterMap.set() sends - until the script calls midi.at() again with a different time, or midi.at() with no time to send at once, or the callback it was called from returns. A timer tick, a MIDI callback, a control's function and a lua exec each start sending at once.
- A time already past, or the current one, sends at once.
- A time more than 10 seconds ahead raises an error.
- SysEx is never held; it is sent at once, as always.
- The schedule holds 256 messages. A message that finds it full is sent at once rather than lost - late is better than never.
- Messages due at the same millisecond go out in the order they were sent.
- The hold belongs to the calling thread, so it never affects the router or what a capture is playing.
time is on the same clock as schedule.now(). Working ahead is what makes the timing exact: a script that waits until a note is due before sending it is already late by however long its own callback took to run.
Long uptimes
Times are Lua numbers, which on the controller are 32-bit floats. Past about 4.6 hours of uptime they can no longer hold every millisecond, and scheduled times start to be quantised.
Parameters
Returns
Example
-- A note that lasts exactly one beat, and a chord arpeggiated ahead of time.
function playBeatLong(noteNumber)
local beatMs = 60000 / transport.getTempo()
midi.sendNoteOn(PORT_1, 1, noteNumber, 100) -- now
midi.at(schedule.now() + beatMs)
midi.sendNoteOff(PORT_1, 1, noteNumber, 0) -- one beat later
midi.at() -- back to now
function arpeggiate(notes, stepMs)
local start = schedule.now() + 50 -- a little ahead
for i, noteNumber in ipairs(notes) do
local on = start + (i - 1) * stepMs
midi.at(on)
midi.sendNoteOn(PORT_1, 1, noteNumber, 90)
midi.at(on + stepMs * 0.9)
midi.at()
arpeggiate({ 60, 64, 67, 72 }, 125)Bytes
The byte handling every preset that talks to a synthesizer used to write for itself: seven-bit packing, nibbles, checksums and hex. Every function takes its data as a Lua string or an array of numbers - the same rule SysexBlock follows - so a script that built a message with string.char and one that assembled it from parameters call the same thing. Every function returns an array of numbers, except toHex, which returns a string, toString, which is the other way round, and checksum, which returns one number.
Array items must be integers in the range 0 to 255. A number with a fractional part, and a float such as the result of a division, raises item N is not a byte; use math.floor() on anything that came out of arithmetic.
None of it touches the display, a preset or MIDI, so it can be called from anywhere, including while the preset loads.
Functions
Parameters
Returns
A 0x prefix is not a prefix here
0 is a hex digit, so "0x41 0x42" parses as 04 14 2 and raises on the odd digit. Strip the prefixes, or write the bytes as plain pairs: "41 42".
Parameters
Returns
Parameters
Returns
bytes.pack7(). Parameters
Returns
Parameters
Returns
Parameters
Returns
Parameters
Returns
Parameters
Returns
Example
-- A Roland-style parameter write, assembled from the manual's hex.
-- Address 19 00 00 06, one data byte, then the checksum over both.
function sendRolandParameter(value)
local body = bytes.fromHex("19 00 00 06")
body[#body + 1] = math.floor(value)
body[#body + 1] = bytes.checksum(body)
local message = SysexBlock()
message:writeHex("F0 41 10 00 00 3B 12")
message:writeBytes(body)
message:writeHex("F7")
message:close()
midi.sendSysex(PORT_1, message)
print("sent: " .. message:toHex())
sendRolandParameter(64)
-- A sample name that arrived seven bits at a time, read out of a dump
if sysexBlock:getLength() < 26 then
return
local name = bytes.toString(bytes.unpack7(sysexBlock:getTable(10, 16)))
print("name: " .. name)
endSysexBlock
An object designed to handle SysEx messages.
In contrast to simple byte arrays, SysexBlock provides efficient tools for working with large SysEx messages, offering stream-like operations such as read, write and peek.
A block arrives in three ways: from midi.onSysex(), from patch.onResponse(), or from the global SysexBlock() constructor, which opens an empty one for writing.
Blocks a callback gave you
A block a callback handed over is valid only while that callback runs. It points into the buffer the message was assembled in, and the next SysEx message reuses it. Read what is needed, or copy it out with getBytes() or getTable(), before returning.
Blocks you build
Write the message into it - framing included, so start with F0 and end with F7 - then close() it, then send it.
Returns
SysexBlock() takes no arguments and answers an empty block. It draws its bytes from one 128 kB pool that every preset's blocks share, laid down one after another; when the pool runs past its end it starts over, so the bytes of an old block are eventually written over.
Two rules follow:
- Build one block at a time, and
close()it before starting the next. Two blocks being written at once interleave in the pool. - Do not keep a block around. Build it, send it, let it go. A block held in a global and read minutes later is reading whatever is there now.
Blocks are append-only: write(), writeBytes() and writeHex() always add to the end, whatever seek() was last told. seek() and read() move the read pointer only.
Functions
Returns
It is taken from positions 2, 3 and 4 - the bytes just after the 0xF0. When position 2 is not zero the id is one byte wide and that byte is the answer: Roland is 0x41. When position 2 is zero the id is three bytes wide and the answer is all three as one number, so Novation's 00 20 29 answers 0x2029 and the Electra One's 00 21 45 answers 0x2145.
Returns
A position of 0 or less, or past the last byte, raises an error. Writing is not affected: writes always append.
Parameters
Returns
A position of 0 or less, or past the last byte, raises an error - it does not answer -1.
Parameters
Returns
Parameters
Working a run of bytes at a time
read() and write() move one byte per Lua call. That is the whole cost of walking a patch dump: a few thousand crossings of the C boundary to look at a few thousand bytes. The functions below carry a run in one call.
A run is either a Lua string or an array of numbers, and every function that takes one accepts both. Lua strings are binary safe, so string.byte, string.sub, string.find and # all work on the bytes of a SysEx message directly. Array items must be integers, as they must for bytes.*.
Positions are one based throughout, exactly as seek() and peek() already are, and a range that runs past the end of the block is clamped rather than raising - so a loop reading in chunks simply stops.
Parameters
Returns
Parameters
Returns
Parameters
Returns
Parameters
Returns
Parameters
Returns
Parameters
Returns
Only space, comma, tab, carriage return and newline separate. Any other character raises, so a 0x prefix is an error here - unlike bytes.fromHex(), which quietly misreads it.
Parameters
Returns
At the end of the block it answers getLength() + 1, which is one past the last byte and which seek() rejects. Anywhere else it is a position seek() takes as it stands.
Returns
Returns
Returns
A block that arrived through midi.onSysex() never does: those messages are handled by the controller and are not passed to presets. It is worth testing on a block built by the script itself.
Returns
Examples
Reading a patch dump without a byte at a time:
print(sysexBlock:toHex(1, 8) .. " ...")
-- The header, checked in one comparison.
if sysexBlock:getBytes(1, 4) ~= string.char(0xF0, 0x00, 0x20, 0x29) then
return
-- The payload, as numbers, from just after the header.
local data = sysexBlock:getTable(8, sysexBlock:getLength() - 8)
parameterMap.set(1, PT_CC7, 74, data[1])
endFinding a marker rather than counting to it:
local at = sysexBlock:find({ 0x00, 0x20, 0x29 })
if at then
sysexBlock:seek(at + 3)
local model = sysexBlock:readBytes(2)
print("model: " .. bytes.toHex(model, " "))
endBuilding a message from a manufacturer's documentation and sending it:
function requestPatch(patchNumber)
local request = SysexBlock()
request:writeHex("F0 00 20 29 02 0E")
request:writeBytes({ patchNumber })
request:writeHex("F7")
request:close()
midi.sendSysex(USB_HOST, PORT_1, request)
requestPatch(3)DMX
The dmx library drives a uDMX dongle plugged into the USB host socket. The dongle is claimed by its USB vendor and product id, so it takes one of the two USB host device slots that MIDI devices also use; usb-devices list reports it with "driver":"DMX".
Channels are given as 1 to 512, the way a lighting desk numbers them, and values as 0 to 255. Up to two dongles can be attached, and every function takes an optional leading device number counting the attached dongles from one - it is the dongles that are counted, not the slots, so a single dongle is always device 1 whichever slot it landed in. Left out, the device number is 1. Passing nil explicitly raises.
Nothing blocks. A write updates the universe the firmware holds for the dongle, and a sender thread hands the changed channels over on the USB control pipe. Only channels whose value actually moved are sent, and consecutive ones are coalesced into a single transfer. The dongle keeps clocking DMX512 out by itself, so a level that is not changing needs no repeating.
Every function except getDeviceCount() and isConnected() raises DMX device N is not connected when there is no such dongle. A preset that has to cope with an unplugged dongle asks dmx.isConnected() first.
A dongle being plugged in or out reaches events.onUsbHostChange(), like any other USB host device. The event does not say what kind of device it was, so a preset that reacts to one calls dmx.isConnected() to find out.
On the host build of the firmware the library is present but does nothing: getDeviceCount() answers 0 and isConnected() answers false.
Functions
Returns
Parameters
Returns
Parameters
An empty array does nothing. A run that would pass channel 512, a value out of range, or an item that is not a number, each raise.
Parameters
Parameters
Returns
Parameters
Example
-- A seven channel RGB fixture patched at DMX channel 1, driven from four
-- controls on the first control set. The fixture's channels are:
-- 1 dimmer, 2 red, 3 green, 4 blue, 5 strobe, 6 mode, 7 speed
local base = 1
local level = { dimmer = 0, red = 0, green = 0, blue = 0 }
local function push()
if not dmx.isConnected() then
return
dmx.setChannels(base, {
level.dimmer, level.red, level.green, level.blue, 0, 0, 0
-- Value functions named in the preset JSON, one per control.
function setDimmer(valueObject, value)
level.dimmer = math.floor(value)
push()
function setRed(valueObject, value)
level.red = math.floor(value)
push()
function setGreen(valueObject, value)
level.green = math.floor(value)
push()
function setBlue(valueObject, value)
level.blue = math.floor(value)
push()
print("DMX dongles attached: " .. dmx.getDeviceCount())
push()
-- Leave the rig dark when the preset is switched away from.
function preset.onLeave()
if dmx.isConnected() then
dmx.blackout()
endOSC
The osc library sends and receives Open Sound Control over the network. It is how a preset talks to a DAW, a light desk, a media server or another controller in that receiver's own terms rather than in MIDI.
Electra One mk3 only
OSC needs a network, and the mk3 is the model that has one. The library itself is there on every model, so a preset that uses it still loads and runs on an mk2 or a Mini - it simply has nothing to send on. osc.isAvailable() answers false, osc.listen() answers false, and a send answers false and goes nowhere. Nothing raises, and the rest of the preset carries on.
OSC is deliberately not wired to the parameter map or to controls. A control sends one value to one place; OSC carries whatever a script wants to say, to whoever it wants to say it to, and tying the two together would limit it to the things a control can express. So this is an API beside midi.*, and what a preset does with it is the preset's business.
local desk = osc.connect("192.168.1.20", 8000)
desk:send("/mixer/volume", 0.75)
osc.listen(9000)
function osc.onMessage(message)
print(message.address, message.types, message.args[1])
endDestinations
osc.connect() names where messages go. It is not a connection in the TCP sense - OSC runs over UDP here, so nothing is opened, nothing can fail to connect, and a destination is cheap enough to build in preset.onReady() and keep in a variable for the life of the preset.
The host is a dotted quad and nothing else. There is no resolver on the controller, so a script that wants a machine by name carries its number instead of waiting on DNS in the middle of a preset.
Listening is separate from sending, and there is one listening port for the whole controller. osc.listen() binds it, a second call moves it, and osc.stop() gives it up.
What a Lua value is sent as
A plain Lua value picks its own OSC type, following Lua's own distinction between an integer and a float:
| Lua value | sent as |
1, -7 - an integer | i, int32 |
1.0, 0.5 - a float | f, float32 |
"text" | s, a string |
true, false | T, F |
nil | N |
So desk:send("/a", 1) sends an int and desk:send("/a", 1.0) sends a float. It is the same distinction Lua itself makes, and worth watching where the value has been through arithmetic that turned it into one or the other. Anything else - a table, a function - raises.
Where that is not what is meant, a wrapper says so outright. Each answers a value to be passed straight to send(); it is not a message on its own.
| Wrapper | tag | |
osc.int(number) | i | a 32-bit integer |
osc.float(number) | f | a 32-bit float |
osc.int64(number) | h | a 64-bit integer |
osc.double(number) | d | a 64-bit float |
osc.string(text) | s | a string |
osc.symbol(text) | S | a symbol - a string the receiver reads as a name |
osc.blob(bytes) | b | raw bytes, given as a Lua string, zero bytes and all |
osc.timetag(number) | t | an OSC time tag |
osc.char(character) | c | one character, as a one-character string or as its code |
osc.rgba(number) | r | a colour packed as 0xRRGGBBAA |
osc.midi(port, status, data1, data2) | m | a MIDI message; one packed integer is accepted too |
osc.infinitum() | I | the impulse, which carries no value |
osc.rgba() and the packed form of osc.midi() want all 32 bits. Written as a hex literal, 0xFF0000FF wraps to a negative Lua integer - those are the same 32 bits and they go out correctly, so it needs no masking.
32-bit numbers
A Lua integer here holds 32 bits and a Lua float is single precision, as The Lua environment describes. osc.int64() and osc.double() put the right tag on the wire, which is what a receiver that insists on one needs, but the value inside them cannot carry more than a 32-bit integer or a float32 already did. The same goes for osc.timetag(): a real NTP time tag does not fit in a Lua integer, so osc.IMMEDIATE is the one a script can usefully name.
What arrives
A datagram that reaches the listening port is decoded by the firmware and handed to osc.onMessage() as a table:
| field | |
address | string, the address pattern it was sent to |
types | string, the type tags of its arguments - "ifs" for an int, a float and a string |
args | table, the arguments counted from 1, with n |
host | string, the dotted quad it came from |
port | integer, the source port |
time | integer, its time tag |
args carries n the way table.pack() does, because nil is a type OSC can send and a script counting with # would stop at the first one.
The arguments arrive as the nearest Lua type:
| tags | arrives as |
i h c r m t | integer |
f d | number |
s S | string |
b | string, the raw bytes |
T F | boolean |
N I | nil |
Two pairs are indistinguishable once they are Lua values - a string and a symbol, a nil and an impulse - so a script that has to tell them apart reads types rather than the argument.
A bundle is unwrapped by the firmware rather than in Lua: every message in it reaches osc.onMessage() on its own, carrying the bundle's time tag. A message that did not come in a bundle carries osc.IMMEDIATE. A bundle nested more than three deep is dropped, which is what stops a made-up datagram from walking the stack down.
osc.onMessage() runs on the application thread, like every other Lua callback. An error inside it is written to the log and the preset carries on.
Limits
| the address | 96 bytes |
| arguments in one message | 32 |
| argument bytes in one message | 1024 |
| one datagram, a message or a bundle | 1400 bytes |
| bundles within bundles | 3 deep |
An address or an argument that does not fit raises. A bundle that does not fit answers false. A message that arrives over these limits is dropped before the callback, because it cannot be decoded into one.
Functions
Whether OSC can reach anything at this moment. false on a model without a network, and on the mk3 while the network is down. A preset that has something extra to offer over OSC asks this before offering it; one that just sends does not have to, because a send without a network answers false rather than raising.
Returns
Names where messages go. Nothing is opened and no network is touched, so this succeeds on every model; whether anything arrives is osc.isAvailable()'s business.
tostring() on a destination gives osc 192.168.1.20:8000.
Parameters
Returns
Starts delivering what arrives on this port to osc.onMessage(). There is one listening port for the whole controller, so a second call moves it rather than adding another. Answers false when there is no network.
Parameters
Returns
Stops listening. Nothing arrives at osc.onMessage() afterwards. Calling it when nothing was listening does nothing.
An OSC character. osc.char("A") reads better at the call site than osc.char(65); both send the same byte.
Parameters
Returns
An OSC MIDI message, which is four bytes. Each is taken as a byte, so anything above 255 is masked rather than raising.
Called with a single integer instead, that integer is used as the packed word - port << 24 | status << 16 | data1 << 8 | data2 - for a script that already has one.
Parameters
Returns
The other wrappers - osc.int(), osc.float(), osc.int64(), osc.double(), osc.string(), osc.symbol(), osc.blob(), osc.timetag(), osc.rgba() and osc.infinitum() - each take the one value the table above describes and raise when given something that is not it.
Destination
One message to this destination. Answers false when there is no network and when the message could not be put on the wire; raises when the message itself is wrong - an address too long, more arguments than fit, an argument of a type OSC cannot carry, or a destination that has been closed.
Parameters
Returns
Several messages in one datagram, sharing a time tag. A receiver that honours time tags applies them together, which is how two faders move as one rather than one after the other.
Each element is an array: the address first, its arguments after, wrapped or plain exactly as send() takes them. An element with no address raises.
Parameters
Returns
Gives up the destination. Sending on it afterwards raises, which is the point - a destination kept past the thing it belonged to is a bug worth hearing about. Closing one twice is harmless.
A script that keeps its destinations for the life of the preset never needs this.
Callbacks
Called for every OSC message that arrives on the listening port, and for every message inside a bundle that arrives there. Define it only if the preset listens; without it, what arrives is decoded and dropped.
Parameters
Constants
osc.IMMEDIATE is the time tag meaning "as soon as you can". It is what sendBundle() is given for a bundle that is not scheduled, and what a message that did not arrive in a bundle carries.
Example
-- A page of faders mirrored to a lighting desk, and the desk's own
-- messages read back.
local desk = nil
if not osc.isAvailable() then
info.setText("no network - OSC is off")
return
osc.listen(9000)
logger.write("OSC to %s", tostring(desk))
-- Called from a fader, with its value 0 .. 127.
function sendLevel(valueObject, value)
if desk == nil then
return
local channel = valueObject:getMessage():getParameterNumber()
-- 1.0 * value forces a float, which is what the desk expects.
desk:send("/dmx/" .. channel, 1.0 * value / 127)
-- The whole look in one datagram, so the desk moves everything together.
function sendLook(levels)
local bundle = {}
for channel, level in ipairs(levels) do
bundle[#bundle + 1] = { "/dmx/" .. channel, osc.float(level) }
desk:sendBundle(osc.IMMEDIATE, table.unpack(bundle))
if message.address == "/desk/cue" and message.args.n >= 1 then
info.setText("cue " .. tostring(message.args[1]))
else
logger.write("osc %s [%s] from %s:%d",
message.host, message.port)
function preset.onExit()
osc.stop()
endMIDI data structures
midiInput
midiInput is a data table that describes the origin of an incoming MIDI message.
interface- integer, one of the interface constants (see Globals).port- integer, one of the port constants (see Globals).playback- boolean, present and true only when a capture played the message back. Absent otherwise.internal- boolean, present and true only for the controller's own clock, which reaches thetransportcallbacks. Such a table has nointerfaceand noport.
Example
midiInput = {
interface = MIDI_IO, -- an integer identifying the interface
port = PORT_1 -- an integer identifying the port
}midiMessage
The midiMessage data table carries one MIDI message broken down into its parts. midi.onMessage() is given one, and midi.sendMessage() takes one.
For a channel message, channel, type, data1 and data2 are always present, along with the fields named for that message type. So a Control Change can be read either as
midiMessage = {
channel = 1,
data1 = 1,
data2 = 127
}or as
midiMessage = {
channel = 1,
value = 127
}channel- integer, the MIDI channel (1 .. 16). 0 for system messages.type- integer, the MIDI message type (see Globals).data1- integer, the first data byte (0 .. 127).data2- integer, the second data byte (0 .. 127).- the type specific attributes listed below.
A SysEx message is the exception: its table holds only type, which is SYSEX, and sysexBlock. There is no channel, data1 or data2.
Attributes specific to MIDI message types
| MIDI message type | Attributes |
NOTE_ON | noteNumbervelocity |
NOTE_OFF | noteNumbervelocity |
CONTROL_CHANGE | controllerNumbervalue |
POLY_PRESSURE | noteNumberpressure |
CHANNEL_PRESSURE | pressure |
PROGRAM_CHANGE | programNumber |
PITCH_BEND | value |
SONG_SELECT | songNumber |
SONG_POSITION | position |
SYSEX | sysexBlock |
Pitch bend is unsigned here
In a midiMessage, PITCH_BEND carries value as the raw fourteen-bit number, 0 to 16383, with 8192 in the centre. midi.onPitchBend() reports the same message as -8192 to 8191, and midi.sendPitchBend() takes that signed form. A table built by hand is read the signed way; a table that came from midi.onMessage() keeps its data1 and data2, and those are used instead, so handing one straight back to midi.sendMessage() is exact.
How a control is put together
A control is one thing on the screen: a fader, a list, a pad, an envelope. Every control belongs to one page and carries a name, a colour, a font, a variant and a rectangle on the screen.
A control has values. A fader has one, spelled value. An ADSR envelope has four - attack, decay, sustain, release - and each of them is turned by its own knob. A value is a Value object.
Every value has exactly one message: the MIDI parameter it reads and writes. A message is a Message object and carries a device, a parameter type, a parameter number and a range.
Control ──► Value ──► Message ──► parameter map entry
"CUTOFF" "value" cc7 #74 device 1, cc7, 74Display value and MIDI value
A Value works in display space. A Message works in MIDI space. Both reach the same parameter map entry, so a write through either is visible through the other.
| kind of value | what its display value is |
| proportional (faders, dials, envelopes) | the number the control shows, between the value's own min and max |
| discrete (lists) | the index of the overlay item, counted from zero - not the item's MIDI value |
| state (pads) | 0 or 1, which become the message's off and on values |
value:toMidi() and value:fromMidi() convert between the two without writing anything.
Ids
A control id is a number from 1 to 864, unique within the preset, written in the preset file and shown in the control properties panel of the Preset Editor. Groups share that id space: a group is a control of type "group", so no group and no control ever carry the same id.
A valueId is a string naming one value of one control, and it is the control type that decides which strings are valid - "value" for a fader, "attack" for an envelope. It is not a number and it is not unique across the preset.
Slots, bounds and visibility
A control is placed either in a slot - a position in the page's grid - or at bounds of its own, four numbers in screen pixels. The grid differs by model:
| mk2 | mini | |
| slots per page | 36 (6 x 6) | 12 (4 x 3, the third row being the context buttons) |
| knobs | 12 | 8 |
| pages | 12 | 16 |
| screen | 1024 x 600 | 800 x 480 |
A mini's four context buttons are pot ids 9 to 12, which a preset file may assign but control:setPot() cannot reach.
control:setSlot() moves a control into a slot and makes it visible, and gives it the knob that slot belongs to. control:getSlot() answers the slot, or nil for a control that sits at bounds of its own - which is legal, and what a hand-written preset often does.
Visibility is separate from placement: control:setVisible(false) leaves the control where it is and stops drawing it.
Controls
The controls module provides functionality to manage preset controls. It is not intended for changing properties of individual controls. Individual controls are managed by manipulating the Control object.
Every function of this module works on the preset the script belongs to, which for a preset pinned in the background is its own preset and not the one on screen. The collections have twins on the preset object - preset.getControls() and controls.getAll() are the same call - and those can be asked of another preset.
Functions
Raises when the preset has no control with that id, and when the id is outside 1 .. 864. preset.getControl(id) is the same lookup that answers nil instead.
A group is a control and is found here too, but it comes back with the Control methods on it rather than the Group ones. Use groups.get() or preset.getControl() when a group's own methods - setSlot, setHorizontalSpan, setVariant - are wanted.
The global Control(id) is the same function under another name.
Parameters
Returns
Returns
The callback is not protected: an error it raises comes out of controls.each(). Do not create or remove controls inside it.
Parameters
Returns
Parameters
Returns
Parameters
Returns
Example
-- Retrieving a reference to given control
local control = controls.get(1)-- Dim everything on page 2 that is not a group.
for _, control in ipairs(controls.getByPage(2)) do
if not control:isGroup() then
control:setColor(0x808080)
end-- Per frame, walk without allocating.
controls.each(function (control)
if control:isVisible() then
control:repaint()
end)Creating and removing controls
Firmware 5.0 and later. A control is created from a table that has the shape of the control object in the preset file: the same keys, the same spellings, the same one-based numbering. It goes through the same reader the file goes through, so every default the file gets - a fader's bipolar mode, a value's range taken from its message - is folded in here too, and what control:toTable() answers is what the file would say. See Editing a preset from Lua for the rules.
The application thread only
controls.create(), controls.remove() and <control>:update() change the preset, and that may only be done on the application thread: from onReady, from a control or MIDI callback, from a command or a patch hook. Called from a timer tick or a schedule callback they raise not on the application thread.
A preset holds at most 432 controls; one more raises. Groups are counted separately - see groups.create().
local c = controls.create {
pageId = 1, controlSetId = 1, type = "fader", name = "RESO",
color = "F49500", slot = 2,
inputs = { { potId = 2, valueId = "value" } },
values = { { id = "value", min = 0, max = 127, defaultValue = 64,
message = { deviceId = 1, type = "cc7", parameterNumber = 71,
min = 0, max = 127 } } }
}Parameters
Returns
A Control object the script kept raises the control was removed on its next method call rather than reading what is no longer there.
Parameters
Returns
Example
-- Build a page of eight CC faders, and take them away again.
local ids = {}
function buildPage()
for i = 1, 8 do
local control = controls.create {
pageId = 2, controlSetId = 1, type = "fader",
name = string.format("CC %d", 20 + i),
color = "529DEC", slot = i,
inputs = { { potId = i, valueId = "value" } },
values = { { id = "value", min = 0, max = 127, defaultValue = 0,
parameterNumber = 20 + i,
ids[#ids + 1] = control:getId()
function clearPage()
for _, id in ipairs(ids) do
controls.remove(id)
ids = {}
function onReady()
buildPage()
endControl
A Control object represents a single control, like a fader or button. It stores its own data and provides functions to read and update its properties.
One control has one object per Lua state, so a script may hang its own fields on it and find them again later:
control.lastSent = 0 -- a field of the script's own
print(controls.get(1).lastSent) --> 0A Group object does not take custom fields.
Functions
Returns
Example
-- Retrieving a control and getting its Id
local volumeControl = controls.get(10)
print("got Control with Id " .. volumeControl:getId())visible member. Hiding a control leaves it where it is: it keeps its slot, its knob and its values, and the parameter map is untouched. Parameters
Returns
Example
-- a function to toggle visibility of a control
function toggleControl(control)
control:setVisible(not control:isVisible())
endParameters
Returns
Example
-- print out a name of given control
function printName(controlId)
local control = controls.get(controlId)
print ("Name: " .. control:getName())
end"F45C51" string the preset file uses. The colour globals - `WHITE`, `RED`, `ORANGE`, `BLUE`, `GREEN`, `PURPLE` - are the six the editor offers. Parameters
Returns
Example
-- A callback function that changes color of the control
-- when its value exceeds 100
function functionCallback(valueObject, value)
local control = valueObject:getControl()
if (value > 100) then
control:setColor(0xff0000)
else
control:setColor (0xffffff)
endWhich variants a control draws depends on its type: dial and thin are a fader's, checkbox a pad's, valueOnly a fader's and a pad's, highlighted and buttonlike a group's. A variant a type does not draw is stored and ignored.
The VT_DEFAULT, VT_HIGHLIGHTED, VT_THIN, VT_VALUEONLY, VT_DIAL, VT_CHECKBOX and VT_BUTTONLIKE globals are the numbers behind the names, and are what group:setVariant() takes. A number given here is not checked.
Parameters
Returns
Parameters
Returns
<value>:overrideValue() does, reached through the control - which is usually what a script has to hand. Parameters
Returns
Returns
Parameters
Example
Filling a text box with a patch name and sending an edited one back.
-- what a patch dump handler does with what it parsed
function setPatchName(name)
controls.get(1):setOverride(name)
-- and what the user typed on the instrument, read back to send onwards
function currentPatchName()
return controls.get(1):getOverride()
-- one axis of the face at a time; the others are left alone
controls.get(1):setFont({ spacing = MONOSPACED })X, Y, WIDTH, HEIGHTglobals to access individual members of the array. The width and the height are cut so that the control ends inside 1024 x 550 - the mk2's control area - on every model. Keep x and y inside the screen the model has; a position off the screen is not corrected.
Parameters
X, Y, WIDTH, HEIGHTglobals to access individual members of the array. Returns
Example
-- print out position and dimensions of given control
local control = controls.get(2)
control:setBounds({ 200, 200, 170, 65 })
bounds = control:getBounds()
print("current bounds: " ..
"x=" .. bounds[X] ..
", y=" .. bounds[Y] ..
", width=" .. bounds[WIDTH] ..
", height=" .. bounds[HEIGHT])Only a control driven by exactly one pot can be moved this way. A control that declares no inputs, and one that declares several - an ADSR, an XY pad, a Custom control spread over the panel - is left where it is and the reason is written to the log. Rearranging those is a change to the control's inputs array, through <control>:update().
Parameters
Example
-- Reassign the control to different controlSet and pot
control:setPot(CONTROL_SET_1, POT_2)As with setPot(), only a control driven by exactly one pot is moved; anything else is logged and left alone. The page id is not checked.
Parameters
Example
-- Change location of the control within the 6x6 grid
control:setSlot(7)
-- ... or put it in the second slot of page 3
control:setSlot(2, 3)value, attack can be used as parameters for the <control>:getValue(valueId) function. The valueId is the control type's own, not a name the preset chooses: a Custom control's values all answer value, whatever the preset file calls them.
Returns
Example
-- list all value Ids of a control
local valueIds = control:getValueIds ()
for i, valueId in ipairs(valueIds) do
print(valueId)
endgetValueIds() when the type is not known in advance. A control with no values at all - a group that follows nothing - answers nil. Parameters
Returns
| control type | valueIds |
fader, list, pad, textBox, knob, relative, custom, macro | value |
adsr | attack, decay, sustain, release |
ahdsr | attack, hold, decay, sustain, release |
adssr | attack, decay, break, slope, sustain, release |
adr | attack, decay, release |
ar | attack, release |
dx7envelope | l1, r1, l2, r2, l3, r3, l4, r4 |
xypad | x, y |
vfader | f1, f2, f3, f4 |
Example
-- Display min and max display values
local value = control:getValue("attack")
print ("value min: " .. value:getMin())
print ("value max: " .. value:getMax())Returns
Example
-- list all value objects of a control
local valueObjects = control:getValues()
for i, valueObject in ipairs(valueObjects) do
print(string.format ("%s.%s", control:getName(), valueObject:getId()))
endReading what a control is
Several properties could be set and not read. These are the readers.
Returns
Returns
Returns
Returns
Returns
Returns
Returns
Bounds, by name
getBounds() and setBounds() work in a four element array indexed with the X, Y, WIDTH and HEIGHT globals, and are not going anywhere. getRect() and setRect() are the same four numbers under their own names.
Returns
Parameters
Example
-- Move it right, leaving its size and its row alone.
control:setRect({ x = 200 })
-- The same rectangle, either way round.
local bounds = control:getBounds() -- { x, y, width, height }
local rect = control:getRect() -- { x =, y =, width =, height = }
print(bounds[WIDTH] == rect.width) --> trueExample: what is under each knob
for pot = 1, 12 do
local control = preset.getControlByPot(1, 1, pot)
if control then
print(string.format("knob %d: %s (%s, slot %s)",
pot, control:getName(), control:getType(),
tostring(control:getSlot())))
endCustom control callbacks
A control of type custom has no appearance and no behaviour of its own: the script draws it and the script answers its gestures. The five functions below hand the control a Lua function for one of those jobs. They may be called on a control of any type, and only a Custom control ever runs them.
The rules they share:
- The argument must be a function.
nilraises, so a callback cannot be cleared once set; assign a function that does nothing instead. - Setting one again replaces the previous function.
- Only the preset that owns the control may set its callbacks. From another preset's script the call is written to the log and does nothing.
- The callbacks are let go when the control is removed with
controls.remove().
It should return quickly: it runs on the thread that paints the screen, and while it runs nothing else is drawn. When the Lua state is busy the frame is skipped and the control keeps the pixels it had.
controls.get(1):setPaintCallback(function (control)
graphics.setColor(control:getColor())
graphics.drawRect(0, 0, bounds[WIDTH], bounds[HEIGHT])
graphics.print(0, 20, control:getName(), bounds[WIDTH], CENTER)
end)Parameters
Parameters
The touch event table:
| field | |
type | DOWN, MOVE, UP, CLICK or DOUBLECLICK |
id | which finger, as the touch controller numbers them: the first is 0. The LCD tracks five |
x, y | where the finger is now, in pixels within the control |
touchDownX, touchDownY | where the gesture started, in the same coordinates |
Parameters
The knob event table, shared by the pot, pot touch and switch callbacks:
| field | |
type | 1 the finger arrived, or the switch closed; 2 the knob turned; 3 the finger left, or the switch opened. The same numbers the DOWN, MOVE and UP globals carry |
id | the knob, counted from zero |
valueId | the valueId the preset wrote for the input this knob arrives on, or "value" - this is what tells one knob of a twelve-knob Custom control from another |
delta | how far it turned, accelerated; negative to the left, 0 for anything but a turn |
Subscribing takes the gesture over: the control's own touch events in the preset file no longer run, and the pot callback is no longer told about touches. One gesture has one owner.
Parameters
Subscribing takes the whole gesture over, which is what lets one Custom control spread across the screen answer for twelve switches: the synthetic touch the switch stands in for does not happen, a long hold opens nothing, and the control's own switch events in the preset file do not run.
Parameters
Example
A Custom control spanning a row, drawing one bar per knob and following all four of them.
local levels = { 0, 0, 0, 0 }
function onReady()
local control = controls.get(20)
control:setPaintCallback(function (self)
local bounds = self:getBounds()
local width = bounds[WIDTH] // 4
for i = 1, 4 do
local height = levels[i] * bounds[HEIGHT] // 127
graphics.setColor(i == 1 and ORANGE or self:getColor())
graphics.fillRect((i - 1) * width + 2,
bounds[HEIGHT] - height,
width - 4,
height)
end)
control:setPotCallback(function (self, event)
if event.delta ~= 0 then
local knob = event.id + 1 -- the event counts from zero
if levels[knob] then
levels[knob] = math.max(0, math.min(127, levels[knob] + event.delta))
midi.sendControlChange(PORT_1, 1, 20 + knob, levels[knob])
self:repaint()
end)
control:setTouchCallback(function (self, event)
if event.type == CLICK then
self:repaint()
end)
endThe control as a table
c:update { name = "CUT", color = "F45C51" }
c:update { values = { { id = "value", min = 0, max = 100,
parameterNumber = 75, min = 0, max = 100 } } } }Parameters
Returns
Value
A Value object represents a single data value inside a Control. Each Value is identified by a valueId, and a Control can have one or more Values. The Value object describes the data users can change through interaction and provides functions to access and modify that data.
A Value object is reached through its control - control:getValue(valueId), control:getValues() - or through its message with message:getControlValue(). There is no constructor: the global ControlValue() exists and always raises.
Two spaces, one parameter
value:getValue() and value:setValue() are the number the control shows. message:getValue() and message:setValue() are the number on the wire.
What a display value is depends on the kind of value:
| kind | display value |
| proportional (faders, dials) | recomputed between the value's own min and max and the message's, through its sign mode and bit width, and constrained to the value's range |
Functions
Returns
Parameters
Returns
Parameters
Returns
-- One sweep of the knob moves the scroll by a tenth of its range
controls.get(215):getValue("value"):setSensitivity(0.1)Parameters
Returns
Parameters
Returns
Parameters
Returns
The two ranges are different things. The display range is what the control shows; the MIDI range is what goes on the wire. Pass true only where they are meant to be the same numbers - a display range of -64 .. 63 copied onto the message sends negative MIDI values.
Parameters
overlays.create() function. Attaching an overlay sets the value's maximum to the last index of the list, because a discrete value is an index into it.
An id the preset has no overlay for detaches whatever the value had, quietly, and getOverlayId() goes on answering the id it had before. Prefer setOverlay(), which takes the object, and clearOverlay(), which says what it means.
Parameters
Returns
Example
-- swap the overlay lists of two controls
local valueA = controls.get(1):getValue("value")
local valueB = controls.get(2):getValue("value")
local overlayA = valueA:getOverlay()
local overlayB = valueB:getOverlay()
if overlayA and overlayB then
valueA:setOverlay(overlayB)
valueB:setOverlay(overlayA)
endParameters
<value>:overrideValue() and restores the display of the current value." <value>:overrideValue(). This is what makes an edited name sendable: a script can put the text the user typed back onto the synth without keeping its own copy of it. Returns
Returns
Parameters
An override belongs to the parameter
The override is stored on the parameter the value is assigned to, not on the control. Two controls pointed at the same message therefore show the same override, and setting it through either of them changes both. This is what lets a text box show a name that a fader elsewhere in the preset is also labelled with.
Returns
Example
-- Get the message associated with the release value
local value = control:getValue("release")
local message = value:getMessage()Every method of every object here is called with a colon. value.getMessage() raises ControlValue expected, because the object itself is the first argument.
Returns
Returns
Setting and converting
A proportional value is constrained to its own minimum and maximum. A list index the overlay does not have is clamped to the nearest one it does, rather than selecting the first item.
It raises on a group's value, which is read only.
Parameters
function does not run. It is the same pair the parameter map has:
parameterMap.set() tells everything and parameterMap.updateValue() tells nothing. setValue() is a value being changed - dispatched exactly as a knob turn is - and this is a value being shown. Which is what a script putting its own state onto the knobs wants. With
setValue() it hears its own writes back through its own callbacks, and every one of them has to survive that. Clamped exactly as
setValue() is. Parameters
Parameters
Returns
Parameters
Returns
Returns
A value that declares no formatter never has one composed, and this answers an empty string rather than the number - the firmware only builds the text where a formatter asked for it. So anything showing a value to a human wants a fallback:
local text = value:getText()
if text == "" then
text = tostring(value:getValue())
endReturns
Returns
The value's maximum follows the overlay in: a discrete value is an index into the list, so its maximum becomes the last index the list has.
Parameters
The range is left where the overlay put it, because nothing recorded what it was before - a preset that wants the original range back sets it with setRange() or setMax().
An unset parameter reads as maximum
A parameter nothing has set holds MIDI_VALUE_DO_NOT_SEND (16537). That is a real value and a deliberate one - it means "there is nothing to send" - but it is not inside any parameter's range, so translating it into display space lands at the top of the range.
A control that has never been touched therefore reads as being at maximum. Ask value:isSet() or message:isValueSet() before trusting the number.
Example
local value = controls.get(1):getValue("value")
if value:isSet() then
print(value:getValue(), value:getText())
-- Display space here ...
value:setValue(64)
-- ... and the same parameter, in MIDI space.
print(value:getMessage():getValue())-- A list: the display value is the index, and the overlay says what it means.
local list = controls.get(2):getValue("value")
list:setValue(2) -- the third item
local overlay = list:getOverlay()
if overlay then
print(list:getValue(), list:getText())
endA group's value is read only
A group may follow a MIDI parameter and show the overlay item it selects. It declares no inputs, no pot drives it and it never transmits, so every setter on its value raises rather than pretending. Reading is what it is for - see Group.
Message
The Message object holds the actual MIDI or virtual message that Control’s Value object sends and receives. Every Value object is linked to exactly one Message object, and message:getControlValue() leads back to it.
A message is reached through its value - control:getValue("value"):getMessage(). There is no constructor: the global Message() exists and always raises.
Functions
Parameters
Returns
PT_ globals - `PT_CC7`, `PT_NRPN`, `PT_NOTE` and the rest - rather than the numbers; they are listed in the Globals section. Type 17 is a macro's and has no global. Parameters
PT_ globals. For a list of message types, refer to the overview in the Globals section. Returns
Parameters
Returns
<value>:setValue() performs, in MIDI space rather than display space. Parameters
Returns
Parameters
Returns
Parameters
Returns
setMin() and setMax() functions. Parameters
Parameters
Returns
Parameters
Returns
Example
-- Print info about the message
function valueCallback (valueObject, value)
local message = valueObject:getMessage ()
print ("Device Id: " .. message:getDeviceId ())
print ("Type: " .. message:getType ())
print ("Parameter Number: " .. message:getParameterNumber ())
print ("Current value: " .. message:getValue ())
endHow the message is encoded
The preset format carries these and the object never showed them, so a script working out what a fourteen-bit or a signed parameter would send had to know the answer already.
Returns
Returns
Returns
Returns
Whether there is a value at all
Returns
Value formatters
A value formatter is a custom function that formats how a control's value is displayed. It receives a display value as input and returns a new value as a string. This allows users to customize how information appears on the screen in many different ways.
To use a formatter, you must assign it to a Value in the preset JSON by adding a formatter attribute to the Value object. The attribute is the name of a global function in the preset's script.
The value formatter runs automatically whenever the underlying MIDI value changes. The text it returns is kept on the value: the control draws it, and value:getText() reads it back. A value that declares no formatter has no text, and getText() answers an empty string rather than the number.
A value of a relative control has no position, so its formatter runs once for every step the control sends instead, with the step as the value - 1 or -1, or up to 10 for an accelerated control - and never when nothing moved.
What the firmware does with what the formatter returns:
- a string, or a number: it becomes the text, cut to 20 characters;
- an empty string, no return value at all, or anything that is not a string or a number: the value keeps the text it had, and the reason is written to the log;
- an error: it is logged, and the value keeps the text it had.
The formatter runs on whichever thread the value changed on - the MIDI thread for an incoming message, the application thread for a knob - so keep it short and keep it pure. It must not send MIDI, load a preset or edit the preset.
Example preset JSON
"values": [
"message": {
"deviceId": 1,
"type": "cc7",
"parameterNumber": 2,
"min": 0,
"max": 127
"id": "value",
"min": 0,
"max": 127,
"formatter": "formatFractions"
]For more detailed information about the preset JSON, visit the Preset JSON format page.
Functions
Parameters
Returns
Compose the text, do not concatenate the number
value arrives as a Lua number, and on this firmware it is a floating point one - so value .. "%" prints 64.0%, not 64%. Use string.format and say which way you want it: string.format("%d%%", value).
Example
-- Convert number to a range with decimal numbers
function formatFractions(valueObject, value)
return (string.format("%.1f", value / 20))
-- add percentage to the value
function addPercentage(valueObject, value)
return (string.format("%d%%", value))
-- name the note a number stands for
local notes = { "C", "C#", "D", "D#", "E", "F",
"F#", "G", "G#", "A", "A#", "B" }
function formatNote(valueObject, value)
local note = math.floor(value)
return (string.format("%s%d", notes[(note % 12) + 1], (note // 12) - 1))
endThe whole path, in a preset that shows a filter cutoff in hertz:
"id": 1, "type": "fader", "name": "CUTOFF", "pageId": 1,
"controlSetId": 1, "inputs": [ { "potId": 1, "valueId": "value" } ],
"values": [
{ "id": "value", "min": 0, "max": 127, "defaultValue": 64,
"formatter": "formatHertz",
"message": { "deviceId": 1, "type": "cc7", "parameterNumber": 74,
"min": 0, "max": 127 } }
}function formatHertz(valueObject, value)
return (string.format("%d Hz", math.floor(20 * math.exp(value / 20))))
-- and the same text, read back wherever it is needed
function currentCutoff()
return (controls.get(1):getValue("value"):getText())
endValue function callbacks
A value function callback is a user-defined function that lets you run custom actions whenever a control's value changes.
To use a callback, you must assign it to a Value in the preset JSON by adding a function attribute to the Value object, naming a global function in the preset's script. You can think of a callback as a flexible alternative to a Message: while a Message sends a fixed MIDI command, a function runs dynamic Lua code when the value changes.
A value may have both a function and a formatter. The function runs first, so the formatter sees whatever the function changed.
For a value of a relative control the function runs once for every step the control sends, with the step as the value, and never when nothing moved. Before firmware 5.0.0 it did not run for relative controls at all.
The function returns nothing; a return value is ignored. Anything it raises is logged and the change carries on. Like a formatter, it runs on the thread the value changed on, so it must not block - and it must not edit the preset, which only the application thread may do.
<value>:updateValue() is the write that does not run it. A function that writes back to its own value with setValue() hears itself.
Example preset JSON
"values": [
"message": {
"deviceId": 1,
"type": "cc7",
"min": 0,
"max": 127
"id": "attack",
"min": 0,
"max": 127,
"function": "highlightOnOverload"
Functions
Parameters
Example
The value object leads back to its control, so one function can serve every control that names it.
function highlightOnOverload (valueObject, value)
if (value > 64) then
control:setColor (ORANGE)
else
control:setColor (WHITE)
endExample
A function used in place of a MIDI message: the value is not sent as one parameter but turned into two.
"values": [
"id": "value", "min": 0, "max": 127, "defaultValue": 0,
"function": "sendAsPair",
"message": { "deviceId": 1, "type": "virtual", "parameterNumber": 1,
]function sendAsPair(valueObject, value)
local coarse = math.floor(value) // 8
local fine = math.floor(value) % 8
midi.sendControlChange(PORT_1, 1, 16, coarse)
midi.sendControlChange(PORT_1, 1, 48, fine)
endControl event callbacks
A control event callback is a user-defined function that runs when a control's knob switch is pressed or its knob is touched.
Unlike a value function callback, which runs when a value changes, an event callback runs on a gesture. It is assigned in the preset JSON by adding an events array to a control and naming the function in a lua action. The same function may be named by several controls and by several events - the arguments tell it which one ran it. The source and the event arrive as numbers, given by the EVENT_SOURCE_* and EVENT_TYPE_* globals, the same way every other enum the script API hands out is.
On an Electra One mini a switch event is the switch in the knob. An mk2 has none, so a touch of the control on the LCD takes its place. A touch event is the knob being touched on either model.
A control that declares any switch event takes over the whole of its LCD touch handling: a pad with a switch event no longer toggles its value, and a fader no longer drags. That is the point of the events - they replace what the firmware would otherwise do. touch events are additive: they run alongside the highlighting and the pot reporting that make the knob work at all.
The callback runs on the application thread, so it may do anything a script can do - send MIDI, switch pages, edit the preset. An error it raises is logged and the remaining actions of the event still run.
Example preset JSON
"events": [
"source": "switch",
"event": "press",
"actions": [
{ "type": "lua", "function": "onSwitch" }
"source": "switch",
"event": "release",
"actions": [
Functions
Parameters
Parameters
Example
The simplest case - do something while the switch is held.
function onSwitch(control, source, event, potId, valueId, value)
if (event == EVENT_TYPE_PRESS) then
control:setColor(ORANGE)
else
control:setColor(WHITE)
endExample
One function serving every knob on the page. potId says which knob it was, counted from one, so it can be used directly as a MIDI parameter number or an array index.
local names = { "OSC", "FILTER", "ENV", "LFO" }
function onKnobTouch(control, source, event, potId, valueId, value)
if (event == EVENT_TYPE_BEGIN) then
print("touched knob " .. potId .. " - " .. (names[potId] or "?"))
midi.sendControlChange(PORT_1, 1, 100 + potId, 127)
else
midi.sendControlChange(PORT_1, 1, 100 + potId, 0)
endExample
Acting on whatever the control currently shows. valueId is the handle in focus - "value" for a fader, "attack" or "release" for an envelope - and value is what it reads, so a script can respond without looking the value up.
if (event ~= EVENT_TYPE_PRESS) then
return
print(control:getName() .. "." .. valueId .. " is " .. value)
-- the handle in focus, ready to be read or changed
local valueObject = control:getValue(valueId)
print("its range is " .. valueObject:getMin() .. " to " .. valueObject:getMax())
endExample
Answering with the value a message action should send. The message names the function instead of a number, so what goes out is decided when the event runs.
"type": "message",
"message": {
"type": "cc7",
"deviceId": 1,
"parameterNumber": 30,
"value": "pickValue"
}-- send the control's own value on press, and zero on release
function pickValue(control, source, event, potId, valueId, value)
return (value)
return (0)
endExample
A latching switch. With "mode": "toggle" in the preset JSON, the first press runs the press actions, letting go runs nothing, and the next press runs the release actions - so the callback sees EVENT_TYPE_PRESS and EVENT_TYPE_RELEASE alternating, one per press.
"source": "switch",
"event": "press",
"mode": "toggle",
"actions": [ { "type": "lua", "function": "onLatch" } ]
}function onLatch(control, source, event, potId, valueId, value)
control:setName("ON")
else
control:setName("OFF")
control:repaint()
endHow a preset is laid out
A page is a named screenful of controls. A preset has up to 12 pages on an mk2 and up to 16 on a mini, and a page only exists when the preset declares it - there is no page 5 in a preset with three pages.
A page holds control sets: three banks of knobs, switched with the buttons below the screen, so that a page can carry more parameters than the instrument has knobs. Each control is in one of them, and only the active set is being turned. A mini's third row of slots is its four context buttons rather than a control set.
A group is a label with a line or a box under it, drawn across a row of slots to say what those controls have in common. It is a control of type "group": it shares the control id space, sits on a page, and comes back from controls.getAll() and preset.getControls() along with everything else.
An overlay is a list of items, each an integer value and a label - and optionally a colour and a small bitmap. A List control shows an overlay item instead of a number, a Fader may be labelled by one, and a Group may follow one. Overlays belong to the preset and are shared: several values may point at the same overlay.
Pages
The pages module allows you to get information about pages, check their status, and switch from one page to another.
Functions
An id outside the model's range raises.
An id inside it that the preset does not declare - the usual case for a preset with three pages - does not raise and does not answer nil. It answers a stand-in Page object whose getId() is 0 and whose name is empty. Test for that, or use preset.getPage(id), which answers nil for a page the preset does not have:
local page = pages.get(5)
if page:getId() == 0 then
print("there is no page 5 in this preset")
endThe global Page(id) is the same function under another name.
Parameters
Returns
The array is indexed by page id and is always full length, so its size is the model's page count rather than the preset's. A page the preset does not declare is a stand-in object whose getId() is 0 - filter on that:
for id, page in ipairs(pages.getAll()) do
if page:getId() ~= 0 then
print(id, page:getName())
endReturns
Returns
Asking for the page already on screen does nothing and says so in the log. Asking for a page the preset does not declare, or one that is hidden, only redraws what is there.
To open a page on a particular control set, set the page's own default with <page>:update{ defaultControlSetId = n } first.
Parameters
<page>:lockActiveControlSet(). Parameters
Returns
It needs no subscription and always runs, on the application thread, in the script of the preset on screen. It is not events.onPageChange, which carries the same two numbers but only runs when the script has subscribed to PAGES.
Parameters
Example
-- Retrieve a reference to given page
local page = pages.get(3)-- Name every page after the first control on it, and follow page changes.
function onReady()
local onPage = preset.getControlsOnPage(id)
if onPage[1] then
page:setName(onPage[1]:getName())
function pages.onChange(newPageId, oldPageId)
print(string.format("page %d -> %d", oldPageId, newPageId))
endPage
A Page object stores its own data and provides functions to update and manage it.
The setters work on the preset being shown
setName, setHidden, isHidden, lockActiveControlSet and isActiveControlSetLocked reach the page by id in the preset on screen, not in the preset the object came from. For the usual case - a script changing its own preset while that preset is being shown - the two are the same page. From a preset pinned in the background they are not, and the call lands on the page of the preset the user is looking at - or on nothing visible at all, when that preset declares no page with the id. getId() and getName() read the object itself.
Functions
Returns
Parameters
Returns
Parameters
Returns
pages.setActiveControlSet() does not either - which is what a preset that has given those buttons another job wants. The lock is not written to the preset file; it lasts until it is unlocked or the preset is loaded again.
Parameters
Returns
Example
-- change the name of a page
local page = pages.get(1)
page:setName("LPF")
print("page name: " .. page:getName())-- Hold page 1 on its control set while a shift pad is held, and
-- let the pages be walked without the hidden ones.
function onShift(control, source, event, potId, valueId, value)
pages.get(1):lockActiveControlSet(event == EVENT_TYPE_PRESS)
function nextVisiblePage()
local all = pages.getAll()
local id = pages.getActive():getId()
for step = 1, 16 do
local candidate = all[(id + step - 1) % 16 + 1]
if candidate and candidate:getId() ~= 0 and not candidate:isHidden() then
pages.display(candidate:getId())
return
endUnlike the setters above, this one works on the preset the page belongs to. It may only be called on the application thread - from onReady, a control callback, a command or a patch hook, not from a timer.
pages.get(2):update { name = "FILTER", defaultControlSetId = 2, hidden = false }Parameters
Returns
Groups
The groups module helps you manage groups inside a preset. A Group is a graphical element that organizes and improves the layout of preset pages.
Functions
Raises when the preset has no group with that id - a control's id raises here as loudly as an unused one - and when the id is outside 1 .. 864. Guard it with preset.getGroup(id), which answers nil, or test what a collection hands back with isGroup().
The global Group(id) is the same function under another name.
Parameters
Returns
Example
-- Retrieve a reference to given group
local group = groups.get(1)
-- the same lookup, without a raise for a missing group
local maybe = preset.getGroup(1)
if maybe then
print(maybe:getName())
endLike every other preset edit this may only be done on the application thread - from onReady, a control callback, a command or a patch hook, not from a timer.
Give a group bounds rather than slot: a slot here is converted with a control's geometry, not a group's, and the group lands a few pixels off. Set the position afterwards with group:setSlot(), which uses the group grid.
local g = groups.create {
pageId = 1, name = "OSCILLATOR", color = "529DEC",
bounds = { 0, 0, 512, 22 }
g:setSlot(1, 3) -- three slots wide, on the group gridParameters
Returns
Parameters
Returns
Group
A Group object stores its own data and provides functions to update and manage it.
A group that follows a MIDI parameter - one given a values array in the preset JSON - takes its label and its color from the overlay item the current value selects. Anything a script sets with setLabel or setColor on such a group is replaced the next time that parameter changes. Set the overlay item's label and color instead, or leave the value off the group and drive it from Lua alone.
Some setters work on the preset being shown
setVisible, setBounds, setSlot, setHorizontalSpan, setVerticalSpan and setVariant reach the group by id in the preset on screen, the way the Page setters do. For a script changing its own preset while that preset is being shown - the usual case - that is the same group. setLabel, setName, setColor, setFont and every reader work on the object itself.
Functions
Returns
An empty string also hides the group: a group with nothing written on it is taken to be a group that is not wanted. To draw a plain line or box with no text, set the label and then setVisible(true) again.
Parameters
Returns
visible member. Hiding a group leaves everything else about it alone. Parameters
Returns
"529DEC" string the preset file uses. Parameters
Returns
This one takes the number, where control:setVariant() takes the name. group:getVariant() answers the name, as a control's does.
Parameters
A group is one of the two things on screen whose face the preset chooses, so unlike a control's this is never ignored.
Parameters
Returns
X, Y, WIDTH, HEIGHTglobals to access individual members of the array. The rectangle is cut to fit inside 1024 x 550 - the mk2's control area - on every model.
Parameters
Example
-- change group slot and dimensions
-- A line over three slots of the first row
local group1 = groups.get(1)
print("Label name: " .. group1:getLabel())
group1:setSlot(1, 3)
-- A box two slots wide and two rows tall, starting at slot 9
local group2 = groups.get(2)
print("Label name: " .. group2:getLabel())
group2:setSlot(9, 2, 2)The grid is the model's own: six columns of six rows on an mk2, four columns of two rows plus the context-button row on a mini, where a group in slots 9 to 12 is always a line.
Keep the span inside the row: slot and width must describe columns the page has. A group asked to span past the end of its row is not clipped back to a sensible width, and can end up drawn many times wider than the screen.
Parameters
This one is measured in the mk2's grid on every model, so on a mini use setSlot(), which knows the model's geometry.
Parameters
As with setHorizontalSpan(), the mk2's grid is used on every model.
Parameters
A group is a control of type "group": it lives in the same collection as everything else, shares the id space, and sits on a page. So it answers the Control readers as well as its own methods, and appears in preset.getControls() and controls.getAll() alongside the rest.
Returns
Parameters
<control>:isGroup(), so a walk over a mixed collection can ask every entry the same question. Returns
The readers below are the Control object's own, and read exactly as they do there.
Returns
Returns
Returns
Returns
Returns
Returns
Returns
Parameters
What a group deliberately does not have is everything it cannot do: setPot(), the override functions and the Custom control callbacks are not on it, because no knob drives a group and a group sends nothing.
A group in a mixed collection comes back with the Group methods on it; controls.get(id) hands back the same group with the Control methods on it instead, so setSlot there is a control's. Use preset.getControl(id) or groups.get(id) when the group's own methods are wanted.
A group that follows a parameter
A group may name a MIDI parameter and show the overlay item that parameter's value selects: the item's label replaces the group's name, and where the item carries a colour, that replaces the group's colour.
That value is read only. A group declares no inputs so no pot can move it, and it never transmits - a minimum, a maximum, a default or an override on one would be fields that reach nothing, so every Value setter raises a group's value is read only rather than pretending. Reading is what it is for.
Parameters
Returns
Returns
Returns
Example
-- What is this group following, if anything?
local group = preset.getGroup(433) -- nil when the preset has no such group
local value = group and group:getValue()
if value then
print(string.format("%s follows parameter %d on device %d",
group:getName(),
message:getParameterNumber(),
message:getDeviceId()))
endgroups.get(1):update { name = "FILTER", color = "F49500" }Parameters
A group's table carries no visible member - the format has none - so a hidden group copied into another preset with groups.create() arrives visible.
Returns
Overlays
The Overlays module provides functionality for managing preset overlays. An overlay is a list of MIDI values, with each entry containing a MIDI value, a text label, an optional colour, and optional bitmap data. Overlays provide options for List controls, can replace display values for Faders, and are what a Group follows when it is bound to a parameter.
Overlays can be read, created, changed and removed at runtime, and a control value can be pointed at a different overlay - or detached from overlays altogether - while the preset is running.
Functions
<value>:getOverlay() answers the overlay a value is showing. The global Overlay(id) is the same function under another name.
Parameters
Returns
This is the same call as preset.getOverlays().
Returns
The callback is not protected: an error it raises comes out of overlays.each(). Do not create or remove overlays inside it either - that invalidates the walk.
Parameters
Returns
Both arguments are needed: the overlay is emptied before the items are read, so overlays.create(5) wipes overlay 5 and then raises.
In this form the item's color is a number, 0x03A598. The table form below is the one that takes the "03A598" string the preset file uses.
Parameters
Returns
Detaching leaves the value's range where the overlay put it - there is no record of what it was before the overlay was attached - so a preset that wants the original range back sets it with <value>:setRange() or <value>:setMax().
A detached value still reports the removed overlay from getOverlayId(); getOverlay() is the one that answers nil. An Overlay object the script kept must not be used after this.
Parameters
Returns
The Overlay Lua table must be structured as shown below. value is the MIDI value, label is a text label of at most 20 characters associated with the MIDI value, and color is an optional 24-bit RGB colour.
overlayData = {
{ value = 1, label = "Room" },
{ value = 2, label = "Hall" },
{ value = 3, label = "Plate" },
{ value = 4, label = "Spring", color = 0x03A598 }
}A colour is optional, and black is not "no colour"
An item without a color key carries no colour at all, and a Group following the overlay keeps its own colour on that item. color = 0x000000 is black, which is a different thing. The same applies to label: an item that carries a colour and an empty label recolours a Group and blanks its name.
A discrete value is an index into its list, so binding an overlay to a value sets that value's maximum to the last index of the list - and so does every change to the list afterwards. That is right for a List control and wrong for a Fader: a 0 .. 127 fader given a four-item overlay for its labels ends up with a range of 0 .. 3. Put the fader's range back with <value>:setRange() after attaching the overlay.
It goes through the reader the preset file goes through, so here an item's color is the "03A598" string, not a number - a number there is read as black. It may only be called on the application thread.
overlays.create {
id = 3,
items = {
{ value = 0, label = "SAW", color = "F49500" },
{ value = 1, label = "SQUARE" }
}Parameters
Returns
Overlay
An Overlay object stores the data and functions used to manage an overlay.
Item indices are zero based
An index into an overlay is a discrete control's display value, so <overlay>:getItem(n) and <value>:setValue(n) name the same item. The first item is index 0 and the last is <overlay>:getNumItems() - 1.
Reading an overlay
Returns
Returns
Returns
The array is a Lua array and so is counted from one, while each item's own index is counted from zero. The bitmap itself is not returned.
Returns
Parameters
Returns
Parameters
Returns
Parameters
Returns
Parameters
Returns
Parameters
Returns
Changing an overlay
Every function below repaints the controls using the overlay and puts their ranges back in step with it, so a preset never has to ask for that itself.
An item table is { value, label, color, bitmap }. value defaults to 0 and label to the empty string, color is a number and is left unset when the key is absent, and bitmap is the raw image data - 48 by 18 pixels, one bit per pixel, six bytes a row, 108 bytes in all - that the Preset Editor writes. A shorter string is read past its end, so do not compose one by hand in Lua.
Parameters
Returns
Parameters
Returns
Parameters
Returns
Attaching an overlay to a control
An overlay is attached to a value, not to a control, because a control may carry several. The three functions live on the ControlValue object and are documented with it.
<value>:setOverlay(overlay) | show this overlay; takes an Overlay object or an id |
<value>:getOverlay() | the Overlay object it is showing, or nil |
<value>:clearOverlay() | detach it, and show raw values again |
<value>:setOverlayId() and <value>:getOverlayId() are the older spelling and are unchanged: they work in ids rather than objects.
Examples
-- Define reverb types with associated values and labels
local listReverbTypes = {
{ value = 4, label = "Spring" }
-- Create a new overlay and show it on the list control with id 4
function onReady()
local overlay = overlays.create(2, listReverbTypes)
preset.getControl(4):getValue("value"):setOverlay(overlay)
endBuilding a list from what a synth reports, and pointing a control at it. The function is an ordinary one - call it from wherever the names were parsed, a SysEx handler most often:
function setPatchNames(names)
local overlay = overlays.get(7)
overlay:clear()
for i, name in ipairs(names) do
overlay:addItem({ value = i - 1, label = name })
-- The control's range has already followed the new list.
preset.getControl(21):getValue("value"):setOverlay(overlay)
endReading the label a raw MIDI value stands for:
function onWaveform(value)
local item = overlays.get(3):getItemByValue(value)
print(item and item.label or string.format("unknown (%d)", value))
endSwitching between two lists, and going back to plain numbers:
local value = preset.getControl(5):getValue("value")
value:setOverlay(overlays.get(11)) -- by object
value:setOverlay(12) -- or by id
value:clearOverlay() -- show the number again
value:setRange(0, 127, 64) -- and put the range backKeeping a group's label in step with a list, which is what a group bound to a parameter does on its own - here done from Lua for a group that is not bound:
-- named in the value's "function" attribute in the preset file
function onWaveformChanged(valueObject, value)
local overlay = valueObject:getOverlay()
local item = overlay and overlay:getItem(math.floor(value))
if item then
groups.get(200):setLabel(item.label)
endThis is the shape the table form of overlays.create() takes, so an overlay goes back in as it came out:
local copy = overlays.get(2):toTable()
copy.id = 8
overlays.create(copy) -- the same list, under a new idReturns
Devices
A Device is an instrument the preset knows about: a name, a MIDI port, a MIDI channel, the interfaces it is reached on, and - optionally - the SysEx templates used to ask it for a patch and to recognise its answer. Every control value that sends MIDI names a device by its id, and the parameter map is keyed by that id too.
A device id runs from 1 to 32. Zero is not a device: a preset value written with deviceId 0, or with no deviceId at all, sends nothing and is not stored under a device.
The devices module reaches the devices of the preset the script belongs to. A pinned preset running in the background reads its own devices, not the ones of the preset on the screen.
Some of this runs on the application thread only
devices.create(), devices.remove(), device:update() and every definition editor - the request, response, rule and message functions - raise when they are called from a timer or a schedule callback. Call them from preset.onReady(), a control callback, a command or a patch hook.
Reading, and the plain setters - name, port, channel, rate, interfaces, running status - may be called from anywhere.
Functions
Raises when the preset declares no device with that id, and when the id is outside 1 .. 32. Use preset.getDevice(deviceId) when you want nil for a device that is not there.
Device(deviceId) is the same call written as a constructor.
Parameters
Returns
Raises when no device of the preset sits on that port and channel.
Parameters
Returns
This is the same call as preset.getDevices(). A Preset object may be passed as the first argument - devices.getAll(Preset(4)) - to read another slot's devices.
Returns
Parameters
Returns
An existing device with the same id is replaced without a warning, and its patch requests, responses and messages go with it. The rate of a device made this way is 0.
Interface names are the ones the preset file uses: "midiIo", "midiUsbDev", "midiUsbHost", and "midiAll" for the lot. An unknown name raises.
local synth = devices.create(3, "Prophet", PORT_1, 4, { "midiIo", "midiUsbHost" })Parameters
Returns
id and name are required; everything else takes the same default the file reader gives it.
local dx = devices.create {
id = 2, name = "DX7", port = 1, channel = 1,
patch = { { request = { "F0", "43", "20", "00", "F7" },
responses = { { id = 1,
header = { "F0", "43", "00", "00", "01", "1B" },
rules = { { type = "sysex", parameterNumber = 1, byte = 0 } } } } } }
}Parameters
Returns
Device objects a script is still holding do not survive the removal. Drop them and ask again rather than calling anything on them.
Parameters
Returns
Example
-- What this preset can talk to, and how.
function preset.onReady()
devices.each(function (device)
print(string.format("%d %s port %d channel %d [%s]",
device:getId(),
device:getName(),
device:getPort(),
device:getChannel(),
table.concat(device:getInterfaces(), " ")))
end)
endDevice
A Device object is used to manage the Device settings.
Every function below is a method: call it with a colon - device:getName(), not device.getName(). A dot call passes no device and raises.
Functions
devices.create() function. Returns
Parameters
Returns
The preset's lookup of "which device is this message for" is rebuilt by the call, so the new port takes effect for incoming messages as well.
Parameters
Returns
Parameters
Returns
The rate is stored on the device and written to the preset file, and nothing in the current firmware paces MIDI output by it.
Parameters
Returns
The device's messages go out on all of them, and a message arriving on one of them, on the device's port and channel, is the device's.
Parameters
Returns
Parameters
Returns
A script's device:send*() is not one of those messages: it always sends full status bytes.
Parameters
Returns
Returns
Sending to a device
A device already knows its interfaces, its port and its channel - that is most of what a device is. These send with all three filled in, so a preset addressing an instrument does not take them back off it on every call, and moving an instrument to another port means editing the device rather than every call site.
Each is the midi.* function of the same name with the address left off. Unlike the control values the preset sends, the arguments are not range checked: a note number of 300 or a value of -1 goes into the message as whatever the low bits of it are. Optional boolean flags must be real booleans; anything else counts as false.
Parameters
Parameters
Parameters
Parameters
Parameters
Parameters
Parameters
A SysexBlock goes exactly as it stands, framing included - that is what midi.onSysex() and patch.onResponse() hand over. A string or an array of numbers is the body: the leading 0xF0 and the trailing 0xF7 are added, so do not put them in. Anything else raises.
Parameters
local synth = devices.get(1)
synth:sendProgramChange(10)
synth:sendControlChange(74, 64)
synth:sendSysex({ 0x00, 0x20, 0x29, 0x02 })The notes held on a device
The controller keeps track of which notes are held down on every MIDI input, all the time, whether or not a preset asked - so a script asking which keys are down is told about the ones pressed before it asked. A device's notes are the ones coming in from it: on one of its interfaces, on its port and its channel - the same messages the preset hands the device's parameters.
A note is held from its Note On to its Note Off, and a Note On with velocity 0 is a Note Off. All Sound Off (CC 120), All Notes Off (CC 123) and the mode messages (CC 124 to 127) let go of every note on their channel, and a System Reset of every note on its input. The sustain pedal lets go of nothing: these are the keys that are down.
Every note is a table:
note | the note number, 0 to 127 |
velocity | the velocity it was pressed with |
time | when it was pressed, in milliseconds on the clock schedule.now() reads |
The same key held on two of the device's interfaces at once - arriving over USB and over DIN - is one note, with the velocity of the later press, until it has been let go on both.
Returns
Parameters
Returns
type | "noteOn", "noteOff", "allNotesOff" or "resync" |
note | the note that went down or up; absent for allNotesOff and resync |
velocity | the velocity it was pressed with, or the Note Off's |
channel | the MIDI channel it came in on |
interface, port | where it came in; the interface is a number, as USB_HOST and the other interface constants are |
time | when, in milliseconds on the clock schedule.now() reads |
A "resync" change carries type and nothing else.
It is called once per change, in the order the changes happened, and each time with the notes as they stood right after that change. So a drum pad whose Note Off follows its Note On by a millisecond is still seen going down, with the note held, and then coming up - however late the function gets to run.
A "resync" is what the function is told when the controller was too busy to hand the changes over one by one - more than 128 of them waited. Those changes are lost, and the device's notes are brought up to date in one step.
There is one function per device: setting another replaces it, and nil removes it. The function runs on the controller's application thread, a few milliseconds after the note reaches the input. It belongs to the preset, and runs while the preset does: while it is on the screen, and while it is pinned and another preset is showing. A preset that is not pinned stops hearing about notes when you leave it, and hears about them again when you come back.
Parameters
To wait for a particular combination of notes - a chord, two pads hit together, a key hit hard - schedule.whenNotes() does the matching for you.
Example
local keys = devices.get(1)
-- Show how many keys are down, and which is the lowest.
keys:onNotesChanged(function(device, notes, change)
if #notes == 0 then
info.setText("--")
else
info.setText(#notes .. " held, lowest " .. notes[1].note)
-- A fifth, and nothing else, struck hard: the synth's lead patch.
if change.type == "noteOn" and change.velocity > 110 and #notes == 2
and notes[2].note - notes[1].note == 7 then
device:sendProgramChange(12)
end)The patch templates a device declares
A device's patch section in the preset JSON says what to ask an instrument for and how to recognise the answer. These read it back, so a preset can see what it is about to ask for and what a response it was handed matched on.
Returns
Returns
Returns
Parameters
Returns
The device a patch callback is handed answers these too
patch.onRequest(device) and patch.onResponse(device, ...) are given a Lua table carrying id, port (counted from zero), channel and interfaces (an array of names), and that has not changed - pairs() and type() answer exactly what they always did. It now also answers every Device method, so the patch callbacks and the rest of the API are one thing:
function patch.onRequest(device)
print(device.channel) -- as before
print(device:getName()) -- and the object's own methods
endExample
-- This needs to reflect the preset device settings
local AccessVirusDeviceId = 2
-- Display info about the device
local device = devices.get(AccessVirusDeviceId)
print("device port: " .. device:getPort())
print("device channel: " .. device:getChannel())
-- A function a Control value calls. setChannel raises outside 1 .. 16, so the
-- control's value has to be in that range - a list or a fader with min 1 and
-- max 16.
function setChannel(valueObject, value)
device:setChannel(value)
endDefinitions: requests, responses, rules, messages
Firmware 5.0 and later. A device holds three kinds of definition beside its common fields: the requests it sends when a patch is asked for, the responses it recognises - each an id, a header and the rules that take parameter values out of the bytes after the header - and the messages its controls send through, by id. All three are readable and editable in place, as tables in the preset file's shape.
A template is the element array the file carries: numbers are decimal bytes, strings are hex bytes, and objects are the placeholders - { type = "value", rules = { ... } }, { type = "parameter", rules = { ... } }, { type = "checksum", algorithm = "roland", start = 5, length = 10 }, { type = "function", name = "myByte" } and { type = "any" }, which matches any single byte on the way in and makes a template unsendable. Framing is added on the way in and stripped on the way out, so a request { "F0", "43", "20", "00", "F7" } reads back as { 67, 32, 0 }.
A rule is { type, parameterNumber, byte, parameterBitPosition, byteBitPosition, bitWidth }, where byte counts from the first byte after the header and bitWidth defaults to 7. A response header is rendered before it is matched and may be at most 64 bytes.
-- A TX7 voice dump: 155 data bytes after a six-byte header, one rule each.
local dx = devices.get(2)
local rules = {}
for i = 0, 144 do
rules[#rules + 1] = { type = "sysex", parameterNumber = i + 1, byte = i }
dx:clearResponses()
dx:addResponse(1, { "F0", "43", "00", "00", "01", "1B" }, rules)
dx:clearRequests()
dx:addRequest({ "F0", "43", "20", "00", "F7" })Once the device carries its request and its rules, the firmware does the rest on every reply: header match, values into the parameter map, controls repainted. No script is needed in the preset that owns the device unless a template needs a function byte or a checksum the firmware does not know.
Returns
Parameters
Returns
Parameters
Parameters
Returns
Parameters
Returns
Parameters
Returns
Parameters
Returns
Parameters
Returns
Parameters
Parameters
Returns
Returns
Parameters
Returns
Parameters
synth:setMessage(1, { "43", "10", { type = "parameter" }, { type = "value" } }, "both")
print(synth:getMessageDirection(1)) -- bothParameters
Returns
Parameters
Returns
The whole table is read and checked before anything is written, so a call that raises - a channel that is not a number, a direction that is not "in", "out" or "both" - changes nothing.
Parameters
Returns
Parameter Map
The Parameter Map is the central part of the Electra Controller firmware. It keeps track of all parameter values across connected devices. Whenever a MIDI message is received, a knob is turned, or a value is changed by touch, the Parameter Map records the change, updates everything that depends on it, and sends out new MIDI messages.
An entry is addressed by three numbers - the device id, the parameter type and the parameter number - and holds one 14-bit MIDI value.
| Argument | Range |
deviceId | 1 .. 32 |
type | 0 .. 17: the PT_* constants, plus 17 for a macro parameter, which has no constant |
parameterNumber | 0 .. 16383 |
midiValue | 0 .. 16383 |
Anything outside those ranges raises, and so does a non-integer.
PT_VIRTUAL 0, PT_CC7 1, PT_CC14 2, PT_NRPN 3, PT_RPN 4, PT_NOTE 5, PT_PROGRAM 6, PT_SYSEX 7, PT_START 8, PT_STOP 9, PT_TUNE 10, PT_ATPOLY 11, PT_ATCHANNEL 12, PT_PITCHBEND 13, PT_SPP 14, PT_RELCC 15, PT_NONE 16.
An entry has to exist before it can be set
The map holds an entry for each parameter some control value in the preset addresses, and for each one parameterMap.setFunction() was called for. Nothing else creates one.
set(), apply(), updateValue() and modulate() on an address with no entry do nothing at all - no error, no message on the wire. A script that drives parameters no control displays has to call parameterMap.setFunction() for them first, which creates the entry as a side effect.
Each preset has its own parameter map, and these functions always mean the map of the preset the script belongs to - a pinned preset in the background reads and writes its own.
Functions
Parameters
The change is made with origin LUA. It does nothing when the address has no entry.
Parameters
An entry that has never been set holds no value to OR into, and the call does nothing: use set() for the first write and apply() for the bits that follow.
Parameters
The modulation is spread over the range of the entry's first message and held inside it. For a message with no sign that is its MIDI min .. max. For a twosComplement or signBit message it is the signed range its bitWidth holds, and the modulation moves the signed number rather than the raw MIDI value, so it never wraps across the sign. Before firmware 5.0.0 every signed message was modulated as a seven-bit two's complement value, which gave wrong results for signBit and for 14-bit messages.
Parameters
This is how a script follows an instrument that reports its own changes: store what the instrument says without sending it straight back.
Parameters
MIDI_VALUE_DO_NOT_SEND is 16537, which is not a MIDI value: it is what an entry holds before anything has been set, and what this answers for an address the map does not know. Compare against the constant rather than the number.
Parameters
Returns
Raises when there is no entry at that address, and when the entry has no control values linked to it - which is the case for every parameter created by parameterMap.setFunction().
Parameters
Returns
All three arguments are required; the address is not checked until the returned function is called.
local cutoff = parameterMap.map(1, PT_CC7, 74)
cutoff(64) -- the same as parameterMap.set(1, PT_CC7, 74, 64)
print(cutoff()) -- 64Parameters
Returns
Since firmware 5.0.0 it also runs for a parameter no control displays: a value set from a script or arriving over MIDI for an entry nothing is drawn for. valueObjects is then an empty table, never nil, so a loop over it simply does nothing; index it directly only after checking #valueObjects.
origin says where the change came from:
INTERNAL (0) | the controller itself - a preset load, a snapshot, a default value |
MIDI (1) | a MIDI message that arrived |
LUA (2) | a script |
| 3 | a modulation pass. Never delivered here: modulation does not run this callback |
| 4 | a file - a snapshot or a capture being applied |
| 5 | a remote control surface mapped to the parameter |
| 6 | a satellite, over the Electra Satellite Link |
Only the first three have constants. Origins 4, 5 and 6 arrive as plain numbers.
It is one callback for every parameter of every device. A preset watching a few parameters is better served by parameterMap.setFunction(), which costs nothing for the parameters it is not bound to.
A relative control calls it once for every step it sends, and midiValue is the value that went out - in the default signBit mode 65 for a step up and 1 for a step down. Before firmware 5.0.0 relative steps did not reach it.
The callback runs in the state of the preset that owns the map, on the application thread.
Parameters
Example
-- Display info about the change in the ParameterMap
function parameterMap.onChange(valueObjects, origin, midiValue)
print(string.format("a new midiValue %d from origin %d",
midiValue, origin))
print(string.format("affects control value %s.%s",
endThe file is named after the preset's project id, so every preset of a project shares one saved map.
parameterMap.keep() function call. Returns nothing, whether or not there was anything to recall. parameterMap.keep() function call. The entry is created if it does not exist yet, which is also what makes parameterMap.set() work on that address afterwards.
The function is handed the MIDI value and the address it arrived at:
function onCutoff(midiValue, origin, deviceId, type, parameterNumber)All scalars, so nothing is allocated per call, and the last three let one function serve several parameters. Like a value's function it does not run on the first pass after a preset loads. A name rather than a closure, because that is what the preset format already binds and what the debugger can put in a stack trace.
A preset may name at most 255 Lua functions in its templates, values and bindings together. Past that the name is ignored and a line is written to the log.
Parameters
Returns
parameterMap.setFunction(). The entry itself stays. Parameters
Returns
parameterMap.setFunction() bound. Parameters
Returns
Applying a patch dump is what this is for: a hundred and twenty-eight changes that would otherwise be a hundred and twenty-eight of everything, and - since the values set inside are not sent - no echo of the dump back to the instrument that sent it.
Transactions nest. An error inside one closes it before it is re-raised, so a script failing halfway through does not leave the map held down.
Parameters
Example
-- React to a parameter nothing on the screen shows.
-- setFunction creates the map entry, so parameterMap.set() and
-- parameterMap.get() work on this address afterwards.
if origin ~= LUA then
print("cutoff from the synth: " .. midiValue)
parameterMap.setFunction(1, PT_CC7, 74, "onCutoff")
endPatch
This library helps you request patch dumps and process SysEx MIDI messages that contain patch data. The patch.onResponse() function is called automatically when a SysEx message matches the response header you defined in the preset JSON.
To use patch callbacks, you must first create a Patch object in the Device object defined in your preset JSON.
The example below shows the simplest Patch setup. Here, patch.onResponse() will be triggered whenever a SysEx message begins with the bytes 67, 0, 0, 1, 27.
"patch":[
"responses":[
"id":1,
"header":[
67,
0,
0,
1,
27
]A response that also declares rules needs no script at all: the firmware puts the values the rules name straight into the parameter map.
Functions
It always runs in the script of the preset on the screen, on the application thread.
Parameters
It runs in the script of the preset that owns the device, so a pinned preset in the background hears its own responses. Only the first response whose header matches is used, and its rules have already been applied to the parameter map by the time the callback runs.
The SysexBlock is valid only while the callback runs. Take what you need out of it - getTable(), peek(), getBytes() - rather than storing the block.
Parameters
device:requestPatches() is the same call reached from the object.
Parameters
Example
A preset that asks a TX7 for its edit buffer and reads the answer. The device declares the request and the response header in its JSON; the script does the asking and the parsing.
local TX7 = 1
local VOICE_BYTES = 155
-- The dump is F0 43 0n 00 01 1B <155 bytes> <checksum> F7, and the device's
-- response header covers the first six bytes - so the voice data starts at
-- byte 7, counting from one as peek() and getTable() do.
local DATA_START = 7
-- Not in the main chunk: the callbacks below are defined by the time
-- onReady runs, and the map is ready to take values.
patch.request(TX7)
if device.id == TX7 then
print("asking " .. device:getName() .. " on channel " .. device.channel)
function patch.onResponse(device, responseId, sysexBlock)
if responseId ~= 1 then
return
if sysexBlock:getLength() < (DATA_START + VOICE_BYTES) then
print("short dump: " .. sysexBlock:getLength() .. " bytes")
return
local data = sysexBlock:getTable(DATA_START, VOICE_BYTES)
-- One change on the screen and nothing on the wire, however many
-- parameters move. Only parameters a control of this preset addresses
-- have an entry, so the rest are quietly skipped.
parameterMap.transaction(function ()
for i = 1, #data do
parameterMap.set(device.id, PT_SYSEX, i, data[i])
end)
info.setText("voice loaded")
endDevice data table
device = {
id = 1, -- a device Id
port = 0, -- a numeric port identifier, from zero
channel = 1, -- a channel number
interfaces = { "midiIo", "midiUsbDev", "midiUsbHost" },
}Every Device method can be called on it as well: device:getName(), device:sendProgramChange(4).
The runtime, by hand
Firmware 5.0 and later. What the firmware does to a SysEx message on its own - match a header, apply rules, fill a template - reachable from a script, for a message that came some other way: from a file, over the satellite link, on a port the device is not wired to.
Parameters
Returns
Parameters
Returns
A template with no placeholders that matches answers 0, 0.
Parameters
Returns
An empty array comes back for a template the firmware cannot render: one that contains an any placeholder, one that is ill-formed, and one longer than 511 bytes.
device:sendSysex() adds its own framing to an array, so hand it the body without the first and last byte:
local bytes = patch.render(device, { "43", "10", { type = "value" } })
if #bytes > 2 then
table.remove(bytes, 1) -- F0
table.remove(bytes) -- F7
device:sendSysex(bytes)
endParameters
Returns
SysEx byte function
A SysEx byte function is used in SysEx templates, patch requests, and patch response headers to calculate and insert bytes at specific positions within a SysEx message.
It is named in the preset JSON, as { "type": "function", "name": "..." }, and must be a global function in the preset's script. It is called every time the byte it stands for is rendered - on the way out for a message, and before a response header is matched - and returns one byte.
Example preset JSON
This example shows how a Lua function is used in both the patch request and the response header. Here, it is used to request and match a SysEx patch dump from a TX7 on a specific MIDI channel.
"devices":[
"id":1,
"name":"Yamaha DX7",
"port":1,
"channel":16,
"patch":[
"request":[
"43",
"type":"function",
"name":"getChannelByte"
"00"
"responses":[
"id":1,
"header":[
"43",
"type":"function",
"00",
"01",
"1B"
"rules":[
"type":"sysex",
"parameterNumber":1,
"byte":0
]The following snippet shows how to use the Lua SysEx byte function in the SysEx template.
"values":[
"id":"value",
"message":{
"type":"sysex",
"deviceId":1,
"data":[
"43",
"type":"function",
"00",
"66",
"type":"value",
"rules":[
"parameterNumber":102,
"bitWidth":5,
"byteBitPosition":0
"min":0,
"max":31
"min":0,
"max":31
]Functions
The last value the function returns is used. It is taken as an integer and masked to seven bits, so 0x93 goes out as 0x13. A return that is not a number, and no return at all, put a 0 in the message and write a line to the log.
The function runs on whichever thread is rendering the message - the MIDI thread for an outgoing message - so keep it short and do not send from it.
Parameters
Returns
Example
-- returns a byte that TX7 uses to identify the MIDI channel
function getChannelByte(device)
return (0x10 + (device:getChannel() - 1))
endPresets
The presets module is about presets as slots in the instrument - which one is on the screen, which ones keep running, and reaching one that is not yours. The Preset object is about what is inside a preset.
A preset is identified by a preset id: a slot in the whole instrument, counted as bank times the slots in a bank, plus the slot, with everything counted from zero.
| Electra One mk2 | 12 presets in a bank, 6 banks: ids 0 to 71 |
| Electra One Mini | 8 presets in a bank, 5 banks: ids 0 to 39 |
preset.getId() answers the id of the preset a script belongs to, which is what to pass rather than working one out.
Ids a Mini accepts but cannot show
The range check is the same on both models - 0 to 71 on an mk2, 0 to 47 on a Mini - while a Mini has only five banks. Ids 40 to 47 are accepted by presets.get(), presets.pin() and the rest, and no bank of the instrument holds them.
Presets that keep running
A preset is normally torn down the moment another one is loaded. Pinning it stops that: a pinned preset keeps its Lua state, its timer, its MIDI callbacks and its parameter map while something else is on the screen. That is what makes a background preset possible at all - an LFO or an arpeggiator that goes on running while another preset is performed, or a script that drives an external control surface whatever the player is doing.
A background preset can see the preset on the screen with presets.getCurrent(). The page and the control set are already global - pages.getActive() and pages.getActiveControlSet() answer for the screen and not for the caller - so between them a script can follow the instrument rather than drive it.
A script may read another preset's controls, but it may not hang callbacks on them: setPaintCallback() and the rest are refused on a control belonging to a different preset, because a callback registered in one Lua state cannot be called from another.
Functions
preset.getControls() and the rest always mean the script's own preset, even when it is running in the background. Returns
Preset(presetId) is the same thing written the other way. A slot that holds nothing answers an object for an empty preset rather than nil; <preset>:isLoaded() tells the two apart. An id outside the range raises.
Parameters
Returns
The switch is queued and happens on the application thread a moment later, not inside the call, so it is safe to call from a MIDI callback: the script goes on running to the end of the callback, and the preset changes after that.
The slot's pin is left as it was. Switching to a preset says nothing about whether it should keep running afterwards; presets.pin() is how a script says that.
-- A pad on a plugged-in controller, stepping through a set list.
local setList = { 0, 3, 7, 12 }
local at = 1
function midi.onNoteOn(midiInput, channel, noteNumber, velocity)
if noteNumber == 36 then
at = (at % #setList) + 1
presets.switch(setList[at])
endParameters
Returns
This is the run-time pin. It is not written to the configuration, so it does not survive a reboot, and the pin marking in the preset list is not changed by it.
Parameters
Returns
Parameters
Returns
Example: a preset that follows the one on the screen
The idea behind presets.getCurrent(): a preset that pins itself, runs in the background, and reports what is under the instrument's knobs. Everything it reads belongs to a preset it knows nothing about.
-- Without this the script is torn down as soon as the player changes
-- preset, which is exactly when it has most to say.
presets.pin(preset.getId())
timer.setPeriod(500)
timer.enable()
local lastSeen = ""
function timer.onTick(ticks)
local shown = presets.getCurrent()
if not shown then
return
-- The page and the control set are the screen's, not this preset's.
local pageId = pages.getActive():getId()
local controlSet = pages.getActiveControlSet()
local line = shown:getName() .. " page " .. pageId .. ":"
for potId = 1, 8 do
local control = shown:getControlByPot(pageId, controlSet, potId)
if control then
local value = control:getValue(control:getValueIds()[1])
-- getText() is the string the instrument is itself showing -
-- a formatter's output, an overlay's label. It is empty for a
-- value that declares no formatter, so fall back to the number.
if text == "" then
line = line .. " " .. control:getName() .. "=" .. text
if line ~= lastSeen then
lastSeen = line
print(line)
endNote
A background preset's timer runs on the application thread, which the display shares. Walking every control of every page at a display rate is enough to make the instrument slow to repaint its own screen. Do the expensive walk when the layout changes - a preset switch, a control set change - and keep the steady state cheap.
It answers false rather than raising for a slot that cannot be written: the slot on screen, a running slot, or an occupied one without replace.
Application thread only.
Parameters
Returns
Its script runs as on any load, preset.onEnter() included, although nothing of it is shown. Raises when the slot cannot be read, and when it is called off the application thread.
Parameters
Returns
Preset
The preset library offers functions and callbacks to manage events that happen when working with presets.
What the preset is
Returns
Returns
Returns
Counted from zero, because that is the identifier the File Transfer API, the slot paths and the archive formats all use.
Returns
Returns
Returns
Example
print(string.format("%s (%s) in bank %d slot %d",
preset.getName(),
preset.getProjectId(),
preset.getBank(),
preset.getSlot()))
endWhat is in the preset
These return the objects the preset is made of. Every collection is a dense array - there are no holes in it, so # is the count and ipairs reaches the end - and it is ordered by ascending id. preset.getPages() is the one exception, and says so below.
Groups are controls
A group is a control in the firmware: it lives in the same collection, shares the same id space, and sits on a page like anything else. So preset.getControls() returns groups too, each with the methods of what it actually is - a group in the array answers getLabel(), a control answers getName(), and both answer getName() and isGroup().
Use preset.getGroups() when you want only the groups.
Returns
Parameters
Returns
Return false from the callback to stop the walk. Returning nothing carries on, so the usual case needs no return statement at all.
The callback is not run in a pcall: an error in it is an error in the call.
Parameters
Returns
Returns
Parameters
Returns
Parameters
Returns
Returns
Parameters
Returns
Returns
Parameters
Returns
Parameters
Returns
It is not a dense array of the preset's pages. A slot the preset does not define holds a placeholder Page object whose getId() is 0, so # is the model's page count and a walk has to skip them:
for _, page in ipairs(preset.getPages()) do
print(page:getId() .. " " .. page:getName())
endpreset.getPage(id) is the dense sibling: nil for a page that is not there.
Returns
Example: renaming every control on a page
-- Groups are in the array too, so skip them: a group's name is its label.
for _, control in ipairs(preset.getControlsOnPage(1)) do
if not control:isGroup() then
control:setName(control:getName():upper())
endExample: walking without allocating
-- eachControl builds no table, so this is the form to use on a timer tick.
local visible = 0
preset.eachControl(function (control)
if control:isVisible() then
visible = visible + 1
end)
info.setText(string.format("%d visible", visible))
endExample: stopping early
-- Returning false stops the walk. This finds the first fader and leaves the
-- rest of the preset unvisited.
local firstFader
if not control:isGroup() and control:getType() == "fader" then
firstFader = control
return false
end)Controls, narrowed
Parameters
Returns
Parameters
Returns
Parameters
Returns
Groups are not included: a group is on a page but in no control set.
A control set id outside 1 .. 3 raises. How many sets a page really uses depends on the model and on the preset - a Mini works one set - so a set that exists but holds nothing answers an empty array.
Parameters
Returns
Parameters
Returns
It is a function of its own rather than a default for getControlsInSet() because the same call would otherwise mean different things as the user navigates.
The page and the set are the screen's, always. A background preset asking this gets its own controls that happen to sit on the page and set the screen is showing.
Returns
A pot id outside the range raises. A Mini has eight knobs and four hardware buttons that act as pots 9 to 12.
Parameters
Returns
Example: labelling the knobs the user can see
-- The controls in front of the user, whichever page they are on.
events.subscribe(PAGES)
function events.onPageChange(newPageId, oldPageId)
local names = {}
for _, control in ipairs(preset.getActiveControls()) do
table.insert(names, control:getName())
info.setText(table.concat(names, " "))
endExample: dimming a knob's control
-- Knob 3 of the second control set on page 1.
local control = preset.getControlByPot(1, 2, 3)
if control then
control:setColor(0x808080)
endPreset objects
Every function above is also a method on a Preset object, so a script can address a preset other than its own:
local other = Preset(4)
print(other:getName(), #other:getControls())preset.getControls() and myPreset:getControls() are the same call; the module form means the preset the script belongs to.
Lifecycle callbacks
Five callbacks, in the order the firmware runs them. All of them are optional, all of them run on the application thread, and an error in one is written to the log and does not stop the load.
A preset being read into a slot - switching to a slot whose preset is not in memory, a reload, presets.load():
- Whatever ran in the slot before is ended:
preset.onExit(), then its timer, MIDI callbacks, transport listeners, router link and data pipes are undone. - The preset file is read. Pages, devices, overlays, groups and controls are built, every control value registers its parameter map entry, and the saved map is recalled - so the values are in place before any script runs.
- The script runs: the main chunk, top to bottom.
- The
midi.*callbacks the chunk defined are registered. Amidi.onXdefined later - inonLoad, in a timer, in another callback - is never registered. preset.onLoad().- The initial Lua pass over the parameter map: the value functions and formatters bound to values run for the first time.
preset.onReady().preset.onEnter().
Coming back to a preset that is already in memory - a pinned preset, or the slot that is already loaded: the callbacks are rebound and preset.onEnter() runs. Nothing else of the list above happens.
Leaving the preset on the screen: preset.onLeave() runs on the preset going off, pinned or not. A preset that is not pinned then stops: its timer is suspended and its MIDI callbacks are removed. A pinned one keeps running.
The end of a Lua state: preset.onExit() runs whenever the state is closed - when the slot is reset, another preset is loaded into it, the preset is reloaded, a new script is uploaded over SysEx, or the preset is removed.
The controls, devices, pages and values all exist here, and the parameter map already holds what the file and the recalled map gave it. What has not happened yet is that first pass, so the value functions and formatters have not run. Start-up work that depends on them belongs in preset.onReady().
This is where a script's own set-up belongs - pinning itself, starting a timer, asking for a patch, subscribing to events.
It also runs on a load that shows nothing - presets.load() and a background reload - so a script must not take it as proof that its preset is on the screen:
function preset.onEnter()
if shown and shown:getId() == preset.getId() then
info.setText("here we are")
endA preset that is not pinned stops running right after this: stop notes, release what has to be released, here.
It is the last Lua that runs in that state. It is not called when the user merely switches to another preset and this one keeps running.
Tables
preset.userFunctions table holds custom Lua functions that can be triggered from the Preset Menu on the Electra One controller. Each function is assigned to one of the predefined keys: pot1 through pot12 on an Electra One mk2, pot1 through pot8 on a Mini. These correspond to the on-screen buttons in the Preset Menu and match the layout of the physical knobs.
Each entry is a table that defines:
call– The Lua function that will be executed when the button is triggered. It is called with no arguments.name– The label that will appear on the on-screen button.close– A boolean value that, when set to true, causes the Preset Menu to close after the function has been executed. This field is optional.
An entry with a name and no call shows a button that does nothing; an entry with a call and no name runs but is not labelled, so give every entry both.
Only the assigned slots will be displayed in the menu. Buttons with a user function appear in blue.
How a function is triggered:
| mk2 | tapping the on-screen button; touching the knob under it when Settings → Interface → Pot Touch Selections is on |
| Mini | pressing the knob under the button while the Preset Menu is open |
| both | the commands runUserFunction1 .. runUserFunction12, so a function can be put on a hardware button or run from a script with commands.run() |
The table is read when the Preset Menu is opened, so a script may change it at any time.
Example
-- Register the functions for use in the Preset Menu
preset.userFunctions = {
pot1 = {
call = printHello,
name = "Hello",
close = true
pot2 = {
call = printHi,
name = "Hi",
close = false
pot8 = {
call = printGoodBye,
name = "GoodBye",
close = false
}Editing a preset from Lua
Firmware 5.0 and later. A preset - the caller's own, or any slot's reached through presets.get() or presets.load() - is a document a script can read whole, build, change, save and reload. Everything is built on one rule:
The Lua table shape is the preset file shape. Every create takes a table with the keys the .epr object has, and every toTable() hands the same shape back. A table goes through the same reader the file goes through, so the same defaults are folded in; an object comes back through the same writer, so what a script sees is what the file would say. Ports count from one in a table, as in the file. There is no second vocabulary.
Every module verb has a twin on the preset object, and the twins are how one preset builds another: controls.create(t) is preset:createControl(t) on the caller's own preset; target:createControl(t) does the same in target.
Each of the functions below is written as a method - target:save() - and each of them has the module form as well: preset.save(), preset.createControl(t), preset.setScript(text). The module form always means the preset the script belongs to.
-- An installer: a device with its patch definitions, and a control for it,
-- in another slot.
local rules = { { type = "sysex", parameterNumber = 135, byte = 0 } }
local target = presets.load(11)
target:setName("DX7 II")
target:createDevice { id = 1, name = "DX7", port = 1, channel = 1,
responses = { { id = 1, header = { "F0", "43", "00", "00", "01", "1B" },
rules = rules } } } } }
target:createControl { pageId = 1, controlSetId = 1, type = "fader", name = "ALGORITHM",
slot = 1, inputs = { { potId = 1, valueId = "value" } },
values = { { id = "value", min = 1, max = 32,
message = { deviceId = 1, type = "sysex", parameterNumber = 135,
min = 0, max = 31,
data = { "F0", "43", "10", "01", "06", { type = "value" }, "F7" } } } } }
if target:save() then target:reload() endThe rules:
- Definitions cross; behaviour does not. Templates, rules, messages, events and function names are data and land in the target. A function, a paint callback or a pot callback is behaviour bound to one Lua state, and setting a callback on another preset's control is refused.
setScript()is how behaviour travels: an editor names functions in templates and values and ships the script that defines them. - The application thread only. Every
createandremove, andsave(),reload(),setScript(),setName(),setProjectId(),presets.create()andpresets.load(), raise when they are called from a timer or a schedule callback. Call them frompreset.onReady, a control callback, a command or a patch hook. A few smaller setters -setVersion(),presets.pin(), the Page setters - do not check, and belong on the application thread all the same. - Saving is explicit. Edits live in memory until
save(). A target on screen repaints the affected control at once; a background one has no components and needs nothing; a reload is only needed when the script changed, and a background target reloads without the screen moving. - Limits. 432 controls a preset, 32 devices, 255 names in the Lua function registry, response headers of at most 64 bytes, rendered templates of at most 511 bytes.
Parameters
Returns
Returns
Returns
Returns
Given a path, the document is written straight to that file: no temporary file, and the preset list is not touched.
Parameters
Returns
Returns
Parameters
Parameters
Parameters
Returns
Parameters
Returns
Parameters
Returns
Parameters
Returns
Parameters
Returns
Parameters
Returns
Parameters
Returns
Parameters
Returns
Parameters
Returns
Example: a preset that edits itself
A user function that gives every device of the preset a volume fader on page 1, then saves. Nothing is reloaded: the controls are in memory and on the screen already, and the script has not changed.
function buildVolumeFaders()
local slot = 1
for _, device in ipairs(preset.getDevices()) do
-- One per device, and only the ones that are not there yet.
local id = 900 + device:getId()
if not preset.getControl(id) then
preset.createControl {
id = id,
type = "fader",
name = device:getName(),
pageId = 1,
controlSetId = 1,
slot = slot,
inputs = { { potId = slot, valueId = "value" } },
values = { { id = "value", min = 0, max = 127,
message = { deviceId = device:getId(),
type = "cc7",
parameterNumber = 7,
min = 0, max = 127 } } },
slot = slot + 1
if preset.save() then
info.setText("faders saved")
else
info.setText("save failed")
-- The Preset Menu runs it, which is the application thread: preset editing
-- raises from a timer.
pot1 = { name = "FADERS", call = buildVolumeFaders, close = true }
}The router table
A preset may carry a router.lua beside its script - a separate sandbox that sees every MIDI message before the preset does. The preset-side router table is how the script talks to it.
router.set(name, value) | Sets one of the parameters the router's init() declared. A number or a boolean; a boolean is passed on as 1 or 0. Raises when the preset has no router, or the router has no parameter of that name. |
router.get(name) | That parameter's value as a number, or nil. |
router.params() | Every parameter as a table of name to number; empty when there is no router. |
router.isActive() | Whether a router is loaded for this preset. |
router.reload() | Reads router.lua again and starts it over. The parameters go back to what init() declares. Answers true. |
The router talks back by calling a global function in the preset script:
function onRouterEvent(name, value)
if name == "overflow" then
info.setText("router dropped something")
endThe name is at most 20 characters and the value is a number. Events are queued, and the queue holds 32 of them.
The router script itself - what it can do, what init() looks like, the budget it runs under - is documented in Router Lua.
Events
The Events library lets you control which notifications Electra One sends out and define callback functions to handle those events.
A subscription is one byte, shared by the Lua callbacks and the SysEx event notifications the controller sends out. It is global to the instrument, not to the preset: it is not reset when the preset changes, and the last script to call events.subscribe() decides what everybody gets.
| Flag | Value | What it turns on |
NONE | 0 | nothing |
PAGES | 1 | events.onPageChange() and the page SysEx notification |
CONTROL_SETS | 2 | the control set SysEx notification; no Lua callback |
USB_HOST_PORT | 4 | events.onUsbHostChange() |
POTS | 8 | events.onPotTouchChange(), events.onPotTouch() and the pot touch SysEx notification |
TOUCH | 16 | reserved; drives no Lua callback |
BUTTONS | 32 | reserved; drives no Lua callback |
WINDOWS | 64 | reserved; drives no Lua callback |
The callbacks go to the preset on the screen
events.onPageChange(), events.onPotTouchChange() and events.onUsbHostChange() are called in the script of the preset the controller is showing. A pinned preset running in the background does not hear them. pages.onChange() has the same rule, and needs no subscription at all.
Functions
The call replaces the whole subscription rather than adding to it, so pass everything the preset wants in one call.
Parameters
Parameters
It runs only when PAGES has been subscribed to - events.subscribe(PAGES) - and only in the preset on the screen. pages.onChange(new, old) is the same notification without the subscription.
Parameters
Needs POTS in the subscription.
Parameters
Parameters
The notification is handed to the application thread rather than run on the USB thread, so it arrives a moment after the event - and it is dropped when the command queue is full. Do not count on it for anything that must not be missed.
What was plugged in is not passed to the callback. When a USB device switches the controller to a preset through the USB host assignments, that preset's script is started with a global table usbHostDevice describing it:
-- usbHostDevice = { vid, pid, manufacturer, product, serial, port }
if usbHostDevice then
print("started by " .. usbHostDevice.product)
endIt is set before the script's main chunk runs, only on that path, and it is never updated afterwards - so it says what started the preset, not what is plugged in now.
Parameters
Example
-- Watching the pages and the knobs
events.subscribe(PAGES | POTS)
events.setPort(PORT_CTRL)
print("old: " .. oldPageId)
print("new: " .. newPageId)
function events.onPotTouchChange(potId, controlId, touched)
print("potId: " .. potId)
print("controlId: " .. controlId)
print("touched: " .. (touched and "yes" or "no"))
endInfo
The Info library lets you show custom text messages in the status bar at the bottom of the screen.
The text belongs to the preset slot on the screen, and it is at most 20 characters: anything longer is cut. It survives until something else writes there.
Functions
This is how a script talks to the user. print() goes to the logger, which is off unless somebody is listening on the control port; the status bar is on the instrument.
Parameters
Example
-- Display an info text
info.setText("Hello world")Returns
Example
-- Retrieve an info text
print("Text shown: " .. info.getText())Commands
The commands module runs one of the instrument's own actions by name - the same actions a hardware button, a MIDI control mapping or a preset override can be given. Commands.inc is the one list behind all of them, so anything that can be put on a button can be run from a script.
This is what lets an external control surface reach the instrument's user interface without the firmware knowing anything about that surface: a pad on a plugged-in controller can open the snapshots window, step to the next page, or toggle the performance page, because the script in the preset turns the pad into a command name.
Parameters follow the configuration file's convention rather than the command queue's, because that is the convention the names come with: a preset, a page and a control set are counted from one.
Functions
commands.exists() when the name came from somewhere else, and when the parameter is out of range for that command. Parameters
Returns
Parameters
Returns
Returns
Example
-- A row of pads on a plugged-in controller, driving the instrument itself.
local pads = { [1] = "openSnapshots",
[2] = "openCaptures",
[3] = "switchPagePrev",
[4] = "switchPageNext",
[5] = "togglePerformancePage" }
local command = pads[noteNumber - 35]
if command and commands.exists(command) then
commands.run(command)
end-- Commands that take a parameter count from one, the way the configuration
-- file does: this is page 3, not the fourth page.
commands.run("switchPage", 3)
commands.run("switchControlSet", 1)
-- The Preset Menu's user functions have commands of their own.
commands.run("runUserFunction1")Four ways of making something happen later
A preset script never runs on its own. It runs when the controller calls it: when a knob is turned, when a MIDI message arrives, and - for everything on this page - when a time comes round.
| what it is | when the function runs | precision | |
timer | one periodic callback per preset | application thread | the period is kept in microseconds and never drifts; delivery is to the millisecond |
schedule | any number of one-shot and repeating functions, each with its own clock | application thread | the same, and a function that finds the thread busy is run as soon as it is free |
transport | callbacks and cues driven by MIDI clock, incoming or the controller's own | application thread, a few milliseconds after the clock byte | the beat is exact, the callback is not |
midi.at() | a send held back until a named millisecond | the MIDI schedule thread, the highest priority there is | the message leaves on the millisecond it names, whatever the application thread is doing |
The application thread is the one that also builds pages, reads the knobs and runs every other preset's script. So a callback on it is called within a millisecond or two when the controller is idle, and tens of milliseconds late while a page is being built or a window is opening.
That is the rule worth learning first: work out when something is due, then hand the message to midi.at(). A sequencer that waits until a note is due before sending it is already late by however long its own callback took. One that works a tick ahead and gives midi.at() the time is exact.
Which one to use
A steady tempo - an LFO, a step sequencer, a clock - is a timer. Anything with its own delay - a request sent 200 ms after the preset loads, a value sent once a knob has stopped moving - is schedule. Anything that has to follow the studio's tempo is transport.
Timer
The timer runs one function, timer.onTick(), over and over at a period the preset sets. It is what an LFO, a step sequencer or a display that refreshes itself is built on.
Every preset slot has its own timer, and it runs while that preset runs: on the screen, or pinned behind another preset. A preset that is left without being pinned has its timer suspended - it stops ticking, keeps its period, and starts again when you come back to the preset.
A new preset's timer is disabled, with a period of 500 ms - one tick per beat at 120 BPM - so timer.enable() on its own ticks twice a second. Set the period or the tempo before enabling it if you want anything else.
How exact it is
The schedule is a deadline on the millisecond clock, moved on by exactly one period from the previous deadline rather than from when the callback happened to run. The time the callback spends working is absorbed instead of being added to the next interval, so the tempo does not drift: a minute at 120 ticks a second is 7200 ticks. The period is kept in microseconds, so a tempo whose period is not a whole number of milliseconds - 200 BPM at 24 clocks to the beat is 12.5 ms - averages out exactly. Nothing finer than a millisecond can be delivered, because the application run loop turns at 1 kHz.
Two things can cost a tick, and they are counted separately:
- a tick that falls a whole period or more behind is given up on, because calling the script once for every missed tick would be worse than the gap.
timer.getSkippedTicks()counts them. - a tick that finds the preset's Lua state busy - the LCD thread is inside it for as long as a custom control's paint callback takes - is dropped rather than waited for.
timer.getContendedTicks()counts them.
Neither is forgotten. The next call's ticks argument says how many periods it stands for, so a script that counts ticks keeps its place in time.
A callback that never returns
A timer.onTick() that has not returned after ten seconds is stopped, the timer is disabled, and a problem is shown in the bottom bar. Fix the function and call timer.enable() again. Holding the six main buttons together for two seconds stops every preset's timer, and clears every preset's schedule, the same way.
Functions
The period is not changed. Raises when the script has no preset slot to time.
timer.isSuspended(). Returns
Returns
Setting the period restarts the schedule from now, so a script changing tempo on every knob movement restarts the beat each time. It also clears getMaxDurationUs(), getFailedTicks() and the load - a new period is a new question about whether the callback fits.
Parameters
Returns
Parameters
Returns
One tick a beat is rarely what a sequencer wants. Multiply for finer steps - timer.setBpm(120 * 4) is a sixteenth note at 120 BPM - or use timer.setClockBpm() for a MIDI clock.
Parameters
Returns
setPeriod() cannot express most of these tempos - 200 BPM is 12.5 ms - which is why this exists.
For a steady clock, prefer the controller's own clock generator - see The controller's own clock. It runs on a higher priority thread and keeps time while a script is working.
Parameters
Returns
Returns
Returns
Returns
A preset that does variable work can read this and do less.
Returns
Returns
A script that ignores the argument behaves as it always did. One that counts ticks - a sequencer, an LFO with a phase - should add ticks rather than 1, or it loses time whenever the controller is busy.
Anything a script may do at all may be done here, with two exceptions: controls.create(), groups.create() and <control>:update() raise from a timer, and window.repaint() from a fast timer starves the application thread - repaint the control instead, with <control>:repaint().
Parameters
Example: an LFO
-- A triangle LFO on CC 74 of device 1, fifty steps a second.
-- parameterMap.set() moves the control that owns the parameter and sends the
-- message, so the preset needs a control on CC 74 of device 1 for anything to
-- happen. The value has to be an integer: helpers.map() answers a float, and
-- a float raises here.
local phase = 0
local steps = 50
function preset.onReady ()
timer.setPeriod(20)
timer.enable()
function timer.onTick (ticks)
phase = (phase + ticks) % steps
local position = phase / steps
local triangle = (position < 0.5) and (position * 2) or (2 - position * 2)
parameterMap.set(1, PT_CC7, 74, math.floor(triangle * 127 + 0.5))
endExample: a step sequencer
-- Eight steps at 120 BPM, one tick per sixteenth note.
-- The notes are not sent when the tick runs: the tick works out the
-- millisecond each note is due and hands it to midi.at(), so the notes leave
-- on time even while the controller is busy drawing a page.
local steps = { 60, 63, 67, 70, 72, 70, 67, 63 }
local step = 0
local gate = 0.5 -- of a step
local lookAhead = 20 -- milliseconds of head start
timer.setBpm(120 * 4) -- one tick per sixteenth
timer.enable()
local period = timer.getPeriod()
local now = schedule.now()
-- One pass per period this call stands for, so a tick lost while a window
-- was opening does not cost the pattern its place.
for i = 1, ticks do
local note = steps[(step % #steps) + 1]
-- Everything is worked out a little ahead of when it is due and
-- handed to midi.at(), which sends it on the millisecond named.
local at = now + lookAhead + (i - 1) * period
midi.at(at)
midi.sendNoteOn(PORT_1, 1, note, 100)
midi.at(at + math.floor(period * gate))
midi.sendNoteOff(PORT_1, 1, note, 0)
step = step + 1
midi.at() -- send at once again
endSchedule
timer.onTick is one callback with one period, and everything else a preset wanted to happen later - a delayed request, a message sent after a knob stops moving, a second LFO - had to be multiplexed into it by hand. schedule queues functions to run once after a delay or repeatedly at an interval, each with its own clock. A preset may have thirty-two of them queued at once.
Scheduled functions run on the application thread, between passes of its run loop, so they may do anything a timer.onTick may. They run under the same guard: a function that has not returned after ten seconds is stopped, and everything that preset had scheduled is dropped with it. They run while the preset runs - on the screen, or pinned behind another preset - and wait while it is not. timer is unchanged; presets that use it are unaffected.
schedule.whenNotes() is here too: not a delay but a trigger, run when a combination of notes is held down on a device.
Functions
Raises when nothing more can be queued - a preset may have thirty-two things scheduled at once. A nil among the extra arguments can truncate the ones after it; pass false or a placeholder instead.
Parameters
Returns
A repeating function that raises an error is dropped rather than left to raise again on every pass.
Parameters
Returns
A function may cancel itself from inside its own call.
Parameters
Returns
Returns
pending | how many functions are queued now |
ran | how many have run to the end since the preset was loaded |
errors | how many raised |
worstOverrun | the latest any of them ever ran, in milliseconds after it was due |
capacity | how many may be queued at once - 32 |
whenNotes | how many whenNotes() triggers are set |
Returns
<device>:getActiveNotes() gives them. It fires on the change to the notes that makes them match, and not again until a change has made them stop matching. A chord held down fires once, however many other keys come and go meanwhile, and fires again the next time it is played. A trigger set while its notes are already held fires on the next change that still leaves them matching.
The options, all optional:
device | a Device, or a device id (0 .. 62): only that device's notes. Left out, every device of the preset, each on its own |
exact | true: these notes and no others. Left out, at least these notes - others may be held too |
anyOctave | true: notes by name, so a C is any C. { 60, 64, 67 } then matches C, E and G in any octave and any inversion |
anyKey | true: the same shape on any root. { 60, 64, 67 } then matches any major triad in root position; with anyOctave too, any major triad at all |
minVelocity, maxVelocity | every note of the match has to have been pressed within this range (0 .. 127). Default 0 and 127; a minimum above the maximum raises |
within | milliseconds (0 .. 60000): the notes of the match have to have been pressed at most this far apart - struck together, not one after another |
once | true: the trigger is removed once it has fired |
onRelease | function(device, notes), run when a match ends - the change that makes the notes stop matching |
The function is handed the device, its notes, and the match:
notes | the held notes that make the match, lowest first |
root | the held note playing the first note of notes - the chord's root, when that is the note listed first |
transpose | how many semitones the notes had to be moved to match: 0 unless anyKey, and 0 to 11 with anyOctave |
velocity | the average velocity of the notes of the match |
spread | milliseconds between the first and the last press of the notes of the match |
A preset may have thirty-two triggers set at once; whenNotes() raises when there is no room for another. A trigger whose function raises an error is removed, as a repeating scheduled function is. schedule.cancel() takes one back.
Triggers run the way <device>:onNotesChanged() does: on the application thread, a few milliseconds after the note that makes the match reaches the input, and while the preset runs - on the screen, or pinned behind another. A preset that is not pinned stops matching when you leave it, and starts again, with the same triggers, when you come back.
Parameters
Returns
Example
-- Ask for a patch a moment after the preset is ready
schedule.after(200, patch.requestAll)
-- An LFO of its own, without touching timer.onTick. parameterMap.set() takes
-- an integer, so the float helpers.map() answers is floored.
local phase = 0
lfo = schedule.every(20, function ()
phase = (phase + 1) % 100
math.floor(helpers.map(phase, 0, 99, 0, 127)))
end)
-- Send a value only once the knob has stopped moving. As a control's value
-- function this is called with (valueObject, value).
local pending
function onCutoff (valueObject, value)
if pending then
schedule.cancel(pending)
pending = schedule.after(150, midi.sendControlChange, PORT_1, 1, 74, value)
endExample: reacting to chords and hits
local pads = devices.get(2)
-- C major, and nothing else, on the keyboard.
schedule.whenNotes({ 60, 64, 67 }, function (device, notes, match)
print("C major, velocity " .. match.velocity)
end, { device = keys, exact = true })
-- Any minor triad, in any inversion and octave: tell the arpeggiator its root.
schedule.whenNotes({ 60, 63, 67 }, function (device, notes, match)
midi.sendControlChange(PORT_1, 16, 20, match.root % 12)
end, { device = keys, anyKey = true, anyOctave = true, exact = true })
-- Kick and snare, hit hard and together, on the pads: a crash cymbal.
schedule.whenNotes({ 36, 38 }, function (device, notes, match)
midi.sendNoteOn(PORT_1, 10, 49, match.velocity)
end, { device = pads, minVelocity = 100, within = 30 })
-- Mute while the lowest C is held down, and unmute when it is let go.
schedule.whenNotes(24, function ()
parameterMap.set(1, PT_CC7, 7, 0)
end, { device = keys, onRelease = function ()
parameterMap.set(1, PT_CC7, 7, 100)
end })Transport
The transport library works like the timer but does not generate its own tick. It follows MIDI real time and clock messages - from an instrument or a DAW on one of the inputs, or from the controller's own clock generator - so that a script can stay in sync with whatever else is playing.
There are three separate things here, and only the first needs transport.enable():
- the callbacks,
transport.onClock()and the rest, one for each real time message. They have to be switched on withtransport.enable(). - reading the clock -
getBpm(),getSongPosition(),getStatus(),getClock()- which works whether or not any preset asked, because the controller measures every input's tempo all the time for the status bar. - sending a clock of the controller's own, at a tempo the preset sets.
Functions
Two rules follow from how they are registered, and a script that does not know them looks broken:
- Each callback has to be defined before
transport.enable()runs. Only the functions that exist at that moment are registered; one defined later - insidepreset.onLoad(), in a timer - is never called. Define them at the top level of the script and enable the transport inpreset.onReady(). - One preset at a time holds each callback. The first preset to ask gets it, and another preset asking for the same one is ignored until the first stops running. Leaving a preset without pinning it hands its callbacks back.
Coming back to a preset that was left does not run its script again, so call transport.enable() in preset.onEnter() if the preset has to keep its transport callbacks across a switch.
Returns
The tempo of the incoming clock
MIDI clock is twenty-four bytes to the quarter note and carries no tempo of its own - the tempo is how fast they arrive, which means measuring it. The controller does that for every input, all the time, whether or not a preset asked: the status bar shows which input is clocking and beats with it, so a script asking for the tempo is given the answer that is already there.
None of the functions below needs transport.enable(). That switches the transport callbacks on and is unchanged.
More than one thing on the desk can be sending clock
So the tempo is kept per input rather than as one number the last cable plugged in gets to define. transport.getBpm() and transport.getSongPosition() answer for the one input that "the clock" means, transport.getClocks() lists them all, and transport.setClockSource() pins the choice.
nil rather than zero when nothing is clocking, and also for the first beat after a clock starts - a tempo is measured over a whole beat, so there is nothing to answer until one has gone by. A display should show a dash rather than a number.
While the controller is sending a clock of its own, this is that clock's tempo, exact from its first clock - see The controller's own clock below.
Returns
The controller keeps it the way a sequencer following the same clock would. A Start puts the song at 0, a Song Position Pointer puts it wherever it says, and while the transport runs the clock carries it on by one every six clocks. A Stop holds it, and a Continue plays on from it. Clock that keeps arriving with the sequencer stopped does not move it.
It answers for the same input as getBpm(). A position means something without a clock, though - a sequencer usually sets it with a Song Position Pointer while stopped, before it sends any clock - so when nothing is clocking it answers for the input that most recently said where the song is.
nil until some input has sent a Start, a Continue or a Song Position Pointer.
Returns
A transport that was playing and whose clock has since stopped arriving - for the couple of seconds after which an input counts as no longer clocking - reads "stop" too: a sequencer that is switched off or unplugged sends no Stop on its way out. One started ahead of its first clock plays, however long that clock takes.
It answers for the same input as getBpm(). With nothing clocking, it answers for the input that most recently sent a Start, a Continue or a Stop - a sequencer sends Start before its first clock. nil until some input has sent one of them.
Returns
The function runs on the clock that plays that beat. The first clock after a Start plays beat 0, the first after a Continue plays the beat the song was put at, and every sixth clock after that plays the next one. It is handed the position, and it runs every time the song gets there - after a Song Position Pointer sends the song back, or a Start begins it again. Only while the transport runs: a stopped song reaches nothing, however much clock keeps arriving. And only the clock getClock() answers for counts, so pin it with setClockSource() when more than one input is clocking.
There is one function per position: setting another replaces it, and nil removes it. A function that removes its own position runs once. None of this needs transport.enable().
Cues belong to the preset, and fire while it runs: while it is on the screen, and also while it is pinned and another preset is showing. A preset that is not pinned stops hearing them when you leave it, and has them again when you come back - unlike the transport callbacks, cues are kept in the preset's own state and are found again by themselves.
It runs on the controller's application thread, a few milliseconds after the clock that plays its beat reaches the input. To send something exactly on a later beat, work out when it falls from getBpm() and hand it to midi.at().
Parameters
interface | the MIDI interface the clock is arriving on; absent for the controller's own clock |
port | the port on it; absent for the controller's own clock |
internal | true when it is the controller's own clock - see The controller's own clock below; absent otherwise |
bpm | the tempo, 0 until a whole beat has been measured |
isRunning | a start or continue arrived and no stop since |
ticks | clocks counted since that start |
songPosition | where the song is, in MIDI beats, as getSongPosition() counts it; absent until the input has sent a start, continue or song position pointer |
status | "play", "continue" or "stop", as getStatus() says it for this input; absent until the input has sent a start, continue or stop |
isRunning is a separate question from whether the input is clocking: plenty of instruments send clock continuously with the sequencer stopped.
Returns
Returns
Returns
Left unpinned, the controller chooses: the input that most recently had its transport started, because pressing play is the clearest statement of which clock is being played; failing that, the one that ticked most recently. A pinned input that has gone quiet is not a way to have no clock - the choice falls back rather than the answer disappearing.
Parameters
Returns
Example
-- Show the incoming tempo on a control, once a second. The preset needs a
-- control named by id 220; a name is text, so it is set on the control
-- rather than pushed through the parameter map.
timer.setPeriod(1000)
timer.enable()
local bpm = transport.getBpm()
controls.get(220):setName(bpm and string.format("%.1f BPM", bpm) or "--")
-- Follow whichever instrument is playing, and say when it stops. onStop has
-- to exist before transport.enable() runs, so define it at the top level.
function transport.onStop (midiInput)
print("stopped; last tempo was " .. tostring(transport.getBpm()))
transport.enable()
-- Light a pad while the song plays, whether it was started or continued.
function showTransport ()
local status = transport.getStatus()
parameterMap.set(1, PT_VIRTUAL, 2,
(status == "play" or status == "continue") and 127 or 0)
-- Bar and beat of the song, in 4/4: sixteen MIDI beats to a bar.
function showPosition ()
local position = transport.getSongPosition()
if position then
local bar = position // 16 + 1
local beat = (position % 16) // 4 + 1
print(string.format("bar %d, beat %d", bar, beat))
-- A crash cymbal on the first beat of every fourth bar from bar 5.
for bar = 5, 33, 4 do
transport.atSongPosition((bar - 1) * 16, function (position)
midi.sendNoteOn(PORT_1, 10, 49, 110)
end)
endThe controller's own clock
The controller can also send a MIDI clock: twenty-four clocks to the quarter note, at a tempo a preset sets, to the outputs it names. There is one such clock for the whole controller, not one per preset, and it belongs to the preset that started it - see Whose clock it is.
It is generated by the controller's highest priority thread, not by Lua and not by the thread that builds pages, so it keeps time while the screen is busy or a script is working. Each clock lands on the millisecond it falls in, and the error does not add up: a minute at 120 BPM is exactly 2880 clocks. On a MIDI output a clock goes ahead of anything queued there, SysEx included, so a long dump does not hold it up.
Once enabled it clocks continuously, stopped or playing, as most hardware sequencers do, so a receiver can lock to the tempo before it is asked to play. Start, Continue and Stop go out immediately before a clock, so the clock after a Start is the first clock of the song.
Another clock wins
While a clock is arriving on any input the controller follows that one, and its own sends nothing: transport.isClockAvailable() says false. It carries on by itself a couple of seconds after the input goes quiet.
Whose clock it is
The clock belongs to the preset whose script last called transport.enableClock(), startClock(), continueClock() or setClockOutputs(). It lasts as long as that preset runs, and ends when the preset:
- is removed from its slot,
- is replaced - another preset uploaded into the slot, or a new script into the preset,
- is reloaded,
- is left for another preset slot, unless it is pinned. A pinned preset keeps running in the background, and keeps its clock,
- is unpinned while it runs in the background.
Ending it sends a Stop if the song was playing, then no more clocks: the clock is disabled, sends to no outputs and is back at 120 BPM, as if nothing had ever set it. A reloaded script starts from the top, so one that enables the clock as it loads has it again straight away. Coming back to a preset that was left does not run its script again; to have the clock back then, enable it in preset.onEnter().
Loading, removing, reloading or leaving any other preset leaves the clock alone. If a second preset enables or starts the clock while another owns it, the clock becomes the second preset's - the last one to ask wins - and the first one ending no longer affects it. setTempo() and the calls that stop or disable it take nothing over.
While it is the clock being sent, it is the clock the controller follows: getBpm(), getClock(), getStatus() and getSongPosition() answer for it, the status bar shows its beat beside the outputs it is sent to, a capture recorded meanwhile is written at its tempo, and atSongPosition() cues fire on its beats. The transport callbacks - transport.onClock(), onStart(), onStop() and onContinue() - run for it too, with the enabled transport, and are handed { internal = true } instead of an interface and a port. midi.onClock(), midi.onStart() and the other midi.* callbacks are about what arrives on an input, and do not hear it.
A tempo outside the range is not an error - it is clamped - so read it back with transport.getTempo() if the number came from somewhere uncertain.
Parameters
Returns
interface is required and is one of MIDI_IO, USB_DEV, USB_HOST or ALL_INTERFACES; port is PORT_1, PORT_2 or PORT_CTRL and defaults to PORT_1. An entry that is not a table, or that names an interface or port outside those, raises.
Parameters
Returns
Returns
Returns
Example
-- Clock a drum machine on MIDI 1 and a DAW on USB, at 128 BPM.
transport.setClockOutputs({
{ interface = MIDI_IO, port = PORT_1 },
{ interface = USB_DEV, port = PORT_1 },
transport.setTempo(128)
-- A pad that starts and stops the song.
function onPlayPad (valueObject, value)
if not transport.isClockAvailable() then
info.setText("Following an external clock")
elseif value > 0 then
transport.startClock()
else
transport.stopClock()
-- A knob for the tempo.
function onTempo (valueObject, value)
transport.setTempo(60 + value)
endCallbacks
All six are run on the application thread, from the queue the MIDI callbacks share, a few milliseconds after the message arrives. They run only after transport.enable(), and only for the preset that holds them - see transport.enable() above.
At 120 BPM that is 48 calls a second. A callback doing real work at that rate is a significant share of the application thread; a tempo display is better built on a slow timer reading transport.getBpm().
Parameters
Parameters
Parameters
Parameters
Parameters
transport.getSongPosition() keeps the same number up to date between messages, so a script that only needs to know where the song is does not have to follow this.
Parameters
Example
-- Every transport callback has to be defined before transport.enable() runs,
-- so they are defined here, at the top level, and the transport is enabled in
-- preset.onReady().
faderValue = 0
function transport.onClock (midiInput)
parameterMap.set(1, PT_CC7, 1, faderValue)
faderValue = (faderValue + 1) % 128
function transport.onStart (midiInput)
print("Start")
print("Stop")
function transport.onContinue (midiInput)
print("Continue")
function transport.onSongSelect (midiInput, songNumber)
print("Song select " .. songNumber)
function transport.onSongPosition (midiInput, position)
print("Song position " .. position)
transport.enable()
print("Transport enabled: " .. (transport.isEnabled() and "yes" or "no"))
endMIDI input data table
For the fields it carries, see the midiInput data table.
midiInput = {
interface = USB_DEV, -- a numeric MIDI interface identifier
port = 0 -- a numeric port identifier
}The controller's own clock arrives on no socket, so its callbacks are handed { internal = true } instead - with no interface and no port.
Data Pipe
Data pipes let presets share numbers with each other. A pipe is a named channel: one preset acquires it and sends a stream of numbers into it, and any other preset can subscribe to it and be called with each one.
This is useful when you want different presets to work together. An LFO preset can send out modulation values continuously, and another preset can receive that stream and use it to move its own controls - without either preset knowing anything about the other beyond the pipe's name.
Sixteen pipes exist for the whole controller, numbered 1 to 16, and sixteen subscriptions. A pipe belongs to the preset that acquired it and is handed back when that preset's script is closed - when the preset is removed, replaced, reloaded or overwritten - so a preset does not have to release its pipes to be tidy.
A pipe carries numbers only, one at a time: a subscriber's function is called with the value and nothing else. Values are dispatched on the data pipe thread and handed to the subscriber on the application thread, so a subscriber never delays the sender.
Pipes are named by bank and slot, counted from 0
pipe.subscribe() and pipe.unsubscribe() take an optional bank and slot to name another preset's pipe, and those two count from 0 - bank 0 slot 0 is the first preset - unlike banks and slots everywhere else in the Lua API. They are not checked, so a wrong pair simply never hears anything.
Functions
Raises when the name is empty or longer than twenty characters, and when all sixteen channels are in use. Names are not checked for duplicates: two presets may each acquire a pipe called "lfo", and a subscriber names the bank and slot to tell them apart.
Parameters
Returns
Raises for a channel outside 1 to 16 - which is what a failed pipe.acquire() used to look like. Ownership is not checked: a script may send on a channel another preset acquired.
Parameters
Releasing a pipe a different script owns does nothing and is not an error - a line is written to the log.
Parameters
Returns
Subscribing again under the same name replaces the previous callback rather than adding a second one. Raises when all sixteen subscriptions are in use, and when the name is empty or too long.
A subscription may be made before the pipe exists: it starts delivering when the owner acquires it. A callback that raises is logged at most once every two seconds and stays subscribed. A subscription lasts as long as the script that made it, and goes on receiving while its preset is not the one on the screen.
Sixty-four values are held between the sender and the subscribers, and at most eight are handed over on one pass of the run loop. A subscriber that cannot keep up costs dropped values, and a line in the log.
Parameters
Parameters
Returns
Example: an LFO preset and a preset that follows it
-- The sender, in bank 1 slot 1 - which is bank 0, slot 0 to pipe.subscribe().
local lfo
local phase = 0
lfo = pipe.acquire("lfo")
timer.setPeriod(20)
timer.enable()
phase = (phase + ticks) % 100
pipe.send(lfo, phase / 100) -- 0.0 to 1.0
end-- The receiver, in any other preset. It moves CC 74 of its own device 1 with
-- whatever the LFO preset sends.
pipe.subscribe(0, 0, "lfo", function (value)
parameterMap.set(1, PT_CC7, 74, math.floor(value * 127 + 0.5))
end)
endSnapshots
The snapshots library gives a preset script the same control over stored snapshots that the snapshot window gives the user: it can recall them, save them, rename and recolour them, move them between slots, morph a pair of them, and name the banks they live in.
Snapshots belong to a project, and a script only ever sees the snapshots of the project its own preset belongs to. There is no way to reach another project's snapshots, and no projectId argument anywhere in the library.
Banks and slots are numbered from 1, like pages and preset slots elsewhere in the Lua API — bank 1 is the first bank, slot 1 the first slot. The web editor and the SysEx protocol count them from 0, so a bank that reads as 0 in a SysEx call is bank 1 here.
How many there are differs between the models:
| banks | slots per bank | |
| Electra One mk2 | 12 | 36 |
| Electra One Mini | 8 | 8 |
A bank or slot outside the range raises invalid bankNumber or invalid slot, so ask snapshots.getBankCount() and snapshots.getSlotCount() rather than writing the numbers into a script that has to run on both.
Reads happen now, writes happen soon
The two halves of this library behave differently, and a script that assumes otherwise will read stale data:
- Reads —
get,getSlots,isUsed,getBanks,getBankName,getBankNameOrNil,getCurrentBank,getBankCount,getSlotCount— answer immediately. - Writes — everything else — are put on the controller's command queue and run a moment later, on the thread that owns the SD card. They return nothing, and they cannot report failure.
So a read taken straight after a write still describes the old state:
snapshots.update(1, 1, { name = "Verse" })
print(snapshots.get(1, 1).name) -- still the old nameThis is not a quirk to work around; it is what keeps a script from stalling the user interface while the card is written.
Reads query the database on whichever thread called the script. That is fine from a control's value function, from timer.onTick() or from preset.onReady(). Calling them from a MIDI callback such as midi.onControlChange() or transport.onClock() holds up incoming MIDI for the duration of the query, and the firmware writes a thread-violation line to the log when it happens. Read once and keep the result instead.
Functions
Parameters
Returns
#result is not meaningful — walk it with pairs(). Leave the argument out to read the current bank. Passing
nil explicitly is not the same thing: it raises. Parameters
Returns
Parameters
Returns
Returns
Returns
Returns
Returns
"Bank n", which is what the controller shows on screen. Parameters
Returns
snapshots.getBankName(), except that it distinguishes a bank the user named from one that has only its default name. Use it when a script should react to the names a user actually chose. Parameters
Returns
Recalling an empty slot does nothing.
Parameters
A name or a colour is applied by a second queued command that follows the save, so the pad never shows the generated name first.
Parameters
{ colour = RED } recolours a snapshot and leaves its name alone. An empty table is not an error; it changes nothing. Parameters
Parameters
Parameters
Parameters
Parameters
Only the parameters both snapshots hold a value for are moved. Morphing is a send, not a recall: nothing is written to the card, and the snapshots themselves are unchanged. It does write the live parameter map, though, with the origin
INTERNAL, so every parameter it moves fires parameterMap.onChange. A morph driven from a knob makes a stream of those calls; keep that callback short, or leave it out. The morph slider in the snapshot window counts its balance 0 to 100, which is the range this takes as well. Parameters
captures.getBankName() for the same bank number. Parameters
Parameters
Example: recalling a snapshot by name
-- Finds a snapshot by name anywhere in a bank and recalls it.
function recallByName (bank, wanted)
for slot, snapshot in pairs(snapshots.getSlots(bank)) do
if snapshot.name == wanted then
snapshots.load(bank, slot)
return (true)
return (false)
endExample: labelling the banks a performance uses
-- Run once, when the preset comes up. onReady is the right hook for this:
-- anything set in onLoad is undone before it becomes visible.
snapshots.setBankName(1, "Intro")
snapshots.setBankName(2, "Verse")
snapshots.setBankName(3, "Chorus")
endExample: morphing between two snapshots
-- A fader that morphs slot 1 into slot 2, and a timer that sweeps the same
-- morph on its own.
-- Assign morphFader as the Function of a fader's value. The fader's own MIDI
-- message should be set to "none" so that it only drives the morph. A value
-- function is called with (valueObject, value), and the value is the fader's
-- display value - 0 to 127 for a fader left at its default range, which is
-- scaled here to the 0 to 100 a morph balance counts in.
local bank = 1
local slotA, slotB = 1, 2
function morphFader (valueObject, value)
snapshots.morph(bank, slotA, slotB, math.floor(value * 100 / 127))
-- The same sweep, driven by the timer: four seconds there and back.
local balance = 0
local direction = 1
function startSweep ()
timer.setPeriod(20) -- fifty steps a second
timer.enable()
balance = balance + direction * ticks
if balance >= 100 then
balance, direction = 100, -1
elseif balance <= 0 then
balance, direction = 0, 1
snapshots.morph(bank, slotA, slotB, balance)
endBoth slots have to hold a snapshot
A morph over an empty slot does nothing at all - silently, because writes to this library cannot report failure. Check with snapshots.isUsed() first when the slots come from somewhere uncertain.
Example: a housekeeping pass over a bank
-- Colours the first half of a bank blue and the second half green, and
-- reports how many slots are in use.
function tidyBank (bank)
local used = 0
used = used + 1
if slot <= snapshots.getSlotCount() / 2 then
snapshots.update(bank, slot, { colour = BLUE })
else
snapshots.update(bank, slot, { colour = GREEN })
print("snapshots in bank " .. snapshots.getBankName(bank) .. ": " .. used)
endCaptures
The captures library gives a preset script control over stored captures — the MIDI recordings the CAPTURES window holds. It can play and stop them, arm a slot for recording, change what a capture plays back through and how, move captures between slots, and name the banks they live in.
Everything the snapshots library says about numbering and timing holds here too, and is worth reading first: banks and slots count from 1, reads answer immediately, and writes are queued and take effect a moment later. Captures belong to the current project, and no other project's captures are reachable.
Captures share the snapshots' geometry — 12 banks of 36 slots on an mk2, 8 of 8 on a Mini — and a bank is also laid out in rows, which is what the row notes on the CTRL port and captures.playRow() address:
| banks | slots per bank | rows | slots per row | |
| Electra One mk2 | 12 | 36 | 6 | 6 |
| Electra One Mini | 8 | 8 | 2 | 4 |
Up to eight captures play at once.
The calls that ask what is playing — captures.isPlaying(), getPlaying(), getPlayingSlots(), isArmed(), isRecording() — answer from memory rather than from the database, so they are safe to call from anywhere, a MIDI callback included. getPlaying() and getPlayingSlots() are not filtered by project: they answer for whatever the controller is playing.
What a playing capture tells the presets
Everything a capture plays goes out to its destination, and is then handed back to the presets as if that destination had answered with it. A preset's controls follow a capture the way they follow a synth: a control change moves its control, a SysEx message is matched against the devices' SysEx messages and patch responses, and a patch dump in a capture updates every control its rules name - running patch.onResponse() as a dump from the synth does. The MIDI callbacks are called too, with midiInput.playback set.
Playback is never taken for MIDI input. It is not forwarded by the router, not recorded into another capture, not counted as clock, transport or held notes, and does not reach the remote knobs, MIDI control, the CTRL port services or MIDI learn. It is handed over on the application thread, after it has gone down the wire, so parsing a dump or running a script never delays what a capture sends or what arrives on a socket.
A looping capture hands its messages over on every pass, so a patch dump in it sets the controls back to the dump each time round.
Functions
Parameters
Returns
pairs(). As with the snapshots, leave the argument out rather than passing nil, which raises. Parameters
Returns
Parameters
Returns
Returns
Returns
Returns
Returns
"Bank n". Parameters
Returns
Parameters
Returns
Up to eight captures play at once. One started while others are playing is launched on the next bar line of the one that has been playing longest, so that it lands in time with it - see captures.setLaunchQuantize(); a ninth takes the place of the one playing longest.
Two things count as looping here: a capture whose loop is set, and one given a play range with captures.setPlayRange(). So playing a slot that already has a range and is already going stops it. A looping capture that is still waiting for its bar line restarts instead.
Parameters
Launched on the next bar line of whatever keeps playing outside the set, like captures.play(bank, slot).
-- the first three slots of bank 1, in step, and a new take alongside
captures.arm(1, 4, true)
captures.play(1, { 1, 2, 3 }, true)Parameters
Parameters
Parameters
Returns
Returns
Returns
Parameters
It needs both arguments to ask about one capture. Called with a single argument it ignores it and answers for any capture at all.
Parameters
Returns
Returns
With several captures playing it answers for the one that has been playing longest;
captures.getPlayingSlots() lists them all. Pairing it with captures.stop() to make a toggle stops everything: use captures.isPlaying(bank, slot) and captures.stop(bank, slot) for one capture. Returns
Parameters
Playing begins at from rather than at the top. The tempo set before it is taken on the way, while the notes and controllers before it are not sent, so a note that begins before from is not heard.
With to past from the capture comes round from to to from, whether or not the capture itself is set to loop. It comes round on the instant to falls due, and a note still sounding there is released. When to is left out, or equals from, there is no range: the capture plays from from to its end and, if it loops, comes round to the top.
captures.setPlayRange(bank, slot) with no beats plays the slot whole again.
The range belongs to the slot, not to the script. It takes effect at once on a capture that is playing: a to moved behind the playhead comes round straight away, and anything else when the playhead gets there. It then applies every time the slot is played, by a script, a pad or a row note, until it is set again. It is kept until the controller is switched off and is never saved with the capture. Unlike most writes it is applied immediately rather than queued, so it is in force for a captures.play() that follows it or comes before it in the same callback.
-- Beats five to eight of bank 1 slot 1, round and round
captures.setPlayRange(1, 1, 4, 8)
captures.play(1, 1)A slot with a range counts as looping, so the play() above stops the capture if it was already playing. Set the range on its own to change the loop of a capture that is going.
Parameters
Parameters
Returns
Poll it from a timer to draw a playhead; repaint only when the part of it you show changes.
-- Light the sixteenth being played
local lastStep = nil
schedule.every(15, function()
local beats = captures.getPlayPosition(1, 1)
local step = beats and math.floor(beats * 4)
if step ~= lastStep then
lastStep = step
controls.get(330):repaint()
end)Parameters
Returns
Only one slot is armed at a time; arming another moves the arm. A recording is ended and written by captures.disarm(), not by captures.stop(), which is about playback.
An armed slot and an open slot do not mix
captures.open() refuses a slot that is armed for recording. The other way round is not refused: arming the slot a script has open for writing leaves the recorder to overwrite whatever the editor saves. Close or cancel the edit first.
Parameters
Returns
Returns
Returns
{ loop = true } sets a capture looping and leaves its name, port and root note alone. captures.update(properties) — one table, no bank and slot — is a different call: it changes the capture open for writing. Parameters
Parameters
Parameters
Parameters
Parameters
Parameters
Parameters
Example: a pad that plays and stops
-- Assign this as the Function of a pad's value. Tapping the pad starts the
-- capture; tapping it again while that same capture plays stops it.
function playPad (valueObject, value)
local slot = 1
local bank = captures.getCurrentBank()
-- isPlaying(bank, slot) and stop(bank, slot), not getPlaying() and
-- stop(): with several captures going, getPlaying() answers for the one
-- playing longest and stop() with no arguments stops all of them.
if captures.isPlaying(bank, slot) then
else
endExample: making a whole bank loop
-- Sets every capture in a bank looping and in sync with incoming clock.
function loopBank (bank)
for slot in pairs(captures.getSlots(bank)) do
captures.update(bank, slot, { loop = true, syncToClock = true })
endExample: recording a take
-- Finds the first empty slot of the current bank, arms it, and records into
-- it until the same pad is tapped again.
-- captures.arm() does not record: the take starts when MIDI arrives at the
-- armed slot. captures.disarm() is what ends a recording and writes it - not
-- captures.stop(), which is about playback.
local armed = nil
function firstFreeSlot (bank)
for slot = 1, captures.getSlotCount() do
if not captures.isUsed(bank, slot) then
return (slot)
return (nil)
function recordPad (valueObject, value)
if captures.isArmed() then
captures.disarm() -- ends and saves anything recorded
info.setText("Take saved")
armed = nil
return
local slot = firstFreeSlot(bank)
if not slot then
info.setText("No free capture slot")
return
armed = slot
captures.arm(bank, slot)
info.setText("Armed slot " .. slot)
-- A tidier take: arm the slot, then start its clock on an instant of your
-- choosing rather than on the first note.
function recordInTime (bank, slot)
captures.arm(bank, slot, true) -- wait for record()
captures.record() -- the take's clock starts now
endEditing a capture
A capture is no longer only something the instrument recorded. A script can open a slot, write events into it, read them back, change them and close it again - which is what turns a preset into a sequencer or an editor.
One slot is open at a time, and while it is open every midi.send* addressed to the CAPTURE interface is written into its track instead of going out of a socket:
captures.open(1, 3, { name = "Verse", tempo = 120, length = 16 })
captures.seek(0) -- quarter notes from the head
midi.sendNoteOn(CAPTURE, PORT_1, 1, 60, 100)
captures.seek(0.5)
midi.sendNoteOff(CAPTURE, PORT_1, 1, 60, 0)
captures.addNote(10, 36, 120, 0.25, 1) -- or a note in one call
captures.close() -- written to the card
captures.play(1, 3)CAPTURE is deliberately not part of ALL_INTERFACES: sending to every interface never writes to a file. A send to a real socket works exactly as it always did while a capture is open, so a script can write a note and play it, which is how a step entered on a screen is heard as it goes in.
Editing what is playing. The open slot plays what is being edited, saved or not. captures.play() on it takes the track as it is in the editor, and every change made while it plays is heard at once, without restarting it:
- a note added ahead of the playhead is played when the playhead gets there
- a note removed while it is sounding stops, and one removed ahead of the playhead is not played
- a note lengthened or shortened while it sounds ends where it now ends
- a tempo change is taken up from the playhead
- a track shortened to end before the playhead comes round at once
Nothing already played is played again, and a note added so that it would already have started is not started half way through. Several changes made in one callback are handed to the player together. Saving is only needed to keep the track on the card.
All sixteen MIDI channels live in the one capture, as they do in any MIDI file. There are no tracks to think about - a note carries the channel it was written on.
Positions are quarter notes from the head of the track, fractional, so 0.25 is a sixteenth note. captures.seekTicks() and captures.getTicksPerQuarter() are there for exact work, and captures.seekSongPosition() counts in the MIDI beats - sixteenths - transport.getSongPosition() and transport.atSongPosition() use, so a cue and an event can be lined up without any arithmetic.
The write position does not move by itself: two sends after one seek() land on the same instant, which is how a chord is written.
open(), save() and close() touch the card and answer at once rather than being queued like the rest of this library - a script cannot write its first event until the open has happened, and a failed save has to be reportable. They are not for a timer or a MIDI callback: a card write takes long enough to be felt.
Everything else here needs a capture to be open. captures.open(), captures.cancel() and captures.isOpen() may be called at any time; every other function in this section raises no capture is open for writing when nothing is - captures.get() with no arguments and captures.update() with one table included.
The open slot is shared by the whole controller
There is one editor, not one per preset: another script, or a lua exec typed by hand, can take it away. A preset that keeps a capture open across its life has to survive losing it - check captures.isOpen(), or open the slot again, at the top of every handler that edits. A script's open slot is also released when its preset is removed, replaced or reloaded.
A track holds at most 16384 events, which is as much as a MIDI file this firmware can load. captures.addNote() and captures.addEvent() answer nil and a message when it is full.
nil and a message, while that slot is armed for recording or when the file cannot be read. An empty slot starts an empty track with the defaults a new capture has: 120 BPM, 4/4, 960 ticks to the quarter note, a generated name,
loop = true, syncToClock = false, rootNote = 60, and a destination of USB_DEV on PORT_1. Pass a property table to change any of them as it opens. Parameters
Returns
Returns
captures.save(), then release the slot. The slot is released either way, so a false means the work is gone - check it, or save first and close after. Returns
captures.getPlaying() answers in. Returns
It carries the fields of a capture plus
tempo (BPM), timeSignature (a { numerator, denominator } pair), length (quarter notes), events (how many events the track holds - the file's own meta events counted in, so it is larger than captures.getEventCount()) and modified (true when there is unsaved work). Returns
captures.update(bank, slot, changes) takes, plus the three a track only has while it is open: tempo in BPM, timeSignature as a { numerator, denominator } pair, and length in quarter notes. Unlike the stored-row form this is applied immediately rather than queued. length is worth understanding: a four bar loop whose last note falls in the third bar has to stay four bars long or it comes round early every pass, and a MIDI file says how long it is only by where its end of track marker sits. Without a length a track ends on its last event. Parameters
Parameters
Parameters
transport.getSongPosition() and transport.atSongPosition() count in, so that a cue and an event can be lined up without any arithmetic. Parameters
captures.getTicksPerQuarter(). Parameters
Returns
Returns
Returns
A velocity of 0 is accepted and writes a note on of velocity zero, which is a note off however it is spelled:
captures.getNotes() never reports it and captures.setNote() refuses its id. Write 1 or more. Parameters
Returns
captures.getEvents(): a table that came out of one capture goes into another unchanged, its port included. An interface field is ignored - the destination belongs to the capture, and port is measured against it. The table needs a
type; everything else follows from it. A channel voice message takes its channel (1 .. 16, default 1) and either the named fields of its type (noteNumber, velocity, controllerNumber, value, ...) or the raw data1 and data2, which win where both are present. A system real time message - CLOCK, START - needs nothing else. A SysEx message (type = SYSEX) needs data: the body as a string, without the leading F0 and trailing F7, at most 481 bytes. Raises when the table has no
type, when a SysEx event has no data, and when the SysEx body is too long. Parameters
Returns
midi.onMessage() hands over - so what comes out goes straight into midi.sendMessage(), out of a socket or into another capture - plus the fields an event in a track has: id | the event's id, which getEvent(), setEvent() and removeEvent() take |
at | where it is, in quarter notes from the head of the track |
tick | the same position on the track's own grid |
type | the message type, without its channel - NOTE_ON, CONTROL_CHANGE, CLOCK, SYSEX |
channel | 1 to 16, for a channel voice message |
port | the port it plays out of |
interface | the interface that port is on - the capture's own destination |
data1, data2 | the raw data bytes, always present for a channel voice message |
plus the named fields of its type, as midi.onMessage() gives them: noteNumber and velocity, controllerNumber and value, programNumber, pressure, position, songNumber. A pitch bend's value is the whole fourteen bit number. A SysEx event carries data - the body as a string, without the F0 and the F7.
The array is built in the Lua heap, so a script reading a long capture a bar at a time - { from = 0, to = 4 } - asks for far less than one reading the lot; captures.getEventCount() answers how many there are without building any of them. Meta events - the tempo, the time signature, whatever wrote the file left in it - are not shown: they are kept across a load and a save, and the ones worth changing are in the property table.
One shape does not round-trip: a SysEx event's body arrives as data, which captures.addEvent() takes but midi.sendMessage() does not - send it with midi.sendSysex(interface, port, event.data) instead.
Parameters
Returns
Parameters
Returns
Parameters
Returns
id, offId, at, tick, length, channel, note and velocity. This is what a piano roll draws and what a step in a sequencer is. A note that is never released has no
length and no offId: it is in the track, and a script is entitled to know that rather than be handed a length that was guessed at. The same note struck twice before being released is ended by the first note off, the way a synth stacks them. Parameters
Returns
at moves the note and keeps its length, and length moves its end. This, rather than
captures.setEvent(), is how a note is transposed. A pitch changed on the note on alone leaves the note off releasing a note nobody is playing - and the new one sounding for ever. A velocity of 0 raises: a note of velocity zero is a note off, and removing a note is
captures.removeNote(). A note that was never released keeps its missing end - a length given for it is not written. Parameters
Returns
Parameters
Returns
Parameters
Returns
Parameters
Returns
captures.removeEvents({ channel = 3 }) takes one channel out of a sixteen channel pattern; with no filter it empties the track but keeps how it is notated. Parameters
Returns
length with them - the track goes back to what captures.open() gives an empty slot, at 120 BPM in 4/4 with no length. So clear first, then set the properties. A script that opens a slot with
{ tempo = 100, length = 4 } and clears it afterwards has neither. Use captures.removeEvents() to empty a track and keep how it is notated. The filter table
One shape serves getEvents(), getNotes(), getEventCount() and removeEvents(), so a selection a script can describe can be read, counted and removed. An absent field matches everything.
| field | meaning |
channel | a MIDI channel (1 .. 16), or an array of them |
from, to | quarter notes, half open: to is not included, so two bars asked for one after the other neither overlap nor leave a tick out |
note | a note number, or a { low, high } pair |
type | a message type - NOTE_ON, CONTROL_CHANGE - or an array of at most eight of them |
port | the port the event plays out of, resolved against the open capture's interface |
Two things about channel and note are worth knowing. Asking for either takes the system messages out with them - clock, SysEx and song position carry no channel, so a filter that names one cannot accept them. And note does not by itself exclude anything that is not a note: it narrows note on, note off and poly pressure, and lets a control change on the same channel through. Add type when only notes are wanted.
Example: writing a bar, and reading it back
-- Writes four notes on the beat of bank 1 slot 1, then plays the bar out of
-- a socket.
-- clear() comes before the properties, not after: it takes the tempo, the
-- time signature and the length with the events.
captures.open(1, 1)
captures.clear()
captures.update({ name = "Scale", tempo = 120, length = 4, loop = true,
interface = USB_DEV, port = PORT_1 })
for beat = 0, 3 do
captures.addNote(1, 60 + beat, 100, 0.25, beat)
if not captures.save() then
info.setText("The capture could not be written")
for _, note in ipairs(captures.getNotes({ channel = 1 })) do
print(note.note .. " at " .. note.at .. " for " .. note.length)
for _, event in ipairs(captures.getEvents({ from = 0, to = 1 })) do
midi.sendMessage(USB_DEV, PORT_1, event)
captures.close()
captures.play(1, 1)Example: a step sequencer's pattern
-- Sixteen steps of a sixteenth note each, in bank 1 slot 1, kept as a
-- capture rather than played by a timer: the firmware's own player is far
-- steadier than anything a script can do.
-- The pattern is edited in place while it plays. Everything below assumes a
-- slot is open, which is why every handler calls ensureOpen() first: the
-- editor is one resource for the whole controller, and anything else - a
-- lua exec, another preset - can take it.
local bank, slot = 1, 1
local channel = 1
local stepLength = 0.25 -- a sixteenth note
local steps = 16
function ensureOpen ()
local openBank, openSlot = captures.isOpen()
if openBank == bank and openSlot == slot then
return (true)
return (captures.open(bank, slot) == true)
if not ensureOpen() then
info.setText("Capture 1:1 is busy")
return
captures.clear()
captures.update({ name = "Pattern", tempo = 120,
length = steps * stepLength, loop = true,
captures.save()
-- Is there a note on this step?
function noteAt (step)
local from = step * stepLength
local found = captures.getNotes({ channel = channel,
from = from, to = from + stepLength })
return (found[1])
-- Toggle a step, and keep it playing: the change is heard on the pass the
-- playhead reaches it, with no restart.
function toggleStep (step, note)
return
local existing = noteAt(step)
if existing then
captures.removeNote(existing.id)
else
captures.addNote(channel, note, 100, stepLength * 0.9,
step * stepLength)
captures.save() -- keeps it on the card; playing is unaffected
-- A fifth up, every note of the pattern. setNote() moves the note off with
-- the note on; setEvent() on the note on alone would strand it.
function transpose (semitones)
return
for _, note in ipairs(captures.getNotes({ channel = channel })) do
captures.setNote(note.id, { note = note.note + semitones })
captures.save()
else
endExample: playing captures from a keyboard
-- Plays one capture per incoming note, transposed to the note played.
-- The note-to-slot mapping starts at C3.
-- midi.onNoteOn is handed (midiInput, channel, noteNumber, velocity) - four
-- arguments, not a message table - and it has to be defined at the top level
-- of the script to be registered at all.
function midi.onNoteOn (midiInput, channel, noteNumber, velocity)
local slot = noteNumber - 48 + 1
if slot >= 1 and slot <= captures.getSlotCount() then
captures.transposeTo(noteNumber)
captures.play(slot)
endSnapshot and capture data structures
snapshot
The snapshot data table describes one stored snapshot, as snapshots.get() and snapshots.getSlots() return it.
bank- integer, the bank the snapshot is in (1 ..snapshots.getBankCount()).slot- integer, the slot it occupies (1 ..snapshots.getSlotCount()).name- string, the name shown on the pad.colour- integer, the pad colour (see Globals).
Example
snapshot = {
bank = 1,
slot = 4,
name = "Verse",
colour = BLUE
}capture
The capture data table describes one stored capture, as captures.get() and captures.getSlots() return it. Every field except bank and slot can be changed with captures.update(); the last five are the playback settings.
bank- integer, the bank the capture is in (1 ..captures.getBankCount()).slot- integer, the slot it occupies (1 ..captures.getSlotCount()).name- string, the name shown on the pad.colour- integer, the pad colour (see Globals).interface- integer, the MIDI interface it plays back through (see Globals).port- integer, the port it plays back through (see Globals).syncToClock- boolean, true when playback follows incoming MIDI clock instead of the file's own tempo.loop- boolean, true when playback starts again from the top at the end.rootNote- integer, the note the capture is taken to have been played at. Transposition is measured from here. 60 (middle C) unless it was changed.
Example
capture = {
bank = 1,
slot = 2,
name = "Bassline",
colour = PURPLE,
port = PORT_1,
syncToClock = true,
loop = true,
rootNote = 36
}captures.get() called with no arguments describes the capture open for writing instead, and carries five more fields:
tempo- number, the tempo the track is notated at, in BPM.timeSignature- data table, a{ numerator, denominator }pair.length- number, how long the track is, in quarter notes. This is where its end of track marker sits, which is not necessarily where its last event is.events- integer, how many events the track holds, the file's own meta events counted in.modified- boolean, true when there is work that has not been saved.
openCapture = {
bank = 1,
slot = 1,
name = "Pattern",
colour = PURPLE,
port = PORT_1,
loop = true,
rootNote = 60,
tempo = 120.0,
timeSignature = { 4, 4 },
length = 4.0,
events = 34,
modified = true
}bank
The bank data table describes one snapshot or capture bank, as snapshots.getBanks() and captures.getBanks() return them. Every bank is listed, whether or not the user has named it.
bank- integer, the bank number, counting from 1.name- string, the name to show."Bank n"for a bank the user has not named.named- boolean, true when the user chose this name, false when it is the default.
Example
bank = {
bank = 2,
name = "Chorus",
named = true
}Drawing in a custom control
A control of type custom has no appearance of its own. It is a rectangle on the page that the script draws, using the graphics library, and it is the only place the library may be used.
The script hands the control a function with control:setPaintCallback(), and the firmware calls that function with the control as its only argument every time the control is repainted. The same page also documents the callbacks that answer the control's gestures - setTouchCallback(), setPotCallback(), setPotTouchCallback() and setSwitchCallback().
What a paint callback can rely on:
- Coordinates are the control's own.
0, 0is the top left corner of the control, wherever it sits on the page, andcontrol:getBounds()gives its width and height. Nothing is drawn outside the control: the drawing is clipped to its rectangle. - The area is already cleared to black when the callback starts. There is no need to fill it first, and
graphics.setBackgroundColor()only has to be told about a different background when the text is being printed over something the script filled in itself. - Coordinates must be whole numbers. Every drawing function except
graphics.drawArc()reads its numbers with the integer rule, so10.5raises an error rather than rounding. A computed position needsmath.floor()- or Lua's//- before it is passed in. Negative coordinates are not clipped either; they wrap to a very large number and draw somewhere unexpected. - It runs on the display thread, not the application thread the rest of the script runs on, and while it runs nothing else on the screen is drawn. Keep it short: compute in a timer or a callback, and let the paint function only draw what was computed.
- It shares the preset's Lua lock with everything else in the script. If the lock cannot be taken within 20 ms - because a timer tick, a MIDI callback or a
helpers.delay()is holding it - the frame is given up and the control keeps the picture it already had. A script that freezes its own screen is almost always holding the lock too long somewhere else.
A custom control is not repainted because a value changed: nothing knows what the script drew. Ask for a repaint with control:repaint() when what it draws has changed.
A second screen draws it too
When a satellite is attached over the Electra Satellite Link, the same paint callback is run again into a list of drawing operations that is sent to the satellite, at the rate satellite.frameRate() sets. The callback must therefore be repeatable and must not have side effects: it may be run more often than the screen is painted. Everything in the graphics library is recorded, drawArc included.
Example
A custom control drawing a level meter: a bar that fills from the left, a tick at the loudest level seen, and the value printed over it. The level arrives by MIDI, and the control is repainted only when it changes.
local level = 0 -- 0 .. 127, what the meter shows
local peak = 0 -- the highest level seen since the last reset
local meter = nil -- the custom control
function preset.onReady()
meter = controls.get(20)
meter:setPaintCallback(function (control)
local bounds = control:getBounds()
local width = bounds[WIDTH]
local height = bounds[HEIGHT]
local colour = control:getColor()
-- the track the bar runs in
graphics.setColor(graphics.dim(colour, 0.25))
graphics.fillRect(0, height - 18, width, 16)
-- the bar itself, green at the bottom and red at the top
local filled = (level * width) // 127
graphics.setColor(graphics.blend(GREEN, RED, level / 127))
graphics.fillRect(0, height - 18, filled, 16)
-- the peak tick
local tick = (peak * width) // 127
graphics.setColor(WHITE)
graphics.fillRect(math.min(tick, width - 2), height - 18, 2, 16)
-- the name, and the value right aligned next to it
local text = tostring(level)
graphics.setColor(colour)
graphics.print(0, 2, control:getName(), width, LEFT, BOLD, SMALL)
graphics.print(width - graphics.getTextWidth(text, BOLD, SMALL), 2,
text, graphics.getTextWidth(text, BOLD, SMALL),
LEFT, BOLD, SMALL)
end)
-- a click anywhere on the control clears the peak
meter:setTouchCallback(function (control, event)
if event.type == CLICK then
peak = 0
control:repaint()
end)
function midi.onControlChange(midiInput, channel, controllerNumber, value)
if meter and (controllerNumber == 7) then
level = value
if value > peak then
peak = value
meter:repaint()
endGraphics
The Graphics module provides drawing functions for use within component paint callbacks. Drawing is restricted to the area defined by each component's boundary box.
Every function that draws raises an error when it is called from anywhere but a paint callback - graphics.drawRect: only allowed from a control's paint callback. The display belongs to the thread that paints it, and a script writing to it from a timer or a MIDI handler would corrupt the transfer that thread was in the middle of.
The five functions that only compute - getTextWidth, getTextHeight, rgb, dim and blend - are the exception and may be called from anywhere.
Functions
Parameters
Parameters
Parameters
Parameters
Parameters
Parameters
Parameters
Parameters
It is the only filled shape with arbitrary corners the display offers, so a polygon is drawn as a fan of these.
Parameters
Parameters
Parameters
Parameters
Parameters
The segment is passed straight to the display, which is not checked, so a number that is not one of the four constants draws nothing useful rather than raising.
Parameters
Parameters
The three trailing arguments are optional. They are checked rather than guessed at, so naming a size or a face that does not exist raises an error at the call rather than drawing something arbitrary. The alignment is the one argument that is not checked.
The four sizes are SMALL (12 px), MEDIUM (17 px), LARGE (23 px) and HUGE (47 px), each in a REGULAR and a BOLD weight. The size is the height of one line, so it is also what to step y by when printing more than one.
width and alignment position the string; they do not clip it. A string longer than the box runs past its edge.
MONOSPACED advances every character by the width of the widest one in the face, so a value that changes does not shuffle the characters around it. It is noticeably wider than PROPORTIONAL, because it has to leave room for a W.
Parameters
Parameters
Returns
Parameters
Returns
This is the one drawing function whose numbers may have fractions: they are read as plain numbers, not integers, so an angle worked out from a value needs no rounding.
The arc is built from filled triangles, one per degree of sweep, between four and 360 of them. A long arc at a large radius therefore costs more than a short one.
Parameters
Parameters
Returns
It only darkens. A factor above 1 does not brighten: a channel that goes past 255 wraps and the colour comes back wrong. To brighten, blend towards WHITE with graphics.blend().
Parameters
Returns
Parameters
Returns
These five may be called from anywhere
Unlike the drawing functions, getTextWidth, getTextHeight, rgb, dim and blend compute a number and draw nothing, so they are allowed outside a paint callback. A preset can work its palette and its layout out once, when it loads, rather than per frame.
Window
The Window library gives you control over the graphic component repainting process.
The suspend is a single switch for the whole controller, not one per preset: a window.stop() in one preset stops the repainting of everything, and it stays stopped until something resumes it. Firmware transitions - a popup opening, a page sliding in, the preset list - call resume() themselves, so a stop() that is never matched with a resume() ends the moment the user touches something, which is worse than either state. Always pair them.
Functions
window.stop() before and window.resume() after your updates, you can speed up the process and display all changes together. The repaint requests the updates make are not lost while it is stopped: they queue up, and are drawn when repainting resumes.
It does not force a repaint of anything that did not ask for one. A script that has changed something the firmware does not know about - what a custom control draws, say - follows it with window.repaint() or control:repaint().
Three functions that do nothing
The library also registers window.addAndMakeVisible(), window.clear() and window.findChildById(). None of them works: addAndMakeVisible() always raises, because the component type it wants cannot be built from Lua; findChildById() answers a value with no methods on it; clear() does nothing at all. They are left registered so that older scripts still load. Do not write anything against them.
Parameters
Returns
Parameters
Returns
Returns
Example
-- Twenty controls moved and recoloured, drawn in one pass rather than twenty
window.stop()
for id = 1, 20 do
local control = controls.get(id)
control:setSlot(id)
control:setColor(id <= 10 and BLUE or ORANGE)
window.resume()Controller
The controller library answers questions about the instrument the script is running on: which model it is, which firmware it has, how long it has been running, how much memory the script is using, and what is plugged into the USB host port. It also holds the two compatibility checks a preset uses when it needs a feature that older firmware does not have.
Every function is called on the library: controller.getModel(), not getModel().
Functions
Returns
Returns
It is not the form controller.require() takes. That wants three numbers separated by dots and nothing else, so this string cannot be handed to it.
Returns
Returns
An integer, so every millisecond is exact. It wraps to a negative number after about 24.8 days; a difference between two readings is still right across the wrap, because Lua's integers wrap the same way.
Returns
Returns
Nothing about free system memory is reported, because the firmware has no honest figure for it.
Returns
Returns
vid, pid, manufacturer, product, serial and driver, and a cables array - a controller usually presents several, and only one of them carries the protocol you want. Each cable has a name as the device spells it, a cable number counted from one, and the port it was routed to - PORT_1, PORT_2 or PORT_CTRL, as set by usbHostAssignments in the configuration. A cable that is not routed anywhere has no port field at all, which is not the same as port 1.
The list is every device the host port has, not only the MIDI ones: a uDMX dongle appears here too, with its own driver and no cables.
An empty array is the honest answer when nothing is attached.
Returns
When the requirement is not met the reason is written to the log, so a preset that refuses to run says why.
The version string is strict: digits and exactly two dots. "5.0.0" is a version; "v5.0.0", "5.0" and "5.0.0c" are not, and none of them can ever be met. Passing a number where the string goes, or a string where the number goes, raises an error.
controller.isRequired() asks the same question. The two differ only in intent: require writes the failure to the log, which is what a preset wants when it is about to stop, and isRequired is silent, which is what a preset wants when it is choosing between two ways of doing something.
Parameters
Returns
What changed in firmware 5.0
controller.require() used to return nothing at all and raise an error when the requirement was not met. The documented line assert(controller.require(...)) therefore failed on every controller, met or not: assert() was handed nothing and stopped the script with "value expected". It now returns a boolean, so that line works as written.
Argument types are still checked: a wrong type raises.
Parameters
Returns
Example
-- Stop the script when the instrument cannot run it
assert(
controller.require(MODEL_ANY, "5.0.0"),
"firmware 5.0.0 or newer is required"
-- Or choose a behaviour instead of refusing to run
if controller.isRequired(MODEL_MK2, "5.0.0") then
print("twelve knobs")
else
print("eight knobs")
-- What this instrument is
print("model: " .. controller.getModel()) --> model: mk2
print("numeric model: " .. controller.getNumModel()) --> numeric model: 2
print("firmware: " .. controller.getFirmwareVersion()) --> firmware: v5.0.0c
print("numeric firmware: " .. controller.getFirmwareNumVersion())
--> numeric firmware: 500000000
print("uptime: " .. controller.uptime() .. " ms")
print("lua heap: " .. controller.memory().luaKb .. " kB")
-- Timing a piece of work
local started = controller.micros()
local total = 0
for i = 1, 1000 do total = total + i end
logger.write("the loop took %d us", controller.micros() - started)-- Find a controller on the USB host port, and the port its control cable
-- landed on. A device often has one cable for its keyboard and another for
-- everything else, and they are routed independently.
function findSurface(productName, cableName)
for _, device in ipairs(controller.getUsbHostDevices()) do
if string.find(device.product:upper(), productName:upper(), 1, true) then
for _, cable in ipairs(device.cables) do
if string.find(cable.name:upper(), cableName:upper(), 1, true) then
return device, cable.port
local device, port = findSurface("Launchpad", "MIDI")
if port then
print(device.product .. " is on port " .. port)
else
print("no Launchpad attached")
endHelpers
The helpers library consists of helper functions to make handling of certain common situations easier: placing controls on the page grid, moving a number from one range to another, and reading or writing a MIDI value in signed notation.
Functions
Parameters
delay() blocks this preset completely
The wait holds the preset's Lua lock for its whole length. Nothing else of this preset's script runs meanwhile: no timer tick, no MIDI callback, no scheduled function, and no paint callback - a custom control whose paint cannot take the lock within 20 ms keeps the frame it already had, so the screen freezes where it stands.
Other presets, MIDI routing and MIDI output are not affected: they do not take this lock. But a one second helpers.delay() is one second of this preset doing nothing at all. To do something later, use schedule.after() or midi.at(), which let the script return.
Parameters
Returns
It answers this model's numbers
The rectangle is the one the model actually gives a control: 146 by 56 on an Electra One mk2, 175 by 122 on a Mini. Earlier firmware answered 158 by 56 whatever it was asked - which is neither - and refused any slot above 36, a number a Mini does not have.
helpers.boundsToSlot() is its inverse and round trips with it since firmware 5.0.0. Earlier firmware answered slot 1 for every bounds it was given, including the ones slotToBounds() had just produced. <control>:getSlot() asks the same question of a control.
Bounds that match no slot answer nil rather than a plausible wrong slot. A control placed at bounds of its own is legal in the preset format and is on no slot; a preset that puts something in the wrong place because a helper guessed is very hard to debug.
Parameters
Returns
Example
-- Move control to given slot
local control = controls.get(1)
control:setBounds(helpers.slotToBounds(6))
-- And back again
print(helpers.boundsToSlot(control:getBounds())) --> 6Parameters
Returns
The result carries its fraction: helpers.map(50, 0, 99, 0, 127) is 64.1414..., not 64. Anything that wants a MIDI value wants an integer, so round it - math.floor(x + 0.5) or x // 1 - before passing it to parameterMap.set() or a midi.send* function, which raise on a number with a fraction.
Parameters
Returns
Parameters
Returns
Example
-- A knob's 0 .. 127 as a cutoff in Hz, with the low end spread out
local hz = helpers.scale(midiValue, 0, 127, 20, 20000, 3)
-- Never past the ends, whatever a script computes
local velocity = helpers.clamp(velocity * 1.5, 1, 127)
-- A mapped value on its way back to MIDI has to be whole
local midiValue = math.floor(helpers.map(hz, 20, 20000, 0, 127) + 0.5)
midi.sendControlChange(PORT_1, 1, 74, midiValue)With signBit, the MIDI value that sets the sign bit and nothing else (64 in seven bits) reads as 0, as it does on the display.
A MIDI value that does not fit the bit width raises an error, as does a bit width outside 1 .. 14 or any other sign mode. noSign is not a notation - a control without a sign maps its MIDI range onto its display range - and signBit2 and binOffset are relative modes.
Parameters
Returns
A number the encoding cannot hold is clamped to the nearest one it can, as the Electra clamps it: seven bits hold -64 .. 63 in twosComplement and -63 .. 63 in signBit.
Parameters
Returns
Example
-- Seven bits, two's complement
helpers.midiToSigned(127) -- -1
helpers.signedToMidi(-64) -- 64
-- A 14-bit NRPN with a sign bit
helpers.signedToMidi(-100, 14, "signBit") -- 8292
-- Whatever a signed control's message says. Only twosComplement and signBit
-- are notations, so ask before converting.
local message = control:getValue("value"):getMessage()
local mode = message:getSignMode()
if (mode == "twosComplement") or (mode == "signBit") then
local shown = helpers.midiToSigned(midiValue, message:getBitWidth(), mode)
print("displayed as " .. shown)
endJSON
JSON text to and from Lua values, on the same converters persist() and recall() have always used, plus the two things a table cannot say on its own: a null, and whether an empty table is an array or an object.
The persistence a preset already has - persist(table) writes the table to the preset's own data file and recall(table) fills a table from it - gains a string form of the same file, so a script that keeps its configuration as text can work on it with this module.
How a Lua table becomes JSON:
- A table whose keys are exactly
1 .. nis an array. Any other table is an object, and its keys that are not strings are dropped, with a line in the log. An empty table is an array, unless it is marked withjson.object(). - Arrays go out in index order. The length is the largest integer key, so a marked array with holes writes the holes as
null. - Strings stay strings, even numeric-looking ones:
"43"goes out as"43". - Integers go out without a decimal point, other numbers with one.
- A function, a userdata other than
json.null, andnilall becomenull.
Functions
The document it builds starts at 4 kB and doubles until the value fits. A value that needs more than 512 kB raises an error rather than writing a truncated document.
Parameters
Returns
An empty array comes back marked as one, so it goes out as one again. An empty object does not carry a mark, so json.decode("{}") re-encodes as [] unless it is marked with json.object() first.
Raises when the text will not parse, and when it needs more than the capacity given. A capacity outside 0 .. 524288 raises too.
Parameters
Returns
It is a value, not a nil, so it is truthy: if data.name then is true for a name that decoded from null. Test it with data.name == json.null.
Parameters
Returns
Parameters
Returns
Parameters
Returns
Parameters
Returns
A global function, not part of the json library.
Parameters
Returns
Returns
Example
-- A JSON round trip, with the two things a table cannot say on its own
local settings = {
name = "Bass",
channel = 3,
cutoff = 64,
tags = { "mono", "lead" },
macros = json.object({}), -- empty, and an object
comment = json.null -- written as null, not dropped
local text = json.encode(settings)
print(text)
--> {"channel":3,"tags":["mono","lead"],"macros":{},"comment":null,
--> "cutoff":64,"name":"Bass"}
-- The members of an object come out in whatever order the Lua table hands
-- them over; an array's elements keep their index order. Pass
-- { pretty = true } for indented output.
local decoded = json.decode(text)
print(decoded.name) --> Bass
print(decoded.channel + 1) --> 4
print(#decoded.tags) --> 2
print(json.isObject(decoded.macros)) --> false, an empty object loses its mark
print(decoded.comment == json.null) --> true
-- The same data as the preset's own file
persistJson(text)
print(recallJson() == text) --> trueLogger
Logging is a key element for understanding what is happening inside the controller. The Electra One Lua API provides the print() function and the logger library, which send text messages that can be viewed in the Electra One web application. Log messages created by a script are always prefixed with lua: text.
In fact, these log messages are SysEx messages sent to the CTRL port. They include both a timestamp and the text of the message. For more details about console logs, please review Electra One’s MIDI implementation.
Because logging uses standard SysEx messaging, users can create their own log viewers or integrate Electra logs into their own applications.
The logger output can be enabled or disabled. By default, the logger is disabled for performance reasons, and the controller's own log messages are not sent. Messages written by a Lua script are the exception: they are sent whether the logger is enabled or not. For more information on how to manage the logger, see the section on enabling and disabling logging.
A log message holds 193 characters of text; anything longer is cut off. Every character outside printable ASCII - a tab, a newline, an accented letter - is replaced with # before the message is sent.
Functions
Parameters
One message per argument
print() sends each of its arguments as a separate log message, and the tab between them as a message of its own. To put several values on one line, join them into one string first, or use logger.write().
%dand%i- an integer;%u,%o,%xand%X- an integer as unsigned, octal or hexadecimal;%c- the character with that code.%f,%e,%gand%a(and their upper case forms) - a number.%s- any value, converted the waytostring()converts it, sonil, booleans and objects with a__tostringmetamethod are written too.%%- a percent sign.
A conversion can carry flags (-, +, space, #, 0), a width and a precision of up to two digits each, as in %-8s or %6.2f. A value that does not suit its conversion, a missing value, or a conversion that is not listed raises an error, and nothing is written. Values beyond the ones the format uses are ignored.
The message is written at the Lua log level, the level print() uses, with the same lua: prefix.
Parameters
Example
-- Printing to the console log
print("This message will be shown in the ElectraOne console")
for i = 1, 10 do
print("message #" .. i)
-- Several values on one line
logger.write("cutoff %d, resonance %.2f, filter %s", 64, 0.35, "on")
--> lua: cutoff 64, resonance 0.35, filter on
-- A literal percent sign is written twice
logger.write("loaded %d%%", 80)
--> lua: loaded 80%The Example will produce following output in the Electra One web application Console
System
A preset can keep a Lua table on the SD card and read it back the next time it is loaded - the place for a script's own settings, a remembered mode, a bank of user data the preset JSON has no field for.
The file is data.json in the preset's own slot directory (/ctrlv2/slots/bNN/pNN/data.json). One file per slot, written by the preset that calls these functions, so a preset pinned in the background keeps its own data whatever is on the screen. persistJson() and recallJson() above are the same file as text.
The file is written when the script asks and not otherwise: nothing is saved automatically when a preset is left or the controller is switched off.
Functions
It returns nothing. A missing argument, or one that is not a table, is written to the log and nothing else happens - there is no error to catch.
Parameters
Every key of the table is cleared first, so a table of defaults handed to recall() comes back holding only what was saved, not the defaults for the keys the file does not have. To keep defaults, recall into a table of your own and copy across what you find.
It returns nothing. A missing file, a file that will not parse, and a wrong argument are all written to the log and leave the table empty.
Parameters
It is still there so that scripts calling it keep working, but it should be removed from them. The first time a script calls it after the preset is loaded, the controller writes a message to the log saying where it was called from, for example lua: ctrlv2/slots/b00/p05/main.lua:12: yield() is deprecated and does nothing. Later calls are silent until the preset is loaded again.
Do not use yield() in new scripts. A long loop no longer hands time to other tasks when it calls it; split the work up with timer, schedule or midi.at instead.
Example
-- Remembering a script's own settings across a power cycle
local defaults = { mode = "live", transpose = 0, lastPatch = 1 }
local settings = {}
local saved = {}
recall(saved) -- clears `saved`, then fills it
for key, value in pairs(defaults) do -- defaults for what was not saved
settings[key] = value
for key, value in pairs(saved) do
info.setText(settings.mode .. ", patch " .. settings.lastPatch)
-- Called from a control, whenever the script has something new to remember
function rememberPatch(valueObject, patchNumber)
settings.lastPatch = patchNumber
persist(settings)
endSatellite
An Electra One can drive a second screen - another Electra One, or an application on a computer - over the Electra Satellite Link. The controller running the preset is the primary and owns everything: the preset, the parameter map, the Lua state, the MIDI connections. The satellite owns nothing; it draws the view the primary sends it and reports what the user did to it.
The satellite library is the primary's side of that: it says what the satellite should show, and answers whether one is attached. A satellite never runs Lua, so these functions are only ever called on the primary.
The library exists on every model, whether or not a satellite is attached. satellite.page(), satellite.preset() and satellite.frameRate() answer false when there is no session to act on, so a preset can call them without checking first.
Functions
Parameters
Returns
The satellite starts on that preset's active page.
This is what gives a background preset a surface of its own: a bank of macros or a set of LFOs running pinned can be played from the satellite while the primary's screen stays on the preset being performed.
Parameters
Returns
It costs link bandwidth, so ask for what the picture needs - a meter that follows a value wants more than a label that changes with a patch. Controls that are not custom do not use this at all: they are sent as values, when the value changes.
With no satellite attached it answers false and the rate is unchanged.
Parameters
Returns
Returns
| field | |
connected | boolean, whether a session is open |
presetId | integer, the preset slot on the satellite, counted from zero; 0 when nothing is connected |
pageId | integer, the page it is showing; 0 when nothing is connected |
frameRate | integer, the custom-control capture rate in frames per second |
frameRate is answered whether or not a satellite is attached - it is the rate the next session will run at.
Returns
Example
-- Put a pinned background preset on the satellite, and keep the primary's
-- own screen on the preset being played.
if not satellite.isConnected() then
return
satellite.frameRate(20) -- enough for a moving meter
local lfoSlot = 4 -- bank 0, slot 4
if presets.isPinned(lfoSlot) then
if satellite.preset(lfoSlot) then
info.setText("LFOs on the satellite")
else
satellite.page(2) -- this preset's second page instead
local status = satellite.status()
logger.write("satellite: preset %d, page %d, %d fps",
status.presetId, status.pageId, status.frameRate)
endGlobal constructors
Nine global functions build an object for something the preset already has. Each one is another spelling of a library function, and each raises when the preset has nothing with that id.
Parameters
Returns
Parameters
Returns
Parameters
Returns
Parameters
Returns
Parameters
Returns
Parameters
Returns
Returns
Returns
Returns
Globals
The global variables are used to identify common constants that can be used instead of numbers.
Every one of them is a Lua integer. They can be compared with == against the numbers a callback is handed, used as table keys, and printed without a trailing .0.
Hardware ports
Identifiers of the MIDI ports.
PORT_1PORT_2PORT_CTRL
Interfaces
Types of MIDI interfaces.
MIDI_IOUSB_DEVUSB_HOSTALL_INTERFACESCAPTURE
CAPTURE is not a socket: it is the capture a script has open for writing, and a midi.send* addressed to it is written into that capture's track instead of going out. It is deliberately not part of ALL_INTERFACES, so sending to every interface never writes to a file.
Change origins
Identifiers of the sources of the MIDI value change. Origin is passed as a parameter of the ParameterMap onChange callback.
INTERNALMIDILUA
Three more origins reach parameterMap.onChange and have no constant of their own: 4 a file being loaded, 5 a remote knob, 6 a satellite. 3, a modulation, never reaches Lua. A script that only wants INTERNAL, MIDI or LUA should test for them rather than test for "not one of the others".
Parameter types
Types of Electra MIDI parameters. These types are higher abstraction of the standard MIDI message types.
PT_VIRTUALPT_CC7PT_CC14PT_NRPNPT_RPNPT_NOTEPT_PROGRAMPT_SYSEXPT_STARTPT_STOPPT_TUNEPT_ATPOLYPT_ATCHANNELPT_PITCHBENDPT_SPPPT_RELCCPT_NONE
Type 17, the macro, is accepted everywhere these are and has no constant.
Control sets
Identifiers of the control sets. The control sets are groups of controls assigned to the pots.
CONTROL_SET_1CONTROL_SET_2CONTROL_SET_3
Pots
Identifiers of the hardware pots. The pots are the rotary knobs to change the control values.
POT_1POT_2POT_3POT_4POT_5POT_6POT_7POT_8POT_9POT_10POT_11POT_12
All twelve exist on every model, because the constants are the same everywhere. An Electra One mk2 has twelve knobs; a Mini has eight, and POT_9 to POT_12 address its four pads.
Hardware buttons
Identifiers of the hardware buttons, 1 to 6.
BUTTON_1BUTTON_2BUTTON_3BUTTON_4BUTTON_5BUTTON_6
No Lua callback is handed a button identifier, so these are of use only to a script that keeps its own numbering and wants a name for it.
Touch points
Identifiers of the touch points the LCD tracks, 1 to 5.
TOUCH_POINT_1TOUCH_POINT_2TOUCH_POINT_3TOUCH_POINT_4TOUCH_POINT_5
The id field of a touch callback's event is one of these.
Colors
Identifiers of standard Electra colors.
WHITEREDORANGEBLUEGREENPURPLE
They are 24-bit RGB numbers - WHITE is 0xFFFFFF, RED is 0xF45C51 - so they can be handed to graphics.setColor() and to graphics.dim() and graphics.blend().
Variants
VT_DEFAULTVT_HIGHLIGHTEDVT_THINVT_VALUEONLYVT_DIALVT_CHECKBOXVT_BUTTONLIKE
Bounding box
Identifiers of individual attributes of the bounding box (bounds).
XYWIDTHHEIGHT
Unset MIDI value
MIDI_VALUE_DO_NOT_SEND
The value a message holds when it has nothing to send - a pad that sends something when it is pressed and nothing when it is let go writes this in its off value. It is 16537, which is not a MIDI value of any width, so it can never be mistaken for one.
It is accepted by the setters that build a message and refused by everything that sends: parameterMap.set() and the midi.send* functions take 0 to 16383. <message>:isValueSet() and <value>:isSet() ask the same question without the number.
MIDI message types
Identifiers of standard MIDI messages.
CONTROL_CHANGENOTE_ONNOTE_OFFPROGRAM_CHANGEPOLY_PRESSURECHANNEL_PRESSUREPITCH_BENDCLOCKSTARTSTOPCONTINUEACTIVE_SENSINGRESETSONG_SELECTSONG_POSITIONTUNE_REQUESTTIME_CODE_QUARTER_FRAMESYSEX
Each is the status byte of that message with the channel cleared: NOTE_ON is 144, CONTROL_CHANGE is 176, SYSEX is 240.
Controller events
Flags indentifying individual types of events.
NONEPAGESCONTROL_SETSUSB_HOST_PORTPOTSTOUCHBUTTONSWINDOWS
They are bit flags, meant to be added together and passed to events.subscribe(). TOUCH, BUTTONS and WINDOWS are accepted but run no Lua callback in this firmware.
Touch events
Identifiers of touch events used in the Touch callbacks.
DOWNMOVEUPCLICKDOUBLECLICK
Control event sources
Identifiers of the gesture a control event callback came from, passed as its source argument.
EVENT_SOURCE_SWITCHEVENT_SOURCE_TOUCH
Control event types
Identifiers of the edge that ran a control event callback, passed as its event argument. A switch reports press and release, a touch reports begin and end.
EVENT_TYPE_PRESSEVENT_TYPE_RELEASEEVENT_TYPE_BEGINEVENT_TYPE_END
Curve segments
Identifiers of the curve segments used in the graphics module.
TOP_LEFTTOP_RIGHTBOTTOM_LEFTBOTTOM_RIGHT
Controller models
Identifiers of the Electra One hardware models.
MODEL_ANY- any modelMODEL_MK2- Electra One mk2MODEL_MINI- Electra One mini
MODEL_MINI_MK1 is an accepted alias for MODEL_MINI, and MODEL_MK1 is historical: it matches no model this firmware runs on, so controller.require(MODEL_MK1, ...) always fails.
Horizontal alignment
Text alignment modes
LEFTCENTERRIGHT
Text faces
Weights graphics.print can draw in
REGULARBOLD
Text sizes
Sizes graphics.print can draw in, given as the height of one line
SMALL- 12 pxMEDIUM- 17 pxLARGE- 23 pxHUGE- 47 px
Text spacing
How far each character advances
PROPORTIONAL- each character takes its own widthMONOSPACED- every character takes the width of the widest one
The JSON null
json.null- a field of thejsonlibrary rather than a global. See JSON above.
