Modules and Namespaced Functions
As Lua programs grow, simply placing all functions in the global space becomes confusing and unsafe. Modules solve this problem by grouping related functions together under a single table. This is exactly how the Electra One Lua Extension API is structured.
What Is a Module in Lua?
In Lua, a module is usually just a table that contains functions.
local math_utils = {}Functions related to the same task are stored inside this table.
function math_utils.add(a, b)
return a + b
function math_utils.sub(a, b)
return a - b
endThis table now represents a module.
Calling Functions from a Module
Functions inside a module are accessed using the dot (.) operator.
local result = math_utils.add(3, 5)The dot means:
“Access the value named add inside the table math_utils.”
This is not special syntax — it is simply table access.
math_utils.add
-- is the same as
math_utils["add"]Why the Dot (.) Is Important
The dot operator makes it clear:
- where a function comes from
- what it belongs to
- what area of functionality it represents
Compare these two styles:
sendMidiNote(60, 127)vs
electra.sendMidiNote(60, 127)The second version is self-documenting. You immediately know:
- this function belongs to electra
- it is part of an API, not user code
- it is related to Electra One functionality
Avoiding Global Namespace Pollution
Without modules, functions are global by default.
function draw()
function send()
endThis easily leads to name collisions. Modules avoid this:
ui.draw()
midi.send()Each function lives in a clearly defined namespace.
Modules Group Related Behavior
A module is not just a container — it represents a concept. Example:
midi.sendNote(note, velocity)
midi.sendCC(cc, value)
midi.sendProgramChange(program)All MIDI-related behavior lives under midi. Users do not need to remember dozens of unrelated function names — they explore the module instead.
Modules vs Objects
Modules look similar to objects, but they serve a different purpose. Modules organize functionality Objects represent individual entities with state Example module:
midi.sendNote(60, 127)Example object:
local button = Button:new()
button:setLabel("Play")Summary
In Lua, modules are tables that group related functions. The dot (.) operator is used to access functions stored inside these tables. This pattern avoids global name conflicts, improves readability, and makes APIs easier to understand and maintain. The Electra One Preset Lua Extension API uses modules extensively to clearly separate areas of functionality and provide a clean, scalable interface for users.
