Tables
Tables are the most important data structure in Lua. A table is a collection of values grouped together under a single name. Tables can act as arrays, dictionaries (maps), records, or even objects. Almost everything beyond basic values in Lua is built using tables.
Creating Tables
A table is created using curly braces {}.
local empty = {}
Tables can store multiple values:
local numbers = { 10, 20, 30 }
Tables can be assigned to variables just like any other value.
Tables as Arrays
When values are stored with numeric indices starting at 1, tables behave like arrays.
local colors = { "red", "green", "blue" }
print(colors[1])  -- red
print(colors[3])  -- blue
Lua arrays are 1-based, meaning the first element is at index 1, not 0.
Tables as Dictionaries
Tables can also store values under named keys.
local player = {
    name = "Alex",
    score = 100,
    lives = 3
Values can be accessed using dot notation or bracket notation:
print(player.name)
print(player["score"])
Dot notation is just a shortcut for string keys.
Mixed Tables
A table can contain both numeric and named keys at the same time.
local data = {
    "apple",
    "banana",
    count = 2
Mixed tables are common in Lua, but should be used carefully to keep code readable.
Adding and Modifying Table Values
New values can be added at any time:
local items = {}
items[1] = "sword"
items[2] = "shield"
items.owner = "player"
Existing values can be changed:
items[1] = "magic sword"
Removing Values from Tables
Setting a key to nil removes it from the table.
player.lives = nil
Iterating Over Tables
Tables are commonly processed using loops. Sequential arrays use ipairs:
for i, value in ipairs(colors) do
    print(i, value)
Key–value tables use pairs:
for key, value in pairs(player) do
    print(key, value)
Table Length
The length operator # returns the size of a sequence.
print(#colors)
The result is only reliable for tables that behave as arrays without missing indices.
Tables Are References
Tables are reference values, not copies.
local a = { 1, 2, 3 }
local b = a
b[1] = 99
print(a[1])  -- 99
Tables and Functions
Tables can store functions as values.
local calculator = {}
calculator.add = function(a, b)
    return a + b
print(calculator.add(2, 3))
Common Mistakes
Assuming tables are copied automatically:
local copy = original  -- this does not create a new table
Using index 0 in arrays:
colors[0] = "black"  -- valid, but usually unintended
Tables are Lua’s primary data structure. They can represent arrays, dictionaries, or more complex structures. Tables are flexible, dynamic, and passed by reference. Understanding how to create, modify, iterate over, and reason about tables is essential for writing effective Lua programs.
