Custom Controls ​
A custom control is a control that draws itself. The preset's Lua script paints it and decides what its knobs do, so it can be anything: a ring of LEDs, a filter curve, a bank of eight mixer faders spread over a whole page. How to write one is shown in the tutorial Drawing a Custom Control.
The Electra One app can keep a custom control on its own, apart from the preset it was written in, and offer it to every preset you make. Such a control is called a control in the app, and it is a single file holding the control, the Lua that draws it and a picture of it.
This chapter covers:
Firmware
Custom controls need firmware 4.0.0 or newer. A control that has several values needs firmware 5.0.0, and switching between its values with one knob needs a firmware newer than 5.1.0. The card of each control says which firmware it needs.
Where controls are kept ​
Controls are on the Controls tab of two pages:
  • Workspace → Controls lists the controls you made. This is where you add, publish and delete them.
  • Library → Controls lists the controls other Electra One users have published, and your own public ones.
The Controls tab of the Library
Library → Controls: three published controls, each with its picture, brief and facts
Each control is a card with the control's picture as the controller draws it, its name and version, its author, a one-line brief, and a line of facts:
FactExampleWhat it means
Latest releaselatest 1.0.1The newest version of the control.
Size4 × 2 slotsHow many slots of a page the control covers, across by down.
Firmwarefirmware 5.0.0 or newerThe oldest firmware the control works on.
ModelsminiThe controllers the control was drawn for.
Values8 valuesHow many values, and so parameters, the control has.
The search box narrows the list by name and brief as you type. Under it, All controls and In my palette switch between every control and only those you have put in your palette.
Click a control's picture or name to open its page.
Using a control ​
A control is used by dragging it from the Preset Editor's palette onto a page, like any other control. To get it into the palette, star it.
  1. Open Library → Controls, or Workspace → Controls for your own.
  2. Click ☆ ADD TO MY PALETTE on the control's card. The button changes to ★ IN MY PALETTE. Click it again to take the control out of the palette.
  3. Open a preset in the Preset Editor. The starred controls are one more tile in the control repository under the grid, stacked like the variants of the other tiles. Click the tile to open it and choose a control.
Starred controls in the editor's palette
The control repository of the Preset Editor. The last tile holds the starred controls, shown with their pictures
  1. Drag the control onto a slot of the page. A control larger than one slot covers the slots to the right and below. The editor adds the control's Lua to the preset's script, so there is nothing to copy by hand, and says that the control was added.
  2. Select the control. The editor cannot draw a custom control, so it shows its outline and name. Its settings list:
    • Pots, the knobs that move each value. They are the ones the author chose. Change them in Expert mode to suit where the control sits in your preset.
    • one card for each value, such as CH1 to CH8, with its range, its default and the MIDI message it sends. Set the device and parameter numbers here, as for any control.
  3. Send the preset to the controller to see the control drawn.
A control placed on a page
The MIXER control placed over the first page of a Mini preset. The Selected view lists its eight pots and a card for each value
You can place a control as many times as you like, in as many presets as you like. Each placed copy has its own values and parameters, and they share the Lua that draws them.
Several values on one knob ​
A control with several values does not need a knob for each of them. One of its values is in focus, the way one segment of an envelope is, and the knob the control sits on moves the value in focus. To move another value, hold the knob and use Next handle or Previous handle, exactly as on an envelope: on the Mini, press CONTEXT while the knob is held and then NEXT or PREVIOUS; on the Mk2, the buttons or commands the controller's settings assign to them. The control's Lua is told which value is in focus and draws it highlighted, or draws only that value, as its author chose.
The focus starts on the value chosen under Value assigned to knob in the control's settings.
The Pots list, in Expert mode, is for the other arrangement: each pot named after one of the control's values is pinned to that value, and moves it whatever is in focus. The two mix. A pot in the list that is named after none of the control's values is not pinned: it moves the value in focus, so a control with twelve values can have a few pots pinned to the values that matter most and one pot that reaches all the others with Next and Previous handle.
Two custom controls on a Mini
Two custom controls with two values each. DUAL spans two slots and has a pot pinned to each value. SOLO sits on one knob; its value in focus is marked, and Next handle moves it
The preset in the picture, with a third control that shows only the value in focus, is focus-demo.epr with focus-demo.lua.
Do not edit the control's Lua
The editor keeps the Lua of placed controls in a marked region at the end of the preset's main.lua. Write your own code above that region. A change made inside it is replaced the next time a control is placed or updated.
You can keep up to 40 controls in the palette.
The control page ​
The page of a control describes it in full and lists its releases.
The MIXER control: its description, size, firmware, values and pots, its releases and its Lua
  • Size, Firmware and Drawn for repeat the facts of the card.
  • Values lists the names of the control's values. Each of them can send its own MIDI parameter.
  • Pots says which knob moves which value, counted from the knob the control is placed on. A control that lists no pots is moved by its own knob alone.
  • Releases lists the versions of the control, newest first, with the date, size, firmware and models of each. DOWNLOAD saves a release as a control file (.ectrl).
  • Lua shows the script that draws the control. It is read only.
The button at the top stars the control into your palette, as on the card. The owner also sees DELETE CONTROL, and the publishing buttons of each release, described in Publishing a control.
Making a control ​
A control is written as a preset holding exactly that one control. That is also how you try it on the controller, because the controller runs Lua only as part of a preset.
Write the preset ​
  1. In Workspace, click CREATE PROJECT and give the preset the name of the control.
  2. Switch the editor to Expert mode and place a Custom control from the misc tile on the first knob slot of page 1. Stretch it over more slots if it needs them.
  3. Write the Lua that draws it. A control's script is written as a small module, so that it can live beside other controls in somebody else's preset. The editor checks the script when the control is saved and says what to change. The rules are summed up below.
  4. Send the preset to the controller and try the control until it does what it should.
The script is a table with an onReady function, which the preset calls once for each control of this kind:
local ring = {}
function ring.onReady(control)
  control:setPaintCallback(ring.paint)
  control:setPotCallback(ring.onPot)
  control:repaint()
function ring.paint(control)
  -- draw the control
function ring.onPot(control, event)
  local value = control:getValue(event.valueId)
  value:setValue(value:getValue() + event.delta)
  control:repaint()
-- electra-control harness begin
function preset.onReady()
  ring.onReady(controls.get(1))
-- electra-control harness end
return ring
  • Keep every function on the module's table, or make it local. A global function is refused, because two controls in one preset would overwrite each other's.
  • Do not set preset.onReady or a timer in the module. They belong to the preset the control is placed in.
  • Do not put events on the control. Use control:setSwitchCallback and control:setPotTouchCallback in onReady instead.
  • The lines between harness begin and harness end run the control in this preset only. They are not carried with the control.
  • The return at the end must start at the beginning of the line.
  • Draw in the control's own coordinates. In the paint function 0, 0 is the control's top left corner wherever it is on the page, and control:getBounds() gives its width and height as bounds[WIDTH] and bounds[HEIGHT]. Do not add bounds[X] and bounds[Y] to what you draw: they are the control's place on the page, and a drawing offset by them lands outside the control and is clipped away, so the control stays blank even though the script runs without an error.
  • Call control:repaint() at the end of onReady and whenever a value changes. A custom control is not repainted for you.
  • In the pot callback, event.valueId names the value the knob moves: the value a pot is pinned to, or the value in focus for a knob that is not. Hand it to control:getValue() as the example does, rather than comparing it with a fixed name. control:getActiveValueId() tells the paint function which value to highlight, and control:setActiveValueCallback() is told when Next or Previous handle moved it. See the value in focus.
Set the type and make a release ​
On the preset's page:
  1. Click the pencil next to Type, choose Control and click DONE. A preset stays of type Control only while it holds one custom control and nothing else.
  2. Take a screenshot with TAKE SCREENSHOT, with the control shown on the controller. The picture is cut from it, and a control cannot be published without one.
  3. Write a Brief, one line that says what the control is. The Library shows it under the name.
  4. Make a release of the preset and make it official. See Revisions and releases. The control's version is the version of that release.
A preset of type Control cannot be made public as a preset. It is shared as a control instead.
Save the control ​
Open the arrow next to DOWNLOAD PROJECT. A preset of type Control offers two more choices:
The download menu of a control
The download menu of a preset of type Control: Export control and Save control to library
  • Save control to library adds the official release to Workspace → Controls. Saving again after a new release adds that release to the same control.
  • Export control downloads the control as a file (.ectrl) that you can send to somebody. IMPORT CONTROL on Workspace → Controls reads such a file and adds it to your controls.
Your controls in the Workspace
Workspace → Controls: three controls, each with its palette star, publishing button, releases and delete
Publishing a control ​
A published control is in Library → Controls for everybody. Publishing is a request: you ask for one release to be published, and the Electra One team looks at it and publishes it, or declines it.
Your namespace ​
A published control carries its author's namespace, a short word that tells your controls from those of other people. Set it once, before the first request: click your name in the top bar and choose Namespace.
The namespace
The Namespace dialog of an account whose namespace is set. It cannot be changed here
The namespace has 2 to 24 lowercase letters, digits or hyphens, and nobody else may use it already. It cannot be changed later. Once it is set, the dialog shows it, and asks you to contact support if it really has to change.
Requesting publication ​
On Workspace → Controls, each control has these buttons:
ButtonWhat it does
☆ ADD TO MY PALETTEPuts the control in your editor palette. ★ IN MY PALETTE takes it out.
REQUEST PUBLISHING 1.0.1Asks for the newest release to be published. The card then says the request is waiting.
WITHDRAW REQUESTTakes the request back before it is decided.
UNPUBLISH 1.0.1Takes the public release out of the Library.
RELEASESOpens the control's page with its releases.
DELETEDeletes the control and all its releases. A public control has to be unpublished first.
When a new release is published, it takes the place of the previous one. Until then, the Library keeps offering the release that was public before. Presets that already use the control keep the copy they were made with. Placing the newer release in such a preset updates every copy of the control in it.
The desktop Electra One app keeps your controls in its local library, next to your presets.
